Old Shimano compatibility with new Shimano?
Bikes: A blue one and a white one.
I need to replace a crankset. The groupset on the bike is a mixture of different Shimano, but everything is old. I'm guessing about 25 years old.
The old crankset says "e300x" on the side of it.
If I buy a brand new crankset Shimano FC-345 Compact Crankset is that going to be compatible with the same bottom bracket as well as compatible with the same crankset removal tool?
SE Wis
Quoted: 2740 Post(s)
Liked 3,388 Times
No.
Your old crank uses a square taper interface and the proposed new one is octolink.
3 things to keep in mind with BB. Interface - how the crank mounts on the axle. Spindle length - How long does the axle need to be to clear the frame and give proper chainline. BB/.frame interface - Pressed in, threaded, what thread type, internal bearing external bearing.
That's just the beginning.
The crankset ALWAYS determines what the BB will be. It's not real often when changing crankets that the existing BB can be used.
https://bike.shimano.com/en-EU/produ...0/FC-R345.html
Cool, thank you for that, it was very useful.
I'll go for a Shimano Claris FC-RS200 Crankset 2x8-speed then.
SE Wis
Liked 3,388 Times
the Fc-rs200 shows a 110mm length recommended to produce a 43.5mm chainline.
https://bike.shimano.com/en-EU/produ.../FC-RS200.html
https://www.sheldonbrown.com/bbsize.html
Quoted: 6177 Post(s)
Liked 4,794 Times
You can probably change out the bottom bracket to match what ever crank you want to get. A new bb can be as little a five bucks, depending on what is required for the cranks you get. However you'll have to know more about the bb shell on your frame. Since it sounds like your bb is a cartridge type, you might have a wealth of information written on the side of it if you think you are able to remove it to look at.
As for whoever said the existing is square tapered, then can you expound on that. I see a lot of octolink bb's with "es300" in their description. Though not the "e300x" as the OP mentions. So what's that reference?
So with the old one spindle length is 115mm. (Shimano FC-A300)
And the new one has a spindle length of 110mm.
Is there going to be major problems?
I am assuming this means my feet will just be 5mm closer together and the chainrings will be 2.5mm closer to frame.
Is it still going to work?
Quoted: 1604 Post(s)
Liked 2,569 Times
Really Old Senior Member
You need to look closer at the last link in post 4.
Also look at the various spindle lengths. They are frequently NOT symmetrical.
SE Wis
Liked 3,388 Times
SE Wis
Liked 3,388 Times
SE Wis
Liked 3,388 Times
Unless you own the tools, or don't mind buying tools you may only use once, I'd suggest having a shop replace the BB.
The issue is your existing BB for the EX 300 crank is likely a cup & cone BB. This will require a crank arm remover, a tool for the adjustable cup lock ring, possibly a tool for the adjustable cup, and yet another tool for the fixed cup. The fixed cup will also usually put up a fight, sometimes a considerable fight, coming out.
The new BB will be a cartridge type which will require yet a different tool for installation.
All told the parts will be less than the tools to do the work.
Liked 4,794 Times
With their guidance, you wouldn't be sweating or questioning what you have and need.
