Brake Sensing Taillights - Useful Feature or Gimmick?
Craigslist Addict
Bikes: Zipp 2001, Specialized Roubaix, Felt FA
Quoted: 7 Post(s)
I'm curious what people's thoughts are on brake sensing bike tail lights. They seem to becoming more popular even on lower cost tail lights, but I'm still undecided if they are useful features or just a marketing gimmick.
I've used two lights that have the feature, Magicshine Seemee 60 and the Lupine Rotlicht. Both lights seem to implement them differently though: Magichshine switches to a high power flashing mode while Lupine goes to a high power solid mode.
CONS
CONS
- Unpredictable battery life as you are running different modes
- Sensitivity of sensors seems to trigger feature on potholes or bumps
- Less control of mode, which may be a downside when riding in a group
- Improves visibility maybe (any studies to confirm this?)
- Adds some variability to the light output
Quoted: 18349 Post(s)
Liked 4,501 Times
My thoughts on brake lights and turn signals are that they don't help a lot.
If you use flashers, then they would naturally confound sensitivity to other lights.
My goal is to BE SEEN, and I hope drivers react appropriately no matter whether I'm going steady, slowing, or at a stop light.
Perhaps glove lights??? But, I also pay attention to traffic before making sudden changes across traffic lanes.
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
Quoted: 522 Post(s)
Liked 227 Times
Who will interpret what your light means?
This has been discussed here before and fairly recently. The problem as I see it is motorists are not going to interpret your dinky little stop light to mean anything. If you follow the progression of brake lights from antique cars to modern vehicles, they got bigger and bigger, brighter and brighter over the years. The DOT even added a requirement for a third brake light in the center and higher than the regular two brake lights. We know what a brake light means on a vehicle because it is always in the same location and the concept has been in use for about a century.
Likes For VegasTriker:
Bikes: 2018 Roubaix Expert Di2, 2016 Diverge Expert X1
Quoted: 482 Post(s)
Liked 151 Times
I prefer my rear light flashing constantly in the daylight, and on constantly at night. I think that and using a hi-output light will get you noticed the most.
Quoted: 482 Post(s)
Liked 151 Times
Good idea, Or at least a some significantly noticeable change in pattern. Don't know how that would work at night though. Guess brighter like a car would be a good cue for a driver.
Quoted: 3451 Post(s)
Liked 1,451 Times
A friend of mine has a B&M taillight that works a a brake light, he likes it and from what I have seen it works reliably. But, it is a dyno powered light, the brake function is activated when the light senses that the dynohub is slowing, which is a reliable way of knowing if you are slowing down.
Bikes: 1978 Bruce Gordon, 1977 Lippy, 199? Lippy tandem, Bike Friday NWT, 1982 Trek 720, 2012 Rivendell Atlantis, 1983 Bianchi Specialissima?
Quoted: 345 Post(s)
Liked 174 Times
Liked 1,451 Times
I sure reacted, my friend is riding along maybe 8 or 10 feet in front of me, and he says, let me know if my light gets brighter. Then he brakes hard and I had no warning that he was going to jump on the brakes, I almost crashed into him.
Quoted: 7341 Post(s)
Liked 2,438 Times
I think it's a gimmick that could give you a warm fuzzy feeling which might prove to be unjustified. If a motorist is tailgating you close enough that he might crash into you, get out of the way. A taillight isn't the way to keep him away. So the braking feature might even be worse than useless.
Likes For noglider:
Liked 4,501 Times
One thing to consider. When cars are moving 50 MPH, and bikes are moving 10 MPH, the bikes are ALWAYS stopped with respect to the cars.
Moving faster, slower, or actually taking your foot off the pedal really doesn't matter.
If a car can't react to a bike going from slow to slower... then they are following way too close.
Likes For CliffordK:
I agree with Vegastriker that many motorists don't expect a brake light function from a bike It is useful for other bikers, and anyone (even a motorist) who pays attention to the surroundings can notice it (and should connect it with a braking function). IMO: no harm done, but i don't know whether it is always useful.
additional con of the Lupine Rotlicht:
That g sensor is sensitive to rougher bumps as well (and if used on the "high sensitivity" mode, that light is basically all the time in max brightness. It is ok in the lowest sensitivity mode). I use the rotlicht with the pulsing mode (on the second lowest level)
I've seen several designs on patent websites in Canada and USA. Using a logic board limits the choice of materials and functions. I use an analog interface with my bike trailer - four switches on the bike connect via two cables to a wallet card-sized interface board. Any failed part that is obsolete is succeeded by a new circuit board. To date, all original parts in my bike trailer's electrical system are still working, 32 years after I invented it.
