Go Back  Bike Forums > Bike Forums > Winter Cycling
Gloves for 45F
Winter Cycling Don't let snow and ice discourage you this winter. The key element to year-round cycling is proper attire! Check out this winter cycling forum to chat with other ice bike fanatics.
Gloves for 45F
Old 11-01-10, 10:11 AM
malux
Bikes: 2008 Trek 2.1
Gloves for 45F
it's getting down to 45 degrees this friday and I'm thinking of getting full gloves. I'm not sure if I need them at this temp though. What do you think?
malux is offline
Old 11-01-10, 11:30 AM
UnsafeAlpine
Domestic Domestique
UnsafeAlpine's Avatar
Bikes: Brand New Old Catamount! Schwinn Homegrown, Specialized FSR, Salsa Vaya, Salsa Chile Con Crosso
Liked 6 Times in 6 Posts
I use light glove liners for temps down to about 40 or so. From about 20 to 40, I use heavier fleece liners. Anything below 20 gets the full mittens.
Even if you have poor circulation, you may find that full gloves will be too hot especially if there's any sun.
UnsafeAlpine is offline
Old 11-01-10, 11:49 AM
The Impossipede
They're your hands, man. If your hands are cold, it's time. If they're not, it's not.
I have friends that put long fingers on at 52. I don't need them until somewhere in the 30s. Everyone is different.
Throw the short gloves in your back pocket. If your hands start to get all sweaty, switch.
The Impossipede is offline
Old 11-01-10, 12:19 PM
ScottRock
This. Rode today in the mid-40's and i was fine with my fingerless Treks. If you're worried, though, better safe then sorry.
ScottRock is offline
Old 11-01-10, 06:38 PM
Pwnt
( 8n(|) DOH!!
Pwnt's Avatar
Bikes: Scattante R670
I use Pearl Izumi Cyclone gloves. They seem to work well for me to about 35. Then I go to a little thicker glove.
_____________________________________________
I love noodles.
Pwnt is offline
Old 11-01-10, 06:56 PM
RonH
Life is good
RonH's Avatar
Bikes: 2018 Lynskey Helix Pro
Quoted: 522 Post(s)
Liked 10 Times in 10 Posts
45F in Winter Garden is COLD. I know. I used to live in Orlando.
If your hands are cold, they're cold. Talking or manning up won't keep them warm. Do what you have to do to stay warm.
Don't get wimpy, thin gloves. Get something heavy enough to keep your fingers warm.
RonH is offline
Old 11-01-10, 07:15 PM
Pug
High Modulus
Pug's Avatar
Bikes: Cervelo R3, Ridley X-Night
I've found the Novara Headwind to be comfortable down to the high 30s (F). Dexterity isn't much to write home about but I guess that's to be expected.
Pug is offline
Old 11-01-10, 07:42 PM
Tom Pedale
Tom Pedale's Avatar
Bikes: 2006 Specialized Tarmac Expert, 1990 Specialized Allez Epic, Specialized RockCombo (winter), 70's Motobecane Team Champion,
Liked 7 Times in 6 Posts
Not sure if you would need full-fingered at 45 degrees...but I would..
Tom Pedale is offline
Old 11-02-10, 04:40 AM
Scheherezade
12mph+ commuter
I wore some basic glove liners this morning (36F) to work. I would have worn heavier if my commute was more than 2.5 miles.
Scheherezade is offline
Old 11-02-10, 07:06 AM
rogerstg
Fred-ish
rogerstg's Avatar
Temp is only one part of the equation. You need to consider speed (windchill) and ride duration along with your own comfort issues. IOW, no one here can give you the right answer, except by coincidence.
rogerstg is offline
Old 11-02-10, 01:09 PM
malux
thanks everyone for the advice. I ride about 1.5-2hrs starting at 5:30 or 6am and I'm a pretty big wuss when it comes to cold. I think i'll try liners first for a day. I don't think i'll need to go thicker, but I'll just see how it goes
malux is offline
Old 11-02-10, 01:15 PM
JPprivate
Very, very Senior Member
JPprivate's Avatar
Bikes: 2012 Surly Troll, 1999 Hardtail MTB
I just use regular work gloves that you can pick up at most hardware stores for a few dollars. Works fine at those temps.
