Where to buy 27mm JIS race for mah bike?
Old 02-04-20, 07:37 AM
LBCwanabe
Quoted: 33 Post(s)
Liked 82 Times in 39 Posts
For a 92 Stumpjumper
thanks!
LBCwanabe is offline
Old 02-04-20, 07:46 AM
'02 nrs
royaloaker
'02 nrs's Avatar
Bikes: 1938 claud butler,1983 Basso,teledyne titan,teocali super,nrs,1993 stumpjumper fsr,Paramountain,Paramount Buell,4 banger,Zaskar LE,Colnago Master Ibex MTB,1987ish,.etc....
Quoted: 72 Post(s)
Liked 63 Times in 35 Posts
Cage looks ok, try local hardware for bearings?
'02 nrs is offline
Old 02-04-20, 07:57 AM
bikemig
bikemig's Avatar
Quoted: 4386 Post(s)
Liked 652 Times in 479 Posts
Run the bearings loose or reuse the cage. Get grade 25 bearings, you can find them on amazon
bikemig is online now
Old 02-04-20, 09:38 AM
LBCwanabe
Quoted: 33 Post(s)
itís warped bad. I wasnít sure Iíd bend it back is an option
Old 02-04-20, 12:42 PM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 2076 Post(s)
Liked 426 Times in 302 Posts
Are you concerned about the crown race, or the bearing retainer? Your subject line mentions one, your picture shows the other.
As others have noted above, replacement retainers are readily available from any bike shop, or you can press new balls into the old retainer, or you can run the balls loose, without a retainer. If you run them loose, usually one more ball can be added above the number held by the retainer.
If you're concerned about the crown race, again, your local bike shop can get one for you, or you can buy them from e.g. Amazon or eBay. If you're just replacing the race, you need to check that it will mate properly with the cup in the frame. The easiest way to ensure that is to get a crown race of the same make and model as the rest of the headset. If you can't find a match, you can replace both the cup and crown race with a matched set from another headset, with the caveat that you want the stack to be the same or lower than the original parts.
JohnDThompson is offline
Old 02-04-20, 02:32 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds.
Quoted: 966 Post(s)
Liked 177 Times in 138 Posts
Terminology is important-
https://www.huskybicycles.com/bearin...-one-pair.html
appears to be your retainer, going by 20x balls.
Order 100 pack of new bearing balls.
Having way more than you need should help prevent the need from reoccurring. (Murphy's....)
I normally don't use a retainer except head sets. It's easier than catching balls on disassembly.
I don't think I've ever had need to disassemble a headset that I've serviced, though.
Bill Kapaun is online now
Old 02-04-20, 04:23 PM
AnkleWork
Bikes: old clunker
Quoted: 684 Post(s)
Liked 96 Times in 74 Posts
Shoppin' ain' easy when you don't know what you want.
AnkleWork is offline
Old 02-04-20, 08:46 PM
LBCwanabe
Quoted: 33 Post(s)
Nm smh fixed
Likes For LBCwanabe:
