Chain skip
Chain skip
So, as the title suggests, chain is skipping. I've replaced the front gears a few months ago, hadn't ridden since then (winter, lockdown). Rode monday, no issues. Lubed the chain and gears when I got home, Tuesday, slipping and skipping. Front set had some shark fin going on, but the back looks fine, and it happens on any gear, even though I almost never shift (maybe once every few months). Happens mostly when I'm going up a hill or just getting started, any high-torque situation, but it won't slip when the back wheel is stationary.
any ideas? I figure my chain is either too stretched or my derailleur spring is shot. Both components are original, and this is a crap Dept store bike, gotta be 5 years old now.
Probably best to replace both, that's likely the problem, right?
Edit - 7 years old based on my first post. Time flies!
Quoted: 350 Post(s)
Liked 122 Times
Well first thing you could do is search the internet for recommended replacement schedule for parts of the drivetrain. What was the reason for installing new chainrings? It would not be effective to only install new chainrings if both the chain and cassette after 7 years old. Usually the chain gets replaced multiple times before the cassette and then the chainrings. If the chain is really old and you install new chainrings then you'll get bad engagement. If you replace the chain and you have very old cassette then you'll also get bad engagement..
I'd replace the whole bike if I could but if a $20 chain and a 20$ derailleur will resolve it for now, that's what I'll need to do. Can't really afford to replace the entire drivetrain, and I expect the rest of the cassette is fine since I practically never use anything but the one in the middle, honestly maybe an hour of use over two years.
Quoted: 283 Post(s)
Liked 262 Times
Your derailer adjustment may be a bit off, won't cost anything to look. On your derailer housing you should have a barrel adjuster somewhere. Turn the adjuster 1/2 turn counterclockwise, ride around & shift. Better or worse? Try another 1/2 turn. Worse, go back to original plus 1/2 turn clockwise, better or worse? You get the idea. You can turn the bike upside down in the grass, turn the crank, shift, and look how the derailer lines up with the cogs. Cogs have no sideplay with the hub? Best of luck.
Likes For grizzly59:
Very Senior Member
Bikes: Giant Quasar & Fuji Roubaix
Quoted: 413 Post(s)
Liked 343 Times
Reading through the post it sounds to me like you have a chain link binding. I would check each link with my fingers and make certain there aren't any tight links that won't pivot easily between your fingers. That happens to me when I neglect cleaning and re-waxing the chain often enough. Especially if I ride in or shortly after a rain and the tires are kicking up lots of light sand/grit that sticks to everything. If all the links feel fine, then check your tuning adjustments and make sure the chain is centered over each cog that it should be and not being pulled to either side (fine tune it). A very worn chain and gears will still function properly if adjusted correctly. They didn't wear out in a week since the last time you rode. Check the links.
Grizzly and I were typing at the same time. That;s good advice and a great tutorial.
Likes For Bigbus:
On your derailer housing you should have a barrel adjuster somewhere. Your derailer adjustment may be a bit off. Turn the adjuster 1/2 turn counterclock, ride around & shift. Better or worse? Try another 1/2 turn. Worse, go back to original plus 1/2 turn clockwise, better or worse? You get the idea. You can turn the bike upside down in the grass, turn the crank, shift, and look how the derailer lines up with the cogs. Cogs have no sideplay with the hub? Best of luck.
