Wobble in Conti Grand Prix Classics
Hi all,
I've been restauring an old bike and one of the last things to get done was buying some good clinchers for it. I stumbled on these Grand Prix Classics that are supposedly really good but I can't seem to have the bead to sit properly straight.
See video I have made of the issues:
I've refit them about 3 times now (completely off and back on), reinflated a dozen times, tried seating the bead better but the front tire seems to keep having this wobble from left to right on the same spot, and the rear some kind of bump which makes me have to put the wheel too far back in the dropouts to clear the front mech hanger from the bump.
Wheels are true, no bump on them without the tires on.
Any suggestions?
Thanks in advance!
Max
Any suggestions?
Thanks in advance!
Max
just another gosling
Quoted: 3889 Post(s)
Liked 1,938 Times
I hand that happen on older Grand Prix tires. Toss them. Buy Conti 4000 IIS or 5000 next time.
Results matter
Results matter
Likes For Carbonfiberboy:
Has anyone experienced a tire developing a wobble like that after considerable time?
A Hutchinson of mine did so recently. It was ~3 years on the bike, only a few 100s of road miles, maybe same equivalent on rollers. I noticed on a flat family ride and didn't worry, but I'm not comfortable with it on a descent.
Liked 1,938 Times
Results matter
Results matter
Liked 1,938 Times
Yes. Getting a tire up onto the TLR shelf is tough. With a tubed tire, the tube is likely to sneak under the tire and pop during that process. And some of them do have a shallower well. The solution is pretty simple: don't run tubed clinchers on TLR rims. Use tubeless instead.
Results matter
Results matter
Liked 1,938 Times
Ah, you've seem my post in the other current tire thread: https://www.bikeforums.net/22264650-post115.html
I'm still ambivalent about this. They say that Orange Sealant will hold at 100 lbs. It's super time consuming just to get my clincher off that shelf if I flat. I have to pry it over with a metal tire iron. I have better luck mounting them with butyl tubes. I use Velo Plugs instead of rim tape to help with mounting. I think two layers of Krapton tape would have worked better.
Results matter
Results matter
Likes For tgot:
Quoted: 6196 Post(s)
Liked 4,810 Times
Was there anything notable in how the tire rode? If it rides good I'd just keep watching the road in front of me and not get so caught up in the mesmerizing visuals of my tires.
Quoted: 4560 Post(s)
Liked 2,802 Times
I've ridden Conti GP Classics with the reddish-brown skinwalls for two or three years on a couple of bikes, no problems. Excellent tires in my experience.
Any time I've had a wobble or irregular looking tire, it was user error -- I was using rim tape that was too wide for the rim. If the rim tape or strip covers the walls of the rims it'll hinder seating the bead. After switching to narrower rim tape, just enough to cover the spoke holes, the tires seated properly, no wobble or bulge.
This might be less a problem with thinner rim tape, such as some tubeless tapes, or rim strips. But cloth tape like Velox is thicker and can hinder seating the bead if the cloth tape is wide enough to cover some or all of the walls of the rim.
Also with older rims be sure there's nothing stuck to the insides of the rims, especially the bead hooks. If obtained some older rims on which the original rim tape or strip deteriorated, leaving gummy and hardened residue that needed to be carefully scraped out. Otherwise it could interfere with seating the tire properly. I had one 20-25 year old wheelset with the original plastic rim tape or strip that deteriorated so much it seemed to have melted and hardened onto the rim. I had to use a combination of hard plastic scrapers and aluminum picks to laboriously remove the material. Took a couple of hours while sorta watching a movie.
Tire isnt seated properly. A little talcum powder makes tires, tubes less "sticky" and tires seat easier.
