Nervar/Stronglight chainrings and 10 speed chains
Ive been scouring the site and I can't find a definitive answer. I have a Peugeot with a nervar crank. Uses the same damn 122bcd as stronglite. No aftermarket rings in this size. Has anyone on a vintage French crankset successfully run a 10 speed chain?
I have DA index 10spd downtube shifters and matching rear mech. Drop outs have been cold set and new wheels fitted. Only piece to the puzzle is the crank. Not opposed to getting a different crank, but would like to keep this one if I can.
Bikes: 1973 Schwinn World Voyageur | Francesco Moser SL | 1984 Ross Utopian | St. Etienne 531 | 1981 Peugeot PK10 | 2015 Cannondale SuperSix | 2012 Felt F65X
Quoted: 54 Post(s)
Liked 51 Times
I run a 10sp chain on a Shimano 600 crank and just compared chainring thickness to my Nervar rings. They are the same. I cannot speak to tooth profile. On my 10speed setup, it will occasionally drop a chain but I think that is more the front derailleur not being happy with the range as it too is vintage (Shimano Golden Arrow).
I have often been tempted by Red Clover Components to get more range out of 122bcd, but have not taken the plunge. Perhaps not helpful here as it sounds you real hope is to leverage the 10speed setup you already have.
122 BCD Conventional Chainring, 37 Teeth
Quoted: 54 Post(s)
Liked 51 Times
I feel like I have been pursuing that for some time and tried the 10speed route to find that I had built a heavy bike (using freewheel). Ultimately I started looking for the 50.4bcd cranks that take the TA Cyclotouriste chainrings. While I am currently setup with a 52-30 chainring on my Nervar crank and a 13-28 freewheel, I think dropping the 52 to a 48 like many of the VO / Herse cranksets will make for more comfortable shifts down. Oddly shifting up is super smooth with a Simplex SLJ front derailleur.
elcraft
I thought that Nervar used 128 mm BCD chain rings! I recall reading some where that someone successfully altered the bolt opening with a rat tail/ round file to alter the more commonly found 130 mm BCD chain rings. If your Nervar are actually 122 mm rings, then XXCycle is the only purveyor that stocks 122 mm rings.
Old fart
Quoted: 3604 Post(s)
Liked 3,431 Times
Likes For JohnDThompson:
I’ve currently ridden ~5k hassle free kms using stronglight 105 crankset with modified large chainring paired to srampagnolo 10spd specific derailleurs.
Chainrings are 48-40 and originally there were massive problems with 10spd chain getting stuck between chainrings when shifting chainrings under any amount of power. I modified the large chainring by adding extra layer of material (chemical metal/epoxy filler) to chainring’s inner surface and then sanded/chamfered it to resemble modern 10spd chainring profile.
This way, I did not need to modify the crankarm. Chainring teeth are technically still too wide apart for 10spd chain (8spd ok), but large chainring has a nice inner slope for chain to find it’s place when shifting. Some epoxy did chip off during first few hundred kms (probably due chainrings flexing), but apparently there doesn’t need to be as much added material as I initially thought.
Long story short - chainring teeth thickness should be about the same from 5spd to 12spd, as chain inner width is not changed*.
Modern chainrings on the other hand, need to be closer to each other to accommodate narrower chain outer width required by narrower rear sprocket spacing.
* 5-8spd chains have 2.38mm inner width while 9-12spd have 2.18mm inner width, which is close enough to work on any number of multi-speed sprockets. Outer width determines chain in-/compatibility with cassettes with different number if sprockets.
more info: Bike gremlin
Shifting is fun!
Bikes: Yes, please.
Quoted: 2213 Post(s)
Liked 4,676 Times
I have 122bcd cranks on several bikes. 50/40, 50/37, 52/37. Combined with a 14-28 FW, and a short cage RD, they work well for me.
I am staring at a modern 2015 crank and my spare stronglite. Side by side. Consensus is the 6spd rings are too widely spaced to accommodate a 9/10/11 speed chain. Aside from tooth count which has minimal effect in throw of the chain from big to little the most glaring factor is the size of the spacers for the chainring bolts. Will modern chainring bolts fit?
