Shimano Crank
Shimano Crank
Looking to upgrade from stock Oval crankset to a Shimano 105 r7000. My bracket is from Praxis and my cassette is Shimano 105 cs5800. Can anyone tell me if I need to buy a different bracket or cassette. Any info will be appreciated. Thank you.
Quoted: 850 Post(s)
Liked 344 Times
My praxis crank (and probably your oval crank as well) used an M30 spindle. So your BB is M30 as well (but you should double check). According to praxis, you cannot modify a M30 BB to Hollowtech II. You will need to buy a Hollowtech II BB. Praxis makes one but you don’t need to get it from them. Any Hollowtech II BB will work as long as it fits your frame.
Quoted: 276 Post(s)
Liked 6 Times
For what it's worth, I don't think that is much of an upgrade. Assuming you have Oval cranks with m30 Praxis rings then the weight is maybe 40-50 gram saving. Praxis rings are great and will be as stiff and shift as well as Shimano. So the "upgrade" to R7000 would be mostly aesthetic unless you are also changing chain ring sizes .
Quoted: 850 Post(s)
Liked 344 Times
That being said, I'm fairly certain my bike was damaged or defective due to an overly soft FD hanger, so that could have something to do with it as well. All I know is that going to the R7000 crank solved my issue.
zpl
Bicycle Mechanics
6
08-16-19 01:21 PM
DayTrick
Bicycle Mechanics
13
01-27-12 11:14 AM
