What tools are these?
Car free since 2018
Bikes: Mostly japanese ones
Quoted: 259 Post(s)
Liked 269 Times
Hi
I bought a random box of tools and there are a few I'm not sure what they are. The one on the left I'm not even sure is a bike tool. I'm guessing the one that looks like a T is a tool for the chainring bolts. The one next to it I'm guessing is a key to wind up a toy?
Also, there were some chains included stamped with PC 951 on the links and K8 on some of the links. Would this be usable for my 5-7 speed rear cogs?
Thanks
Thanks
The one on the left is a crank puller--actually a car tool, I believe, but useful for pulling off a crank that has stripped threads so you can't get the normal tool to work. And I'm pretty sure the one on the right is for tightening the cap on a modern BB/crank system like the Shimano Hollowtech stuff.
Likes For Headpost:
Quoted: 964 Post(s)
Liked 1,451 Times
That T-handled thing with the three prongs on the end is likely a chainring bolt driver.
Bikes: 2020 Pivot Vault, 1983 Rossin Record, Garneau R1, Mesamods home built gravel/rain commuter bike, 1995 Barracuda A2V modified with Surley single speed dropouts, 1969 Bottecchia junkyard special fixed gear, Cervelo P4, Mesamods 650b klunker
Quoted: 96 Post(s)
Liked 72 Times
The piece with the green tape is for a Shimano hollowtech II crank preload cap and the Park tool tool is a dummy pedal to turn the crank when no pedals are installed.
Friendship is Magic
Bikes: old ones
Quoted: 26419 Post(s)
Liked 10,380 Times
...back when they were not solid state ignitions, I used to use a three armed puller about that size and configuration to pull the flywheel off my lawnmower engines to access the stuff you needed to service. I guess you could use it to pull other stuff, like on a bike, but I never have because there are other things that work better for me.
Bikes: Litespeed (9); Slingshot (9); Specialized (3); Kestrel (2); Cervelo (1); FELT (1); Trek (2)
Quoted: 436 Post(s)
Liked 3,471 Times
The Park Tool is a hamster restraint device. The veterinarian slips the wire end over the head and behind the ears of an aggressive hamster with sharp chisel-like teeth, and turns the rear disc to tighten the wire gently but firmly around the hamsters neck area. The rigid nature of the tool keeps the business end of the hamster a safe distance away from the good doctor's healing hands and helps control the hamster during a physical examination.
WTB: Slingshot bicycle promotional documents (catalog, pamphlets, etc).
WTB: Bicycle Guide issues 1984 (any); Jun 1987; Jul, Nov/Dec 1992; Apr 1994; 1996 -1998 (any)
Likes For SpeedofLite:
Mr. Anachronism
Quoted: 526 Post(s)
Liked 256 Times
Yes, the tool on the left is a universal puller. I use mine to pull the harmonic balancer off a Chevy V8, but I've also used it to pull a (bicycle) crank that has the extractor threads stripped out.
Car free since 2018
Quoted: 259 Post(s)
Liked 269 Times
Thanks for all the replies guys. There were other tools in the bins but I could make most of them out. What exactly I'm going to do with 6 pedal wrenches, 12 pin spanners, 18 headset wrenches, multiple cone wrenches, 6 bottom bracket lock ring tools, a dozen chains that apparently are 8 or 9 speed so I can't use, and some other bits and pieces I'm not exactly sure just yet.
There was a nice big park tool stand but I didn't think I could fit it in my small car or in my wallet. Unfortunately I didn't see any truing stands or derailleur alignment tools, which I would have wanted. Or maybe I should have looked in that third bin she had for sale. I didn't want to overplay my hand by digging through it and looking too interested. Well, I got what I could get.
Bye.
Quoted: 1639 Post(s)
Liked 829 Times
Usually called a "gear puller" in the auto world....
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Likes For Chombi1:
Quoted: 2338 Post(s)
Liked 2,822 Times
Ah a multi purpose tool. Fantastic. I have a cousin who's a vet I might be able to sell it to her.
Bye.
Bye.
Likes For big chainring:
Quoted: 3810 Post(s)
Liked 6,699 Times
Likes For grizzly59:
Quoted: 436 Post(s)
Liked 3,471 Times
For the Park Tool, the answer is Yes. However, gerbils run a bit smaller than hamsters and the smallest of them can sometimes slip out of the loop.
In those cases it helps to place small diameter polyethylene tube around the loop. A used IV line works well. The smaller gerbils seem to tolerate the loop better and are more calm with this modification.
It's been said the purpose of the threaded end is to serve as the point of attachment for a 12" extension rod to allow its use in human hospital emergency rooms as a gerbil extraction tool.
But I really can't confirm that and, quite frankly, don't believe a single word of it.
I've never checked into VAR, but I bet you're right.
I'm sure CYCLUS would make a very nice one too, but I never looked into them either.
Man, I wish I had saved my responses for April 1.
Quoted: 1608 Post(s)
Liked 2,216 Times
P1000181, on Flickr
verktyg
Quoted: 1036 Post(s)
Liked 1,238 Times
Best Laugh Of The Day
It's been said the purpose of the threaded end is to serve as the point of attachment for a 12" extension rod to allow its use in human hospital emergency rooms as a gerbil extraction tool. But I really can't confirm that and, quite frankly, don't believe a single word of it.
verktyg
Chas. ;-)
Chas. ;-)
