Advice on buying bike for commuting
Old 07-22-19, 10:31 AM
terrymorse
climber has-been
terrymorse's Avatar
Quoted: 3432 Post(s)
Liked 3,567 Times in 1,793 Posts
Originally Posted by Blu3b3ar
Thanks for the response! I ... decided a 52 cm would be a better fit.
Terry's approximate rule for selecting a road bike frame size:
1. Take your height in inches.
2. Subtract 14 from that number.
3. The resulting number is your frame size in centimeters.
4. Pick a frame size that's closest to that number.
Cyclist mean Height vs Frame Size - Road Bikes
Ride, Rest, Repeat. ROUVY: terrymorse
terrymorse is offline
Old 07-22-19, 10:57 AM
RubeRad
Keepin it Wheel
RubeRad's Avatar
Quoted: 26 Post(s)
Liked 3,433 Times in 2,540 Posts
Convenient rule of thumb. At a hair under 6', that puts me on a 58. Which is certainly doable, but I prefer to stretch out on a 60 and have (as Riv/GP recommends) just a 'fistful of seatpost'. So I guess the rule of thumb I use would be height-12.
RubeRad is offline
Old 07-22-19, 02:55 PM
jade408
Bikes: Working on replacing my stolen Soma Buena Vista Mixte
Quoted: 417 Post(s)
Liked 95 Times in 44 Posts
I think this rule is decent. But I am 5'4" and anywhere between 49-52 can be the right size for me. Sometimes the smaller frame has a cramped cockpit or way too much toe overlap.
jade408 is offline
Old 07-22-19, 02:56 PM
jade408
Quoted: 417 Post(s)
Originally Posted by tim24k
I to commute twenty miles a day. I like touring bikes with steel frames also I run 1.50 tires. As we have a lot of chip seal roads here. Touring frames are comfortable, the steel frames soak up the vibration of the chip seal, and the 1.50 are a good compromise of speed and comfort.
I rode on 1.5 on my last bike. This new one as 1.75 and it is awesome, 2 rides in. I don't think I want to go back to "only" 1.5. My roads are terrible. In some places, the "smooth" pavement is worse than gravel.
jade408 is offline
Old 07-22-19, 03:44 PM
RubeRad
Keepin it Wheel
RubeRad's Avatar
Quoted: 26 Post(s)
Sounds like, to avoid a cramped cockpit, you also prefer height-12 (64" - 12 = 52)
RubeRad is offline
Old 07-23-19, 02:44 AM
tim24k
Bikes: To many to list. I like them all!
Quoted: 60 Post(s)
Liked 43 Times in 32 Posts
I agree if you ride mostly on badly broken up and some gravel roads 1.75” is better. On my Surley LHT I have Schwalbe Marathon Supreme 1.75” that work well in hard packed gravel roads. I also run 2.0” and up Schwalbe Big Apples on deeper gravel and on a tandem.
tim24k is offline
Old 07-23-19, 07:09 AM
BobbyG
BobbyG's Avatar
Quoted: 1364 Post(s)
Liked 1,678 Times in 827 Posts
Check with your local bike shops for pre-owned or reconditioned bikes. They will have been "gone over" by bike mechanics and they often come with some type of short warranty, and sometimes you can return or exchange it if it isn't quite right.
BobbyG is offline
Old 07-23-19, 07:29 AM
wphamilton
wphamilton's Avatar
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times in 228 Posts
When I began, knowing almost nothing about bikes, I followed the general advice and called every bike shop in the area. None of them had a used bike, period. That avenue did not exist. Looking at Craig's list I couldn't tell trash from a gem, except that anything that I saw as a "good prospect" was snapped up long before I contacted them. I realized that the time necessary to research each bike, and to constantly monitor CL for fresh listings, was a greater loss than possibly paying more. So I purchased an inexpensive bike online.
Since you (@Blu3b3ar) have a bike and bike home from work you're probably ahead of where I was. You might post links to CL ads here and some of the knowledgeable members can tell you instantly if the bike is worth the price. But you know more or less what you want - I'd say don't waste time and just pick an inexpensive, new entry level bike.
FWIW I wouldn't spend $500 on an old 2008 Fuji. Maybe $200, if it was in great condition and I was in a hurry.
wphamilton is offline
Steely Dan
Commuting
55
02-23-18 04:59 AM
SnareSide
Commuting
52
01-05-16 05:41 PM
pamaguahiker
Commuting
8
08-18-12 07:23 PM
