Light Bicycle Carbon wheels, built for tandem
pan y agua
Quoted: 1442 Post(s)
Liked 712 Times
I’m selling a brand new in the box set of Carbon Light Bicycle Wheels.
the specific specs are:
RRU65C02d 640 Disc matte UD 28H With Holes
HUB-F DT SWISS 240S QR / 100mm straight pull Center lock Black 28H
HUB-R DT SWISS 240S QR / 135mm Shimano Road 11S straight pull Center lock Black 28H 18T
SPOKE Sapim Race Black straight pull
NIPPLE Sapim Brass Black Polyax Secure Lock
Its my understanding the hubs can be changed to thru axle by swapping out end caps.
The rims have an added 100 grams of weight to strengthen for tandem use.
Im selling them because I’m an idiot. I meant to spec rim brake compatible rims, and ended up with disc rims.
$700.
$700.
You could get lost and die.
You could hit a tree and die.
