Go Back  Bike Forums > The Racer's Forum > Track Cycling: Velodrome Racing and Training Area
Ask your small, random, track-related questions here
Track Cycling: Velodrome Racing and Training Area Looking to enter into the realm of track racing? Want to share your experiences and tactics for riding on a velodrome? The Track Cycling forums is for you! Come in and discuss training/racing, equipment, and current track cycling events.
Old 02-22-16, 08:14 PM
  #3276
Koogar
Koogar's Avatar
Quoted: 27 Post(s)
Originally Posted by queerpunk
The Langster Pro is a decent bike, even considering the fact that it doesn't have sprint geometry.
Originally Posted by Hida Yanra
.... you know, I can't name anything wrong with them at all, other than "the geo is traditional track geo" - Those bikes can go fast, they can Madison, they can move up and down track on steep tracks with no problems I've ever seen..... dunno.
I used to ride a Felt TK2, which has traditional sprint geometry, and I actually hated how it responded sometimes. I wouldn't really be able to describe it - it's been a few years - but while I liked the nimbleness of a steep headtube there was something else I didn't like.
When I replaced the TK2 with a Langster Pro, the LP's 73deg headtube and 45mm fork struck me as "not right" - even though the trail measurement winds up being a totally reasonable number, like 56 or 57 IIRC.
I really believe that a lot of geometry has probably been pretty well refined by trial and error over the last century or so, but there's also a lot of recycled "wisdom" out there for which there's no clear basis. Unfortunately, there's also often no agreement about what falls into either category. Moreover, "optimal" depends on use case.
This is relevant to a project Colby Pearce and I are undertaking. We've been frustrated by the handling of certain frames and the relative dearth of definitive information on what works best for track. So, we're going to build a number of frames, for which we'll vary the geometry in a controlled fashion, set them up identically, and then go ride test and race them. Full disclosure, this is a commercial endeavor, but as an additional output I hope to be able to answer some of these questions in a data-based way soon.
Koogar is offline
Old 02-22-16, 08:28 PM
  #3277
Hida Yanra
VeloSIRraptor
Quoted: 22 Post(s)
Originally Posted by carleton
Remember the post that started this:
now on that point - generally agree.
A bunch (eg, more than 3) early gen PlanetX track bikes at Marymoor just got "mushy" - noticible flex in the way they rode after a few years. No one had any good explaination for it- even the Boeing carbon guys out there - but it wasn't imaginary either. The later ones didn't seem to have that problem, but the conversation reminds me of it.
Yeah- unless medals and fancy-shirts are in the balance, |a currently functional track bike > a bike that isn't free|
Hida Yanra is offline
Old 02-22-16, 08:30 PM
  #3278
Hida Yanra
VeloSIRraptor
Quoted: 22 Post(s)
Well hello there!
Can we get an introduction, or any further details?
So many questions:
I assume steel- as it is the easiest/fastest material to work with on a "one-off" basis?
Old 02-22-16, 08:51 PM
  #3279
wens
wens's Avatar
Hmm, I had a boss who did military carbon fiber stuff and talked about delamination causing stiffness to drop over time. Probably not usually a problem for bikes though, since you're usually designing to stiffness rather than stress.
wens is offline
Old 02-22-16, 09:13 PM
  #3280
Hida Yanra
VeloSIRraptor
Quoted: 22 Post(s)
yup - and given a normal sort of layup sched+epoxy distribution, it wouldn't make sense for the frames to be experiencing the drop in stiffness about 2 years after manufacture.
Especially given that they are track bikes used on an outdoor track, that's just not a meaningful number of cycles to start talking about flex-based delam of materials.
Old 02-22-16, 09:50 PM
  #3281
Koogar
Koogar's Avatar
Quoted: 27 Post(s)
Well hello there!
So many questions:
Sure, happy to share to the extent I can do so based on the early R&D stage and the forum rules related to commercial advertising. Colby and I have known each other for a few years and we share a frustration with the available frame offerings out there - he from the perspective of a coach and fitter, I as a rider. We also realized that we were thinking along the same lines as to how we'd do stock frame sizing differently to fit more people and their event-specific needs, and what traditional wisdom about geometry we want to test.
Both the prototypes and production frames will be 7000 series aluminum. I've got tube sets on order for the first five prototypes and am having a custom dropout designed. The website isn't up yet, but when it is, there will be a lot more detail on the design philosophy, geo and sizing, and Colby's thoughts on fitting a track bike. The company is Fifty Point One Racing.
Koogar is offline
Old 02-22-16, 10:22 PM
  #3282
700wheel
Quoted: 144 Post(s)
Liked 14 Times in 11 Posts
I worked in aerospace which built a lot of carbon epoxy structures, some needing to last for decades in high stress, and often high stiffness, applications. All were fabricated and cured using an autoclave (high pressure and temperature). Some delamination was found during inspection and those parts either repaired or scrapped. Never experienced delamination in service.
