Schwinn Crossfit!?
Prefers Cicero
It doesn't look as bad in the second picture but it still looks like it is there. The forward slant and forward curve of the fork fine tune how the bike steers, and make it more stable and less likely to unexpectedly buck you off onto your face. If the fork is bent back a bit, it can make steering a bit less smooth and more twitchy. As well, a bent fork might break, although that is highly unlikely. Also the impact that caused it may have damaged the ball bearing joint that connects the fork to the steering tube and that joint might wear out sooner.
Quoted: 52 Post(s)
Liked 17 Times
i honestly don't see a difference lol. They both look the same to me.
edit oh I see now here's another picture...
Instagram
would this possibly be from someone putting the fork in crocked?
You could also take it to another shop to get a mechanic's opinion. I think it's pretty hard to bend a fork that evenly.
It's possible an attempt was made to straighten it so at least the legs line up with each other. If it does turn out to be bent, the bike shop might be willing to replace the fork. The color wouldn't match but otherwise it would be fine. I don't think a black fork would look bad on that bike. Maybe even chrome.
They're not that expensive. I guess the question is whether or not the bikeshop would be willing to go to the effort. They might considering they really shouldn't be selling that bike as it is (assuming the fork is bent).
My son bent a fork last year after a small branch went through his spokes. I went to a local bike shop that has a large "salvage yard" to look for a replacement. The shop owner said that lots of times steel forks can be successfully bent back. I'd rather spend the money on a new fork personally.
Also after looking at the picture, it might need some new tires.
It's Queen to you!
Bikes: Roadmaster
It might be easier to tell if it's bent if most of the bike was visible in the picture. Make sure the front wheel is pointed straight ahead and that you're aiming the camera straight at the bike (not more toward the front or more toward the back).
Yes they do have lots of low cost used forks that might not be bent. I mean the place I'm buying from is a non profit, so I'm not going to expect them to do everything. I'm willing to fix up the bike, I know hot to do most of the work by my self..
Everyone that works there are volunteers
Prefers Cicero
Regarding seat (or, properly, saddle) position, there are three variables: height, tilt, and forward/backward adjustment.
Whoever owned the bike before slid the seat as far back on its rails as she could. The rails are on the bottom part of the saddle. I do that on my bikes, but it may or may not work for you. The guru Sheldon Brown pointed out this puts you in a position akin to a diver crouching to dive into a pool with your head leaning forward and your bum sticking out back to counterbalance. It puts more of your weight on your legs and less on your wrists. If your seat is too far forward, you tend to fall forward and put too much pressure on your wrists.
For seat tilt it looks like it is tilted a bit down at the front. This might cause you to slide forward and always be pushing yourself back. Probably better to have it level or a very tiny bit higher at the front, so you slide towards the back. But not too high or the nose will cause discomfort. Most of your weight should be on the ischial bones ("sit bones").
Re saddle height, your leg should be almost straight at the bottom of the pedal stroke, but not quite. If your butt rocks a bit as you pedal, you are too high. Some people feel it is at the right height if they can straighten their leg when their heel is on the pedal. I like it just a smidge lower than that.
It's Queen to you!
Bikes: Roadmaster
So could this replace the fork? If it can, it's still worth my old roadmaster and 20 bucks. Atleast in my opinion.
Amazon.com: Sunlite LW Fork - 27" x 1-1/4", Threaded, No Cantilever Posts, Black: Sports & Outdoors
Prefers Cicero
Actually, probably no. You have cantilever brakes.
Riding like its 1990
That is not a "maybe" it is a "definitely" bent fork. Walk away unless he is willing to give you $20 for your bike and a trade. Then go get another fork. Even then i would prefer to just WALK AWAY!
There is a reason he's so accomodating to you, he wants a working bike and even a walmart roadmaster is better than a bent (low level '90s) schwinn.
No, you need a cantilever 700c fork, with a 1" threaded steer tube in the correct length... and there's no reason you should give him $20.
You'd need this to be installed by a mechanic (another $50) IF the head tube is not bent:
https://www.amazon.com/gp/offer-listi...=&sr=8-2-fkmr2
It's Queen to you!
Bikes: Roadmaster
Prefers Cicero
aka Phil Jungels
No itwill not fit - but it is likely they have a replacement in their pile.
My wife thought she wanted an upright bike, primarily for commuting purposes, but the couple she tried were very uncomfortable. If it is comfortable for you, then perfect but, as @cplager stated, only you know if it is right for you.
DancesWithSUVs
Quoted: 7 Post(s)
Yeah,fork is def bent. Not sure what else is wrong. If they're willing to swap on a good fork,and everything else is ok(have one of their senior wrenches look it over),then an even swap might be alright. Also hard to tell from the pic,but how are the tires? Is that just dirt,or is there any discoloration/cracking on the sidewalls? If there is,tires need to be swapped.
