Which frame would be more suitable for long distance touring/commuting
1. Cheap aluminium alloy Mercurio road bike frame converted to touring bike with Suntour NCX suspension seatpost, butterfly handlebars, Lepper leather saddle with mattress (cover springs) and Schwalbe Marathon Pluss 622x32 tyres inflated to 40psi pressure. Total weight about 100kg.
2. Raleigh high tensile steel 18-23 frame with telescopic suspension seat post and the same tyres and the same saddle.
3. XB3 Tourist (unknown steel frame), obsolete German leather saddle with cover springs, cafe handlebars and unknown Schwalbe 622x32 tyres inflated to 30psi. Total weight 80-100kg.
I'm trying to get used to the first example after years of being able to ride whole day without significant discomfort while using the third example.
Now thinking about using the second example.
Seems like suspension seatposts aren't doing anything to improve comfort when used with aluminium alloy frames. Might reduce frame fatigue and keep the wheels true for longer though.
Quoted: 451 Post(s)
Liked 364 Times
Don't intend to be rude, but why would these be our only options? Lots of good bikes out there, many, quite affordable. If you are going to be commuting, you really want something dependable and safe.
Registered User
Quoted: 188 Post(s)
Liked 276 Times
Bah! Good quality built wheels keep wheels true longer. Clydesdale here, over 20,000 miles on a set of wheels riding an aluminum roadie. Built them myself. A shock post would not make one bit of difference.
As far as choice, I would not select any bike that I could not test ride. If I could, the most comfy would be the one I would chose.
Looking for new one in your local LBS might be cheaper, but according to personal experience one always ends up with rebuilding, customising something or returning and reselling.
As far as I know nowadays there are only available low quality hight tensile (mild) steel frames or chromoly steel frames which are made with larger diameter tubing therefore stiffer and more uncomfortable. This leaves old steel frames as the best option.
Bikes: Soma Double Cross Disc (2017), red Hardrock FS (circa 1996)
Quoted: 217 Post(s)
Liked 155 Times
Quoted: 2236 Post(s)
Liked 1,314 Times
30 seconds and google lets me know the XB3 is an old Russian bike made by a company called Mecholaton.
My vote is whatever is cheapest at the thrift store.
In Real Life
Bikes: Lots
Quoted: 3203 Post(s)
Liked 596 Times
And I'm guessing you haven't been bicycle shopping in a while?
Rowan
My fave photo threads on BF
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
First one is fully assembled, second one is a frame in a need of painting, third one is long gone now. All of the brand new midrange bikes I have bought had all sorts of problems, so not exactly sure if repeating the same mistakes all over again would be the best thing to do at this point.
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
I think you're asking us which of 2 frames you'll find comfortable. I'm pretty sure none of us can tell you that.
What's wrong with your current bike? We really don't have any idea what you're trying to improve.
That pressure seems pretty low for 32s. Maybe futz around with different pressures and saddle/post choices before you start a big project. I've generally found that suspension seatposts are worse than useless.
Expired Member
Quoted: 3674 Post(s)
Liked 5,431 Times
Quoted: 7652 Post(s)
Liked 3,473 Times
I definitely cannot recommend the XB3 Tourist since it “is long gone now.” Why you would mention a bike that doesn’t exist is hard to understand.
The other two are probably very similar. The steel might be a bit less buzzy, that is, it might dampen really small, high-frequency sort of road shocks, but it depends on the shape of the fork as much as anything else.
If you have one bike built and running …. Is it uncomfortable? How is it different from the bike you used to b able to ride all day? (Also, how has your body changed?)
As for the suspension seatpost---as others have said, it has nothing to do with frame material. Frame fatigue is not really an issue---they are made of metal---and the only way it would matter with the wheels would be id you rode planted in the saddle and didn’t lift up for big bumps, or hit a big bump unexpectedly---and in neither case would a suspension seat post do very much to keep the wheel from bending or a spoke from breaking if the hit was hard enough to do that.
It seems to me, the question you need to ask is, “How can I make my bike more comfortable.”
To know that, you would need to figure out what makes it uncomfortable. Is it not the right size? Is it not set up properly (wrong relationships between saddle, bars, and pedals)? Those are what really impact comfort. Any bike will kick back impacts over bumps …. If you ride really bumpy roads all the time you are going to feel bumps. Nothing but a suspension forks will make bumps go away.
Liked 3,473 Times
Also, you say "All of the brand new midrange bikes I have bought had all sorts of problems, so not exactly sure if repeating the same mistakes all over again would be the best thing to do at this point." What problems? What went wrong that those bikes did not work? Also ... what is "mid-range" to you. It could be $600, $1200, $or $2000-$3000 where I live ... which is a pretty wide range.
What bikes have you bought and what went wrong?
Likes For Maelochs:
