Vintage Style Handlebar Angle
Have bike, will travel
Quoted: 910 Post(s)
Liked 288 Times
Hmm...it seems more to me that those unattractive bar and lever angles, as seen in your photos, are compensating for an otherwise poor fit. If the frame size, stem length, bar size, etc. are proper, one should be perfectly comfortable and have the best ergonomic angles of back, shoulders, arms and wrists when his bars/levers are positioned and angled close to the typical "pro" fashion. If you need to change those angles, then the frame or stem is probably the wrong size.
Well then there's no need to set up your handlebars race style.
You know, there are rules for this.
What??? Only 2 wheels?
Quoted: 1222 Post(s)
Liked 645 Times
Understood. My vision is similar in that I like the implicity and elegance of the ramps as a linear extension of the stem.
Real cyclists use toe clips.
jimmuller
jimmuller
Quoted: 31 Post(s)
Hmm. I've always put my ramps horizontal, i.e. parallel to the stem. It puts the brakes in a good place for riding and braking. (I ride the hoods a lot.) But I also like the appearance. To my eyes a bike with drops parallel to the ground looks, shall we say, droopy-nosed. I hate that look.
There is another benefit from angled drops, at least for me. When I don't ride them very often but when I do my arms and hands are perpendicular to what I am holding. With horizontal drops my hands would be leaning forward into the things I'm trying to hold. So my hands would tend to slide forward more easily, requiring me to grip them more tightly.
Quoted: 659 Post(s)
Liked 595 Times
I roll the drops downward (bars back) just a tad. Levers are set forward enough to give proper fit when on the hoods.
Quoted: 7348 Post(s)
Liked 2,465 Times
My guidelines comes from training I received from the estimable Gaylen ("Lenny") Preheim from Toga Bike Shop, may he rest in peace. His orientation was towards Italian racing bikes. He noticed that all pictures from Italy of racing bikes showed tips of the brake levers dropping slightly BELOW the plain formed by the bottom of the bar. The drops would range from (1) parallel to the ground through (2) pointing towards the rear axle. This is a good example:
RUSA #3100
Bikes: Yes
Quoted: 237 Post(s)
Liked 505 Times
"You know, there are rules for this."
For me the primary rule is comfort. I want a riding position that is sustainable for hours in the saddle. I like to take my older bikes on brevets and double centuries so a comfortable riding position is very important. If what you ride is mainly 30 mile club rides which can be a pretty sporty pace then comfort is less important and speed is more so. Rules for what is correct depends entirely on what you are doing!
Having said that, I agree with rootboy that the bikes pictured in post #22 look about right to me, and very similar to how I set my bars and levers.
Also, remember that it is a rule that all rules have exceptions!
https://utahrandonneur.wordpress.com
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,295 Times
++++ 1
You're supposed to wear size 42 shoes and they have to be narrow to be a REAL cyclist! I don't care if your feet are 10 1/2 EEE! ...
...I ride with my bars pointed downward at 5° to 10° with the levers near the tops of the bends. The angle depends on the frame size.
I like my wrists to be comfortably parallel to the tops of my forearms so I adjust the angle to where the bar is comfortable FOR ME!
verktyg
Chas.
verktyg
Chas.
I can see the value in gripping a straighter part of the bar, versus the curved part, while supporting weight. That's why I like Anatomic bends, it's more comfortable on my palms, while setting the bar at it's intended angle, since the drops have that sharp bend a couple of inches from the end.
And so funny about the shoe dimensions. The big reason I don't even consider using vintage pedals is because I could never find wide shoes to make it all work comfortably for me. That and the safety improvement of clipless.
Quoted: 1324 Post(s)
Liked 927 Times
I really thought I read that Schwinn wanted it's bar ends to point to the rear hub.
I don't doubt your guideline, but there were a lot of different style drops thru the 70s and 80s and what. You posted wouldn't apply. Full C bend are great for me since both the ramps and drops are level. That's just one of the designs.
Cheers
One nice feature of the early Phillips handlebars was a very elegant bend that kept the long flats behind the brake levers parallel to the drops. Do you think perhaps they knew something about comfort back then? One can see why they were popular, along with randonneur handlebars, for long distance riding. I have two bikes with the V.O. Grand Cru rando bars, easily the most comfortable type I have used.
Quoted: 443 Post(s)
Liked 27 Times
Chas' examples look close to the way I like my bars and levers, although I can't figure out what he means by "parallel to the tops of my forearms".
Decrepit Member
Schwinn instructed dealers to set the drops at a 15° angle when assembling new bikes. The idea is to keep the wrists straight when riding the drops with the elbows slightly bent. This prevents numbness of the hands from poor circulation that occurs when the wrists are angled. Obviously, the 15° drops angle gets changed depending on the riding position, arm length, and other variables to suit the rider.
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Quoted: 150 Post(s)
Liked 34 Times
Bar position was always subjective to each rider. Sure there would be a general opinion on what might be correct, but as long as the cyclist does not use the bars and levers totally contrary to the intended purpose design (such as flipping the bars and levers to "hobo" configuration, which can be quite unsafe, IMO), the rider is free to angle their bars any way they want to, off parallel to the ground....,What I noticed is, modern bike riders configure their bar and brifters positions as to emulate what would be a high bullhorn configuration with everything on top at pretty much one level. Lots of C&V riders like to angle up their bars to possibly emulate this more modern approach to riding positions..
I personally still find the three position old school bar configuration with the top being the horizontal portion of the bar, near the stem, mid level on the hoods and low on the drops....
Sunshine
Quoted: 10955 Post(s)
Liked 7,485 Times
That would obviously change depending on stem height though.
Thanks for the pic.
Quoted: 514 Post(s)
Liked 448 Times
While Schwinn did quote the 15 degree angle in many publications, the angle to match those pictures (where the bar ends point to the rear axle) is more like 30 degrees actual.
Schwinn wanted the stem height to be consistent as well, 1/2" below the top of the Twin-Stik shifters for derailleur models according to the official pubs.
These days, you can walk into a decent shop and see bars, levers, and saddles sticking in all directions, depending on who built the bike. Or not. Or you can walk into Wal~Mart and see a fork turned backwards.
Personally, I believe that if you're going to use the drops effectively, they should be dead horizontal to turned up a few degrees. And the ends of the levers should at least hit the projected line from the bottom of the drops. Lower is OK for shallow drops.
As for all that curved real estate above the lever, that's for draping your hands over, Roger de Vlaeminck style.
You already know, though, that you don't need my permission to do whatever makes you feel good.
Liked 2,465 Times
@Kactus, that's fine, but optimizing for the tops has made it impractical to use the drops. It's fine if you don't plan to. My goal for my own bikes is to make the brake levers equally accessible from both the tops and the drops.
Quoted: 150 Post(s)
Liked 34 Times
That's what was cool about Schwinn, even if I don't quite agree with all the details. They cared how their bikes were presented and showed their dealers how to do it.
Liked 1,295 Times
When I am in the drops, the brake levers are literally at hand, which better allows me to stay relaxed and comfortable.
The "Schwinn" method is great in terms of gripping a straight section of bar at a comfortable angle, but brake lever access doesn't seem to be part of the plan!
Also, when I'm going at the highest speeds that I would over rougher road surfaces, that is no time to have to change one's hand position on the bars, which by itself could cause loss of control in worst-case circumstances.
So I gladly suffer some hand discomfort (from having my hand gripping the curved part) in lieu of surrendering ready brake lever access.
Thanks mstateglfr for clarifying the official position of the ever-conscientious Schwinn. They had their opinion on the matter, which I happen not to follow. But before the advent of the Anatomic handlebar, theirs was one way to maintain a comfortable grip over rough ground, with hands in a low, stability-promoting position.
I have purchased many a used bike with the brake levers positioned way down, for ready access from the straight ends of the bar. It's actually not that bad of a position if you never put hands to hoods, but deprives the rider of the best grip for out-of-saddle honking and somewhat disables the function of safety levers, where present.