C'dale BBU('05 and '09)/Super Six/Hooligan8and 3,Kona Dew Deluxe,Novara Buzz/Safari,Surly Big Dummy,Marin Pt Reyes,Giant Defy 1,Schwinn DBX SuperSport,Dahon Speed Pro TT,Brompton S6L/S2E-X
It's Queen to you!
Bikes: Roadmaster
Headset could be galled up due to the damage, or maybe it survived, they are usually pretty tough.
To the OP, you have your mind set on that bike so get it. You seem set on paying him $20 as well. I'd advise against the $20 unless he replaces the fork with a comparable model, he may not have realized it was bent. Then again he may not care its bent and be the type of guy who says "hey beggars (literally) can't be choosers. It rolls so ride it."
Since you want it and will get it soon then you've got two options:
New fork - get a good used replacement from him of the right type (700c with cantilevers, NOT a 26" or 27") for proper handling.
Fix fork - Looks like it could be put backif it has been bent right at the junction. NOT ideal but being thick steel 'may be fine'. I wouldn't want to find out on a steep downhill....
I've wrenched on many bikes, from nice to junk. After facing and fixing many types of issues I ALWAYS prefer buying unbroken, unbent, non-bottom-level bikes. Sometimes the final product isn't worth the cost of the fix. Sometimes it is.
Enjoy the bike and post your final build pics. Good luck.
Here's the before and after of a bike in bad shape but unbent and restorable. New wheels and many hours but it was a labor of love for a friend.
Bikes: Sngl Spd's, 70's- 80's vintage, D-tube Folder
I Forgot where you are AQ . . .
Where you are post the CL ads from. I think, Indiana?
If your part of IN is close to Louisville, we a have a few fabulous used bike shops that would take great care of you!
Happy hunting
Happy hunting
☞-ADVOCACY-☜ Radical VC = Car people on bikes. Just say "NO"
It's Queen to you!
Bikes: Roadmaster
From the photo I don't see any signs of the headtube being bent but not all signs are visible. It's a heavy guage frame so is 'probably' ok....
It's Queen to you!
Bikes: Roadmaster
Quoted: 4227 Post(s)
Liked 2,488 Times
Unfortunately the volunteer today had an emergency of some kind and couldn't open the bike project, but Monday hopefully ill be able to go back and see, at this point even a brand new fork would cost me 20ish bucks, I could put it on my self. I'm not sure if its worth it or not, but this bike is just so perfect for me, I've been looking for a long time. I will have to put sme elbow grease into it, but most things like tires and breaks I can adjust/ replace on my own as long as I have the parts. Would it still be worth it do you think to do a trade plus 20 bucks if I have to buy a new fork?
Prefers Cicero
If you have it looked at, have them also inspect the frame joints where the top tube and downtube attach to the seat tube. Those step-through frames experience more stress there, than a bike with a horizontal top tube, which provides stronger bracing.
It's Queen to you!
Bikes: Roadmaster
Yup to repair it its totally not worth it... 40 bucks for a new fork, and he hold me my derailers and breaks need to be replaced too, they are rusted pretty bad I guess.., ugh the search continues... In the mean time, is this bike worth $50
AMF Scorcher Road Bike
Prefers Cicero
The problem is that any cheap used bike is going to need attention. I have bought a number of them and they always cost about $100 to get them in safe working order
It's Queen to you!
Bikes: Roadmaster
So it's not just this bike, it's all bikes? Hmm okay then maybe it is worth it for the price range I'm looking to spend. Idk...
Prefers Cicero
Unless it's really badly banged up I think the crossfit is a much better than the scorcher. Those curved pedal cranks are extremely old and obsolete.
Prefers Cicero
what i mean to say is the Crossfit will be easier to fix up since it has more contemporary components
Quoted: 52 Post(s)
Liked 17 Times
Maybe 10 or 15 years ago used road bikes were cheap and plentiful since most people where buying mountain bikes and hybrids. Lots of old road bikes sat unused in garages. Then they started getting popular as cheap transportation for younger folks. Many were converted to single speeds and fixed gears.
At the same time triathlons and events like long distance charity rides have increased in popularity so road bikes in general have experienced something of a resurgence. However, very few new road bikes were being sold between the late 80's and early 2,000s. So there's not much available in the used market that isn't either really old or really expensive.
Again, just speaking about the local used market, it's not hard to find a hybrid or mountain bike in good riding condition for $150. A good used road bike is going to cost more than that.
That AMF you provided a link for is a 35 to 40 year old equivalent of a bike from Walmart or Target. On it's best day it wasn't that great of a bike. It most likely has some issues now. If everything works and it has been maintained over the years then it's probably worth $50 or a little more if that's all you had to spend. But it's never going to be a nice bike.
Personally I think you'd be better off fixing the Crossfit if you could do it for under $75
