Shimano levers.... what witchcraft is this!?
Bikes: '84 Miyata 610 ‘91 Cannondale ST600,'83 Trek 720 ‘84 Trek 520, 620, ‘91 Miyata 1000LT, '79 Trek 514, '78 Trek 706, '73 Raleigh Int. frame.
Quoted: 685 Post(s)
Liked 370 Times
what kind of wafer thing socket fits in here?
Quoted: 1949 Post(s)
Liked 2,010 Times
I think my 1/4 inch drive sockets fit there with the screwdriver handle thing. The hard part is finding hoods that fit.
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,054 Times
Gotta be metric.9mm?
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,404 Times
Nah. 10mm quarter inch socket on an extension will do the trick. Tight, but it works.
There’s a guy in France who sells hoods that fit those levers. Check eBay- they run under $10 a pair. More plastic than rubber but comes in at least three colors.
You’ll need to source beehives for the lever tops if you don’t already have them.
Insane Bicycle Mechanic
Quoted: 805 Post(s)
Liked 705 Times
Or an 8/9/10mm "Y" wrench. The nut doesn't have to be really tight, just enough to hold the brake lever in position.
Jeff Wills
Jeff Wills
Quoted: 1372 Post(s)
Liked 1,751 Times
!/4" drive with an 8mm socket does the trick, as I recall. Also, as mentioned, not too tight! I always mount very snug but allow for some movement in event of a drop or crash. Better to move a bit as opposed to bend a bit (my opinion only).
spondylitis.org
Bikes: '84 Colnago Super; '90 Bridgestone MB-1; '81 Trek 930; '01 Cinelli Supercorsa; '62 Ideor Asso; '87 Tommasini Super Prestige; '13 Lynskey R2300; '84 Serotta Nova Special; '94 Litespeed Catalyst; etc.
Quoted: 121 Post(s)
Liked 97 Times
Thinwall / deep-well metric socket is the way to go there. Hopefully you have access to a few of those. They're harder to get, now that Craftsman tools are made in the PRC.
Quoted: 4722 Post(s)
Liked 3,036 Times
It requires an 8mm socket. My socket fits nicely. It's thin wall and slightly necked to a 12.0 mm outer diameter. The larger end, which is 12.5mm, won't fit inside the lever.
Some "all-in-one" screwdrivers will fit over those nuts if you take the bit out of them.
Quoted: 5888 Post(s)
Liked 3,471 Times
A campy T wrench (8 mm socket) works nicely on these. I'm pretty sure that the dia compe cane creek hoods will work well on these as well.
Stop reading my posts!
Quoted: 1443 Post(s)
Liked 1,062 Times
I use a nut driver, I like that it's a hollow shaft (not so important for this job) and the handle stays attached. A full metric set was cheap at the "emporium of cheapness" Harbor Freight. Cheap drivers but still they have worked for me over many years.
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Likes For BFisher:
Mr. Anachronism
Quoted: 526 Post(s)
Liked 256 Times
12-point sockets are usually thinner than 6-point. I rarely use 12-point, unless I come across a situation like this.
Bikes: many
Quoted: 1444 Post(s)
Liked 1,392 Times
My first gen D-A levers take an 8mm socket. It was tight enough that I ground down a cheap socket which is generally dedicated to that task now.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3886 Post(s)
Liked 6,481 Times
I just ran into this issue with some Shimano 600 brake levers. Used a regular walled socket to remove it. Took a really long time, but my parents were visiting, and it gave me something "busy" to do while they were here. When I was ready to remount them, I used a fat washer on each side, so the nut would be more easily accessed. The washers I found were similar to those threaded nuts bundled with new presta tubes, but they just slipped on. Threading them on would have spelled disaster. It worked and they were simple to tighten with the same nuts and socket.
