#2201
Thought I had the downtube shifters done.....the originals were missing bits so I went with some Huret ones I had in the drawer. Turns out, they look great but lack function. So I got looking at the og set and think I can piece them back to life. The brakes though, work great after refresh.
Likes For Kdogbikes:
#2202
Shifting is fun!
Bikes: Yes, please.
Quoted: 2193 Post(s)
Liked 4,586 Times
Upgraded mrs non-fixie's DeVos by adding a set of matching off-white Milremo fenders that I found at a jumble sale for €5. Aligning them with the wheels is a bit of a challenge, as you can see, but luckily the owner is not as OCD as I am :
Likes For non-fixie:
#2203
Shifting is fun!
Bikes: Yes, please.
Liked 4,586 Times
Damn it. I stripped out the extractor threads from the drive side crank on my McLean. I don't mind ruining it, as the operation was to replace the cranks, but this is going to be difficult. I'll look for one of those three-arm gear pullers.
While I had the bike apart, I cleaned it a bit. It is not enjoying life in a barn. I have to take it apart and de-rust and grease every damned nut and bolt. The front brake caliper had one arm seize to the center bolt. I overhauled the whole caliper and brought it back to life. It's an old Campagnolo Record single pivot caliper. Well made indeed. I brushed the pieces with a brass wire brush and added grease. I love having a bench vise.
#2204
Overdoing projects
Quoted: 784 Post(s)
Liked 1,237 Times
#2205
Quoted: 1324 Post(s)
Liked 927 Times
I was looking for an Eddy Merckx quote about upgrading a bike and came across this quote by Michelle Pfeiffer.
“I relax by taking my bicycle apart and putting it back together again.” — Michelle Pfeiffer
That sure does apply to me. I love wrenching on my bike or components and restoring them to like new or tailoring the bike to my needs/wants. Next up will be my new to me Campagnolo Clipless Pedals that arrived in the post today.
Cheers
Cheers
Likes For Miele Man:
#2206
Edumacator
Quoted: 2434 Post(s)
Liked 3,107 Times
Cheers
Cheers
#2208
Quoted: 796 Post(s)
Liked 522 Times
Well its finally done, I guess I can get a Cigar now, The 420 is now on CL
Likes For ryansu:
#2209
Quoted: 7345 Post(s)
Liked 2,452 Times
Really fine, @ryansu.
I guess I should take comfort that after 40 years of wrenching and giving and taking advice about stripping the crank threads, this was the first time it happened to me. Oh well. Getting the right cranks and front derailleur on this bike has presented a whole host of challenges.
Likes For noglider:
#2210
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3869 Post(s)
Liked 6,455 Times
Picked up this Bertoni today. Was gonna part-out, 'cause I thought it was a 59cm, but it's more my size (ugh) at 57cm.
Lots of work ahead...
Likes For SurferRosa:
#2211
Rustbelt Rider
Quoted: 261 Post(s)
Liked 372 Times
I like the way you seem to clean everything...I normally do a quick wipe and assemble.
I may take the queue and clean and polish this next build.
I have been collecting stuff for a while and will create a new thread asking which one I should start and finish ove the winter...I like the floor like everyone else!
Ben
Ben
Ben
Ben
#2212
Quoted: 101 Post(s)
Liked 49 Times
Time to overhaul/clean/re-grease the Gios A70. The head tube races look great after cleaning so I put the press on them for good measure. I discovered a crack in the Campagnolo Record 9 speed RD. Bummer! Now I have to find another. At least it was found now instead of out on the road!
#2213
Rustbelt Rider
Quoted: 261 Post(s)
Liked 372 Times
Worked on the Melton a bit more today. I’m mostly waiting on rim tape, tubes and tires to show up now.
Likes For mkeller234:
#2214
Quoted: 227 Post(s)
Liked 388 Times
Im waiting on a few parts in the post so played with this old x2000. Went a bit hard on the name plate but there was tin worm under there too.
I wish I took before pics of the Shimano A20 I'm going to use, was way worse than this but came up much better.
#2216
Edumacator
Liked 3,107 Times
I might have one (Record 9), but if I recall it is slightly in need of things. One pulley was loose and the mounting bolt felt a bit loose, but no cracks. Let me know and I will look for it.
Likes For Mr. 66:
#2218
Edumacator
Liked 3,107 Times
Likes For jdawginsc:
#2220
Edumacator
Liked 3,107 Times
#2221
Quoted: 796 Post(s)
Liked 522 Times
My clunker challenge, Trek 520 was jealous of all the attention the Trek 420 was getting as I prepped it for sale. So today I spent about an hour on the 520, not the spa treatment it will get in the winter more of a strip mall cut rate Mani/Pedi : swapped the pedals, took off the fraying Kenda tires and put on some Panaracer Pasela's, new saddle as I used the stock Vetta on the 420 and I was able to put on the new Nitto stem and bars while preserving the current levers and brake cables and housing. Then it was test ride time.
clunker challenge 520 minus the Vetta saddle I used on a 420 rebuild
MKS sneakers to replace no name stamped steel
VO touring - needs breaking in
Nitto technomic stem and wider bars
A shake down on Alki
Likes For VtwinVince:
#2223
Quoted: 1199 Post(s)
Liked 1,354 Times
Getting my 95' Ttofeo ready for Rosarito/Ensenada bike ride.
Changed the Prologo saddle to Concor and added an Axiom RushAir 160.
#2224
Quoted: 3349 Post(s)
Liked 3,610 Times
Well, looks like my rear 600EX hub is dead.
Both the driveside cup and cone look about the same. I looked around a bit on eBay but I'm not sure if it's with rebuilding.
Thankfully I have another set of 650b wheels in the garage, but they are spaced at 135. So in the interest of frugality, looks like the big old Trek is going wide
#2225
Liked 3,610 Times