I do not know the process used for bike frames so they may not be as sophisticated as those used for aircraft parts. Some epoxies absorb moisture so that might be a reason for the bikes becoming "mushy". I also wonder if sunlight can cause deterioration in carbon frames.
700wheel is offline
Old 02-23-16, 07:12 AM
  #3283
MrMinty
Bikes: Cannondale Caad8, Claud Butler Roubaix, Raleigh Equipe
Quoted: 14 Post(s)
A key indicator is muscle fiber type. Generally, your muscle fiber type percentages does not change over time. So if you were predisposed to being an endurance athlete as a kid, you'll likely be the same as an adult. Same for sprinters.
High school athletics are a good testing ground for muscle fiber time because most schools have the students doing all kinds of sports that involve everything from short bursts of speed (100M dash) to long events (1 mile run). And the sample sizes are relatively large (LOTS of kids in the school doing the same things), so if you are above average in something there, this is good.
If you were in fair shape, your performance, likes, and dislikes of these events will lend a valuable clues to your muscle fiber type percentage. In layman's terms: TALENT
So...
If you were a "sprinter" in high school track and field or were above average in sports that use fast-twitch muscles or lots of power, then you will probably lean towards being better at sprint events because you have a higher percentage of "fast twitch" muscles.
If you were an "long distance" runner in high school track and field (events 1 mile /1,600m or longer) then you will likely be better at endurance events because you have a higher percentage of fatigue-resistance "slow twitch" muscles.
If you were best at "middle distance" events like the 800M or you didn't particularly excel in sprint or long events, then you may be an all-around racer or simply above-average across the board.
Haha and if you did nothing? I literally did no competitive sports from aged 11- when i picked up a bike again at 21. Good thing is, I never really put on any weight in that time, so I guess I'm more at the ectomorph end of the scale. That being said, now I'm eating healthy and going to the gym, I'm putting on lean muscle, especially in the legs.
I guess the only way to know is to go try all the events I can! I think the kilo can be a good one though.
There's plenty of scope in my track league. Actually- there's 2 which are both around an hours drive away. One tends to do more endurance races, and the other has sprint events too, so I can mix and match or alternate between a sprint week and an endurance week
MrMinty is offline
Old 02-23-16, 07:33 AM
  #3284
Banchad
Bikes: Planet X Pro Carbon, Dolan FXE, Fuji Transonic
Quoted: 5 Post(s)
Why do we use gear-inches developed instead of gear ratio?
Banchad is offline
Old 02-23-16, 07:56 AM
  #3285
dunderhi
dunderhi's Avatar
Bikes: Little Wing, XTRACK, Electron Pro, SuperCorsa, Paramount, & Thunderdrome
Quoted: 69 Post(s)
Liked 3 Times in 2 Posts
IIRC, it's just inches and it goes back to high wheel bikes where each rotation of the pedals produced X numbers of inches of travel. High wheel bikes had many different wheel diameters, so inches of travel was a good way to compare.
Here's the starting grid for a local high wheel race. Greg Lemond is the 4th rider from the front.
File Type: jpg
dunderhi is offline
Old 02-23-16, 07:57 AM
  #3286
Trackliche
Because it sounds way more awesome to say "ninety eight" than "forty eight thirteen". Helps weed out the roadies.
But for real, I think it stems from the early Penny Farthing-style bikes: the pedals were directly connected to the front wheel, so the "inches developed" was just the diameter of the front wheel. The manly men racing those bikes would compare dic er. . . wheel sizes in inches developed. It stuck.
TC
Trackliche is offline
Old 02-23-16, 10:18 AM
  #3287
dunderhi
dunderhi's Avatar
Quoted: 69 Post(s)
TC
Your memory is better than mine, I think it was the wheel diameter.
dunderhi is offline
Old 02-23-16, 10:48 AM
  #3288
Banchad
Quoted: 5 Post(s)
Thanks for clearing that up for me guys. I was always confused as I'm only relatively new to bikes and I've only ever had to deal with 700c wheels and couldn't understand as to why literal ratios (52/16=3.25, 48/15= 3.87) weren't used as a measure of gear magnitude.
Banchad is offline
Old 02-23-16, 11:21 AM
  #3289
tonski
Bikes: Ritte 8055, Felt TK3, Cervelo S2 & P3, Giant TCR
Carleton likes to do 650's
tonski is offline
Old 02-23-16, 11:32 AM
  #3290
queerpunk
aka mattio
queerpunk's Avatar
Bikes: yes
Quoted: 344 Post(s)
Liked 58 Times in 35 Posts
thanks for sharing this info! when you're ready, i'd love to hear even more and more - some of the specific sizing and geo things you're testing, what the test protocol is, and what you find. whatever isn't proprietary/close-to-the-chest info.
queerpunk is offline
Old 02-23-16, 12:16 PM
  #3291
Koogar
Koogar's Avatar
Quoted: 27 Post(s)
Sure, we'll be very transparent about what we're working on, as the whole project is meant to be frame designs driven by elite athlete / coach / fitter feeback and real world testing. So sharing our findings is part of substantiating our design choices. Both of us feel that it isn't worth putting another frame into the market unless it addresses the shortcomings of the stuff already out there and works better for riders' needs - we're creating a brand because we want great track frames, not making track frames to fill out a brand's offerings.
