Hike and bike footwear for long distance riders?
Quoted: 3459 Post(s)
Liked 1,465 Times
I really have to disagree with you on this one. Cleat bolts are notorious for loosening after initial tightening. I've been on top of mine with sone loosening over the years, but toured once with someone whose one bolt came out, and couldn't release his shoe then. We luckily found the bolt on the ground, and I was able to undo the second loose bolt somehow, but now we had the cleat in the pedal.
luckily I could borrow some pliers from a store and get it out, and was able to then reinstall the cleat to shoe, threads not too damaged luckily.
So it worked out, but with lots of luck.
I also have one cleat slightly turned askew, I've got a funny knee, so don't like the idea of repositioning it again.
I'm picky about all fine adjustments on my bike, seat height, seat position, so never want to change things once sweet spot is achieved. Long hard days in the saddle on a heavy touring bike require everything just right.
anyway, the bolt loosening factor is a real one, but yes it would be nice not to have cleats grating on rocks, I get it.
The plastic sole of the she will deform to the shape of the cleat, then the cleat is not pressing against the sole as hard and the bolts become looser. I have generally tried to remember to tighten my cleat bolts frequently after getting a new pair of shoes, they loosen rapidly at first as the sole deforms, and annually in spring on every pair of shoes every year. Carry cleat bolts with my spare bolts, on some of my bikes I have a spare cleat bolt in an unused threaded point on the frame. Two of my bikes have a tab for a bottle dynamo which I do not use, those tabs have two M5 threded holes, in each of those bikes I have a spare cleat bolt in one of the threaded holes. And after losing a cleat bolt a couple years ago I decided to use a thread locker on my cleat bolts.
A friend of mine quit using cleated shoes for touring, switched to toe clips so he only needed one pair of shoes on a tour. Then he started having foot problems from riding for too many consecutive days with wet shoes, which meant we had to sit in a campground for a day because of his foot problems. Yeah, a second pair of shoes takes a lot of odd shaped space in the luggage, but I always bring a pair of cycle shoes AND a pair of hiking shoes. And shoe covers for rain. There have been some days when I rode with my hiking shoes for a day on the bike to dry out my wet cycling shoes.
After three days of rain on GAP and C&O, my cycling shoes finally had a day to dry out while I rode with my hiking shoes on a sunny day.
I wear Shimano M089L SPD shoes and they work well on and off the bike. I’ve done some hiking in them and while bit great for scrambling over rocks they are just fine for trails and walking around town. Once the riding is done for the day I take them off to air out and I wear a pair of Kung fu shoes. These take up very little room in my bags are are good for the campsite and pavements
https://www.amazon.com/BlackBeltShop.../dp/B00P8AC3HU
Quoted: 18409 Post(s)
Liked 15,530 Times
I am still interested in the OP's experience during his tour in relatively remote areas of the world. Did what he used then not work for him? If not, why not?
Quoted: 1324 Post(s)
Liked 927 Times
I've been wearing these mesh type shoe.
If it rains then I take my socks off and just let the water run through.
Works good for swimming in rivers, also.
They work well in hot weather (with socks). Lots of ventilation.
I use platform pedals with those little spike things sticking out of them.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Cheers
Bikes: Custom built LHT & Troll
Quoted: 844 Post(s)
Liked 149 Times
I use sandals on platform pedals. Like others above, I only take one pair of footwear. In the past I've used flip-flops on platforms too, when in warmer locations. My toes like to feel the breeze. In winter they like water-proof socks which are also generally nice and warm.
although I wouldn't wear flip-flops. Teva in my case. Points being (1) open shoes (socks if needed) (2) carrying additional footwear takes lots of space and adds some weight. I've once toured with Scarpa (I forget which model) in cold weather involving serious backcountry hiking.
Quoted: 427 Post(s)
Liked 339 Times
Biking I use bike shoes, mostly use Keen Commuter 4 sandals (now discontinued) or some Serfas shoes, both of which use SPD cleats. The SPD cleats make these shoes less than ideal for hiking.
Hiking, Merrill Moab waterproof hiking shoes. If my bike shoes are soaked from rain or if I am on really rough rocky terrain with my bike, I will use the hiking shoes instead of the bike shoes on the bike.
Pedals, usually Shimano M324 or occasionally Shimano A530 pedals, both of these models have a flat platform side that I can use my hiking shoes and the other side works with cleats.
You can still get theri bike shoes (not the sandals). They are super comfortable, you can walk all day in them, they last forever and you can put SPD cleats on them. Simply nothing better. Just as comfy and well made as other Keene hiking shoes.