JPprivate is offline
Old 11-02-10, 03:45 PM
scoatw
scoatw's Avatar
Bikes: 96 gary fisher 'utopia' : 99 Softride 'Norwester'(for sale), 1972 Raleigh Twenty. Surly 1x1 converted to 1x8, 96 Turner Burner
Quoted: 9 Post(s)
Liked 4 Times in 4 Posts
I do the same. I wear those brown cotton work gloves you see in convienence stores for about $1. They work for me down to about 32f. Below that its Loki mittens.
scoatw is offline
Old 11-02-10, 10:49 PM
Hezz
Get yourself the liners and some nylon glove shells. The shells are light and you can carry them in your pocket. IF the liners are not warm enough on their own slip on the shells. The liners will be much warmer with the shells on them. I find that the easiest way to get a good quality lightweight shell is to buy a pair of cheap insulated ski gloves from Walmart that have a good shell on them and cut out all the liner and membranes. These are usually under 10 bucks. Ski gloves in this price range are usually touted as waterproof because they have a waterproof lining. They do but they don't breath so they are only good for one bike ride. With this approach you can use either a thin glove liner for insulation or a medium thick cheap fleece glove which will be a lot warmer than the thin glove liner. So you have four combinations for different temps.
Hezz is offline
Old 11-03-10, 02:19 AM
commo_soulja
commo_soulja's Avatar
Bikes: are fun to ride
Quoted: 33 Post(s)
Liked 35 Times in 23 Posts
I wear windproof gloves from Performance during the morning commute into work and it's been in the 40s. During the ride home I'll sometimes wear my full fingered Fox gloves but more often than not, it's the same pair of gloves if it's still chilly (50s).
commo_soulja is offline
Old 11-03-10, 05:31 AM
zoink
I used these yesterday in the high 40's for about 2.5 hours, pretty cheap and worked great.
https://www.sierratradingpost.com/p/,...-For-Men-.html
You can use the coupon code "PARKS" to get 20% off on that site for the month of November. Pretty good deals on lots of winter stuff like baselayers.
zoink is offline
Old 11-03-10, 04:57 PM
harshbarj
Bikes: Trek Belleville, Workcycles opa, Schwinn
Quoted: 61 Post(s)
Liked 6 Times in 3 Posts
Gloves at 45°?? I don't even think of gloves until the lower to mid 30's. Though I guess it depends on the length of the ride, the wind, etc.
harshbarj is offline
Old 11-04-10, 10:22 AM
simonaway427
Bikes: 2010 S1, 2011 F75X
I use MEC full fingered cycling gloves along with Arcteryx Merino wool liners - they work great down to about -5C.
simonaway427 is offline
Old 11-05-10, 07:37 AM
malux
I ended up getting these. It was 54 degrees this morning but windy and chilling. They did a good job on a close to 2hr ride. NowI need a jacket. Also, my toes were coooold.
malux is offline
Old 11-05-10, 07:49 AM
rogerstg
Fred-ish
rogerstg's Avatar
The body pulls warming blood flow away from extremities in favor of the head and core organs. What it means is that keeping the head and torso warmer often helps the extremities to stay warm.
TIP: An easy way to accomplish this is to tape over helmet vents as needed. I use 1" blue painters tape. It's easy to remove tape strips while you ride if it gets too warm.
rogerstg is offline
Old 11-05-10, 08:30 AM
malux
great tips roger. I'm new to cycling and especially to cycling in the cold. Much appreciated.
malux is offline
Old 11-05-10, 09:11 PM
Hezz
I think those gloves will work pretty well for you down to a certain temp. You'll have to find out what that temp is. I would still recommend a windproof shell to carry with you on the colder days.
Ya, you got to get a decent cycling jacket for winter riding. Absolute must. Then you can work on the feet. A cheap solution to help keep your toes warmer that works with cycling shoes down to about 45 degrees F is to duct tape over the toes to block the wind from coming in. That is if your using cycling shoes. You can also use clear vinyl tape as it doesn't look so corny but it may not stick as well as duct tape.
Hezz is offline
Old 11-14-10, 09:12 AM
chuckb
Here's a glove option that I discovered by accident. Wear silk glove liners under your regular (short-fingered) cycling gloves. Dirt cheap and works to surprisingly low temperatures, easily down to 45 F for me.
https://www.amazon.com/gp/product/B00...ms_ohs_product
They are a little slippery on grip, but that hasn't bothered me much. Your fingers may feel a little cold at the start of a ride, but once I get going this combo works well.
chuckb is offline
crazyravr
Road Cycling
29
11-05-16 07:09 PM
chefisaac
Winter Cycling
17
10-31-15 06:06 PM
chefisaac
Commuting
12
04-05-13 10:06 AM
milnerpt
Winter Cycling
4
12-27-10 08:46 PM
DGonzalez
Mountain Biking
19
08-16-10 09:07 PM