I'm currently spending the most time on getting a custom dropout designed and manufactured to test on the prototypes, and working to set up frame production in the US. As we start prototype testing, we plan to post the latest to the website. That, however, has taken a backseat to getting the prototypes made.
If there are questions or asks for the product, I'm happy to take them here!
Koogar is offline
Old 02-23-16, 12:50 PM
  #3292
carleton
Elitist
carleton's Avatar
Quoted: 1386 Post(s)
Liked 92 Times in 77 Posts
Yes, you'll have to race them all and see what suits you.
carleton is offline
  #3293
carleton
Elitist
carleton's Avatar
There's an app for that
carleton is offline
Old 02-23-16, 01:32 PM
  #3294
tonski
Is it out already? What's the name?
tonski is offline
Old 02-25-16, 03:05 PM
  #3295
petereps
I have a question about what I think is called "pulling a wheel".
I'm new to track, and am on a cheap "Pure Fix" track frame that I know is hardly good enough for the track, but I do have friends who race this frame in Cat 3 on the track and do fine. I do however have good components (Sram omnium, ultegra pedals, paul hubs, etc). Yesterday was my first time doing standing start sprints, and on the first go, when I put out my max power the drive side of the rear axle slipped and the wheel jammed in to the seat stays and I screeched to a stop. I thought perhaps I just didn't tighten the axle nut enough, so I realigned/tensioned the wheel and then cranked down the nut as hard as I reasonable could. Next go, I got about 100m into the sprint and then the same thing happened. I luckily was able to keep upright, but am now very hesitant to ride this bike again, as the thought of this happening again is always on my mind. I was told that chain tensioners would remedy this problem, but am still not sure if I possibly just have a POS bike. My main question is, can I rest easy if I install chain tensioners? Or could this be a wheel/frame problem?
petereps is offline
Old 02-25-16, 03:19 PM
  #3296
Koogar
Koogar's Avatar
Quoted: 27 Post(s)
Originally Posted by petereps
I have a question about what I think is called "pulling a wheel". My main question is, can I rest easy if I install chain tensioners? Or could this be a wheel/frame problem?
Yes, that's pulling a wheel. The problem is most likely a too slippery dropout, though bad nuts could be contributing. Sometimes the problem will go away as the dropout gets roughed up from repeated gear changes.
A chain tensioner on the drive side will keep the wheel from pulling forward, but the the add-on type is a bit of pain to deal with and may or may not fit your frame.
What kind of dropouts do you have, the ones with an insert bolted in? Those are notorious for slippage.
Koogar is offline
Old 02-25-16, 03:29 PM
  #3297
carleton
Elitist
carleton's Avatar
If you have allen-bolt hubs like these:
Then that's probably your problem.
Those don't apply as much torque as you would get with a15mm nut like these:
Paul hubs are nice looking, but some inexpensive Formula hubs would probably solve your slipping problem.
Can you borrow a wheel from a friend to test?
If you test and the standard track wheel still slips, then it's your dropouts as Koogar suggests.
carleton is offline
Old 02-25-16, 05:50 PM
  #3298
petereps
Thanks for the help guys. I think the dropouts are the insert type. And yea I have the allen bolt hubs. Don't really have anyone I can borrow a wheel from to test if it's slippery dropouts or the bolt. A chain tensioner seems to be the cheapest fix, would having chain tensioners on both sides of the dropout garauntee I won't pull a wheel? Really just looking for a fool-proof solution as I'm a bit hesitant to put out a full sprint due to fear of my wheel slipping again.
petereps is offline
Old 02-25-16, 06:06 PM
  #3299
Koogar
Koogar's Avatar
Quoted: 27 Post(s)
Looks like Carleton called it. However, if your dropout inserts are nice and shiny, they certainly aren't helping. You only need a tensioner on the drive side to keep the wheel from slipping.
Koogar is offline
Old 02-25-16, 07:35 PM
  #3300
wens
wens's Avatar
If you can get someone to run alongside you to catch you, and your other side against a wall or railing, if you don't pull a wheel in the first few pedal strikes of a full gas standing start, you shouldn't pull it at all. Somebody can keep up for a few pedal strokes and catch you if you do pull your wheel. Chain tensioner is probably the easy/cheap solution though .
wens is offline
