Criteria to replace drivetrain
In general, how many miles before having to replace your drivetrain?
I have a 105-5800 with about 5K miles - chain was replaced with around 3K miles (but I kept the old one, so I can compared them later).
On another bike I got a used Ultegra 6700 and have put some 2K miles (don't know the previous owner mileage) - I had a new chain when I built it.
Since I am cheap, I will probably use it for more many miles.
What are the criteria BFs use to replace a well used drivetrain?
Also notice my rear wheel rim on my commuter shows some usage where brake pads touch it - I have a long half mile descend where I use the brake,
Any recommendation when should be replaced, signs to watch out/keep eyes on?
Quoted: 1438 Post(s)
Liked 1,092 Times
I repair drivetrain parts by condition,not mileage; chains at 1/16" stretch in 12 inches, cassettes and chainrings when they skip with a new chain. I use an Iwanson dental gauge to measure brake track thickness and replace rim at <1mm. https://www.amazon.com/Stainless-Iwa.../dp/B0087HKWCO Rear rims tend to wear more since grit gets thrown onto them especially in the wet.
Likes For dsbrantjr:
Quoted: 980 Post(s)
Liked 582 Times
AKA "crown thickness gauge" used for measuring the thickness of finished dental crowns (before cementation) and wax-ups of crowns (before casting). Good ones are accurate to 0.1mm and ar handy to have around for a variety of non-dental applications.
SE Wis
Quoted: 2746 Post(s)
Liked 3,390 Times
I have about 20K miles on an Ultegra 6600 drive train. on 2nd cassette, new chain & cables every year, original chainrings, BB, Freehub, shifters, derailleurs, hub bearings serviced or replaced every year. Mavic open pro 36h wheels. I've replaced brake pads at least once.
My commuter is 32h on both front and rear, so I could swap the rims and rebuild the wheels since the front one is in much better shape currently.
Quoted: 1819 Post(s)
Liked 1,693 Times
Putting a badly worn rear rim on the front involves completely unbuilding both wheels and then rebuilding them with possibly poor results. If a front wheel fails due to a worn rim or a poor build the results could be very painful
Likes For alcjphil:
Quoted: 980 Post(s)
Liked 582 Times
This puzzles me (though it makes complete sense!). I have worn out the rear rims on my commuter bikes several times. 20" wheels (406), always the rear. I commute in all sorts of weather in Chicago. My "winter" bike was the worst until I replaced the rear V-brake with a roller brake. My "good weather" bike is on its third rear rim at about 7,500 miles. I use the front brake predominantly. My hypothesis is that the front wheel kicks up dust and road debris which then lands on the rear wheel. I have no other explanation.
I am potato.
Quoted: 1789 Post(s)
Liked 1,629 Times
A better balance between front & rear brake application & an occassional bath would save you a bunch of $$$.
Some people keep a bucket of water by their back door/garage to rinse off the bike before puting it away.
Quoted: 550 Post(s)
Liked 325 Times
You can't see the few thousandths of an inch difference between measuring at 11 and 12 inches, but having the fractional inch marks will be more accurate. You don't want to use a chain checker that also measures roller wear which doesn't effect pitch and therefore does not matter.
Replace the cassette when a new chain skips on it. I have over 26,000 miles on my current cassette, but expect it to be due when I change my next chain given a historic 5:1 chain to cog replacement rate.
Replace big rings and triple middle rings if you get uncommanded down shifts at high chain angles. That takes a very long time.
I've never worn out a small ring. When I wore out my first big ring I replaced the crankset because that cost less, and I changed cranks before I wore out the next one.
People in the wet Pacific Northwest with rim brakes can wear them out in a year, so your mileage may vary.
Watch for where your brake pads touch your rims. They hit the rim higher as they wear and can go through your tire if you don't adjust them as needed.
Bikes: Merida Speeder
Quoted: 233 Post(s)
Liked 165 Times
A rough guide is 3-4 cassettes per set of chainrings and 3-4 chains per cassette. Check each chain at 2,500 kms for 9 speed, 2,000 kms for 10 speed and 1,500 for 11 speed. They are usually about 0.75 on a Park Tool chain checking tool at that stage, but they can be more or less worn, depending on what you've been doing on the bike. Still, you can then take the chain out to 3,000-3,500 and measure again. You can also do the same with cup and cone type hubs for longevity. I'm currently changing my Shimano XT hub bearings once every 2,000 kms, but I'm a heavy guy, I ride a heavy bike and I carry heavy loads on it.
Keeping track of the numbers is useful in terms of knowing when to check the chain and having a fairly clear picture of the state of your drivetrain. It's not meant to be limiting or a hard rule to follow, it just tells you that it's time to check your bike out and to think about changing your chain sooner rather than later to get a better lifespan out of your chainings.
Quoted: 980 Post(s)
Liked 582 Times
Or you just use your rear brake predominantly for stopping & under utilize the front. Exactly the opposite of what is most effective. Combine that with rarely removing grit/road grime/abrasives from the pads & brake surface...Well, It's hard to believe any wheel would last "only" 7500 miles, let alone a rear. Something is amiss with your habits. Does the left brake go to the front & right go to the rear? American standard isn't necessarily the way your bike may be cabled. Brit's do it opposite.
I'm well-acquainted with the greater effectiveness of the front brake, and use it accordingly.
In fact, the right brake lever controls the front brake; I have all my bikes set up that way.
The bike has 7,500 miles on it, and it's on the third rim. This is the odd thing: the front rim is worn, but only slightly. Also, this problem only appears on my 20" folder; my road bike has similar mileage, yet the rims look almost unworn. A mountain bike that's 20 years old and has over 6,000 miles on it has barely noticeable wear on the rims.
I do ride the commuter bike in a fair amount of rain, so there is that. There may be something about the narrow (original) rim width with wide tires; I installed the current rim, which is wider than the original, about 3,000 miles ago... about 50% more mileage than I got on the original 2 rims, and it's not too worn.
I'm OK with washing the bike a couple times a year, but I'm not going to do it every day. Especially when it's below freezing!
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
Well used can mean cosmetically challenged, or slap wore out. Wore out = replacement time, smart to keep ahead of the game on the chain so you don't ruin chain rings and cassette in the process. Good advice above.
Cosmetically challenged = continue on!
Started applying more front brakes on my rides .
When we install a brake pad the recommendation I see is to have some angle on the rubber so you don't have the noise and that feeling of quick stuck and release.
I am thinking now, since the angle is there, it is a perfect way to collect the little sand/crap on the rims and kind of hold with the brake pad - because you have that little angle there.
Do you try to keep the pad as parallel as possible to the rim, so in theory you accumulate less crap between the pad and rim?
Quoted: 1638 Post(s)
Liked 741 Times
nine mile skid on a ten mile ride
