SSCX: what singlespeed gear ratio for cyclocross racing?
I have a motobecane fantom cross uno with a 20T rear freewheel. I currently have a 38T chainring that I feel will be too low for a typical cyclocross race. What size should I upgrade to?
Oh, and I've never raced cyclocross before, I use mine primarily on fire roads but I'd like to convert it to something I can race with.
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,862 Times
I think 38x20 sounds about right, depending on the course, especially if you're new to CX racing.
I raced singlespeed a couple of times last year with a 38x18 setup. On two completely flat courses, that was about right for me. On one mildly hilly course it nearly killed me.
Bikes: jamis xenith comp '08, trek 750 hybrid (w/drops) c.1995, centurian fixie, kona cindercone mtb c.2000
When researching the same question I found that a 2:1 ratio was popular.
I did 3 training rides and ended up with a 36x18 and found myself wishing for a 34.
good luck
good luck
I guess it depends on your course. I've only done two races singlespeed and used around 63 gear inches, 39 x 17. Seemed about right, especially on the flatter and faster of the two courses. I brought an 18t cog each day to swap if needed, but didn't. It also would depend on how fast you can comfortably spin or how competitive you are. I'm more of a masher and was trying to at least be kind of competitive against people with gears so I didn't want to go too low. I think 55 gear inches would be as low as I would consider, and it would have to be a supper muddy, techy course to go that low. For me. I absolutely had to do a fair amount of standing out of corners, but that's fine for me, especially in a 45 minute race.
It will definitely depend on if you like to spin faster or mash a harder gear, as well as your fitness. 39x20 seems to work for me when hills are involved, 39x18 if it's pancake flat.
n00b
Bikes: Surly Karate Monkey, Twin Six Standard Rando
Quoted: 428 Post(s)
Liked 466 Times
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
SS gearing is such a personal choice that it can be hard to give advise on. I use between a 38 to 42 chainring and from 16 to 18 on the rear. So far so good.
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
Bikes: 2010 Niner EMD, 2008 Surly Steamroller, 2007 Giant OCR.
From my experience a lot of people start with a 2:1 ratio and change it from there. I use a 36:16 and find it to be a great combination. Can get up basically all hills and never spin out on the flats.
Did I catch a niner?
Bikes: Vassago Fisticuff/Surly Ogre/Surly Pugsley/Surly Pugsley 29+
Quoted: 9 Post(s)
A shop owner who has won the SSWC and does SSCX suggested 39x17 (which he runs) most of the time here.
Bikes: Yes
Liked 3,862 Times
edit: also, depending on tire size, we may be even closer than 1.1 gi. i am currently on 700x30s so i am actually a little less than 63
Bikes: Yes
Liked 3,862 Times
For fun/commuting 42-18 is definitely no problem (unless you're riding fixed and skidding). I used that exact combination yesterday for my commute. It might even be a bit low for that kind of riding. The thing is, you need much lower gearing for CX than for riding around the streets. The difference is dramatic enough that you really need to change parts. IMO, swapping in a smaller chainring is probably better than changing the freewheel, because it makes for a bigger changes.
i find 42x16 w/ 700x23 tires is best for fixed riding/fast commuting
i am expecting i will need lower gearing than 42x18 but the two cross racers above use 39x17 and 42x16. 42x16 is much higher than what i have and 39x17 is very close. what i have may not be optimal, but it cant be too far off given the success of the two racers above.
you have that backwards, swapping freewheels makes a bigger difference. one tooth on the back is WAY more than one tooth on the front.
Bikes: Yes
Liked 3,862 Times
42-18 should be a good place to start for general riding around with mixed dirt/road. Really you can analyze this stuff over and over but gear ratios depend on a lot of things and it's best to just get some ride time in on the courses or rides you'll be doing and go from there.
well i ran into a new campagnolo 39t ring for $15 so i bought it to give me a second option. in the process i discovered and interesting setup. i fully expect that some may laugh:
now for the explication. my rear hub is a white industries eno.
fixed chain line = 43mm
ss chain line = 47.4mm
this gives me a 42x16 fixed for road riding and a 39x18 for cross riding and a close chain length for each. funny looking yes, but great flexibility for $15
correct. 42x16 fixed, 39x18 single speed. it would look more traditional with the 42 on the outside but that is not conducive the the chain line on the hub (unless you want to ride fixed off road)
the chain will be protecting the outer ring when i am off road. the inner ring will be used for fixed road riding. it is not like there are derailleurs involved. this is a traditional turn the back wheel around setup.
