Headset Help -1985 Centurion Ironman
Quoted: 74 Post(s)
Liked 72 Times
Hello everyone,
I recently acquired an 85 Ironman that is in need of a new headset. The existing one has bad indents where the bearings were indexing - too much for the loose ball replacement method.
I am terrible when it comes to finding out what will fit, can you please help me with finding a comparable quality replacement?
Thank you!!!
Thank you!!!
Quoted: 3241 Post(s)
Liked 2,512 Times
Hello everyone,
Thank you!!!
Thank you!!!
Bikes: yes
Quoted: 512 Post(s)
Liked 409 Times
The original headset on that bike should be a Shimano HP-6207, 600EX headset. If I'm not mistaken, you need the version with a 27mm fork crown race, but that should be confirmed.
VeloBase.com - Component: Shimano HP-6207, 600EX
Look up stack height of headset that came with bike and get new headset with that stack height. Note Vintage Cyclists comment about fork crown race diameter.
aka: Dr. Cannondale
Quoted: 2152 Post(s)
Liked 3,402 Times
That's a 27mm crown race on a Tange Levin headset.
Still widely available, although you need to make sure it's a 27mm race. Lots of 26.4's out there.
Tree Fort has them for $20.99, a good price.
I've got a simple remedy for indexed headsets. Take off the front wheel, handlebars, cables and everything else except the bare fork & headset. Tighten the headset nuts down until the fork is very tight & nearly frozen solid. Begin rotating the fork round and round. Continue adjusting the headset nuts & rotating until the races are worn smooth. Take it all apart. Replace the grease & bearings. Tighten the headset nuts down until the bearing surface runs smooth. That's it. That's all. Done deal. Be good. Have fun.