Quoted: 226 Post(s)
Liked 45 Times
I had those and they were great for rides where a lot of pressure wasn't put on my non-platform pedals but one day when I rode 60+ kilometers (40+ miles) my feet were killing me. I switched to platform pedals = Lyotard 23 and the problem wasn't so bead. I now use an MTB shoe with a smoother sole than normal MTB shoes and used the included cleat holes cover plate. I love those stiffer sole MTB shoes on any pedals,
Cheers
Cheers
As for the sand.....I guess I did wash that out of the shoes a few times but by morning the shoes were dry and ready for another day.
I've used the same setup for most of my tours. Last year, however, used a pair of Brooks trail runners with Superfeet inserts and was extremely happy. I'll probably use Brooks again.
The reason trail runner shoes are my choice comes down to foot protection, comfort, and flexibility. Trail running shoes have a robust tread, so therefore they offer great protection for the soles of your feet. When combined with the stiff inserts, you can transfer force from your whole foot onto the pedal much better than sneakers or sandals.
For me, much of the draw of bike touring is the unique capacity to take breaks in beautiful places. I like to go on short hikes to explore. When you have good footwear, you can explore so much better, and trail running shoes are very lightweight and comfortable for how much protection they afford. They also tend to be well ventilated. Even when my shoes get soaked, they dry fairly quickly.
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 675 Post(s)
Liked 741 Times
For me, much of the draw of bike touring is the taking breaks in beautiful places. I like to go on short hikes to explore. When you have good footwear, you can explore so much better, and trail running shoes are very lightweight and comfortable for how much protection they afford. They also tend to be well ventilated. Even when my shoes get soaked, they dry fairly quickly.
Ever hear of "bagtex?" In cold heavy rain or snow, use bread bags as a barrier over your socks. You don't want to do that all day, for days at a time, but it's a good, light, and free tool when used judiciously.
This is why I have used rain booties for over 20 years, no more soaked shoes to dry out, very little dampness overall, and totally worth the small space and weight they take up.... Bonus use in cold weather.
Quoted: 2236 Post(s)
Liked 1,314 Times
No matter the degree of technology, it only works if you use it
Never tried, but I will, especially in cooler times of the year. Wet feet in the summer isn't too bad, but in the fall it is. The most Important thing is to always have a supply of clean, dry socks. Even slightly damp means for feet get cold with very few ways to warm them.
Partially Sane.
Bikes: Soma Saga, pre-disc
Quoted: 972 Post(s)
Liked 643 Times
I’ve had great luck with Merrill hiking shoes, and yes, they usually have those mesh tops. 👍 Strangely, they seem to have a few different grades of quality, in the same company. 🤔 Most go for miles & miles, but I’ve had a couple pair that were lemons.
Partially Sane.
Quoted: 972 Post(s)
Liked 643 Times
Liked 1,465 Times
I used to use the plastic bag sock idea years ago when I rode to horticulture college but these days have Shimano rain booties too. Biggest problem. Always miscalculating or putting off the need to stop and put them on when rain begins so I wind up with wet shoes anyways.
But, the plastic bags over the socks do have a role, when it is cold like in the 30s or 40s (or 0 to 10 C) and your vented cycling shoes let too much cooling air into your socks, the plastic bag over the socks inside the cycling shoes helps keep your toes a bit warmer by cutting off the wind from coming into the vents. They will still get cold, but not as cold as without. But if you use this method, if your toes get warm and start to sweat, get rid of the plastic bag quickly.
Below freezing, I switch to hiking shoes or hiking boots instead of cycling shoes.
Liked 1,314 Times
For rainy fall/winter weather commuting I finally bought a pair of ankle length rubber boots that my rain pants cover. Light and comfortable and low enough that the socks protect against chaffing. https://www.marks.com/en/windriver-m...5Bwidth%5D=WID
But yup, gotta put em on
If you want one SPD compatible shoe for riding and walking the Pearl Izumi X-Alp series shoes are great, I've had two pairs of the now discontinued X-Alp Enduro with the ratchet buckle that I used for everything except winter. I use Crank Brothers pedals and install the Crank Brothers steel shim under the cleats to protect the soles. These are a little on the bulky side for most booties but a large neoprene style or toe covers work OK. About 10 years ago PI made an ankle height X-Alp with Gore-Tex but those have been discontinued for ages.
Keen sandals, flat pedals.
Rider. Wanderer. Creator.
Bikes: Bike Friday Pocket Rocket, Cinelli Hobootleg, Zizzo Liberte
Quoted: 389 Post(s)
Liked 772 Times
I like having an off-bike pair of shoes to vary the pressure points on my feet.
