Dunelt Resurrection
2-Wheeled Fool
Bikes: Surly Ogre, Brompton
Quoted: 1385 Post(s)
Liked 677 Times
Dunelt Resurrection
Hello, Everyone. I'm starting this thread to document my rebuild of an old Dunelt 3-speed frame that I've had kicking about. This will not be a full-on restoration, rather it'll be a resurrection. I'm of the opinion that a complete restoration to this frame would cost more and take more time, and the end result will be a bike that will not get ridden. What will do is to freshen it up, clean it up, straighten it up, and sort it out.
Here's the serial number location. I bought this as a frame, and the PO said the frame was a '53. When I asked him several times how he knew it was a '53, he side-stepped my questions rather well. He should be a politician!
The frame number is: 675056. If anyone can help me verify the year, I would be in your debt.
What I have done so far is to straighten the frame and fork, and widen them out to fit a nice set of old-school Campy hubs, which I intend to lace to some VO PBP rims for a nice classic polished look.
There were a lot of factory finish issues that I encountered, but nothing that some file work would not cure.
The frame paint was severely oxidized. I started to gently clean it with some warm soapy water and a cloth, but found a log of slag and poor brazing along the way. I was going to just buff out the whole frame with some polish and cleaner wax, but instead I decided to clear-coat it with some satin 2K.
I apologize for the lack of "before" pics, but I also have another project going and it was overlooked. I did flush out all of the tubes with denatured alcohol, and blew out any debris. The frame was cleaned thoroughly inside and out, and Framesavered afterwards. Now its been preserved in time! Good for at least another 50 years!
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,055 Times
Do you have a rear wheel with a Sturmey hub? The frame is Raleigh-made which suggestst "59 or later. The D-thimble crown was typical of the 60's era. Should be a fine bike.
Phyllo-buster
Liked 2,055 Times
Bonus!
Bikes: Indeed!
Quoted: 1507 Post(s)
Liked 3,478 Times
I'm looking forward to seeing the project progress. I'm happy to see I'm not the only one who thinks it's ok to clean up messy shorelines, blobs of brass, and the other little uglies left by the original builder.
Brent
Brent
2-Wheeled Fool
Liked 677 Times
The old saying of "Lipstick on a pig" comes to mind. My best friend used to say, "If you stick a diamond in a turd, you still got a turd." There's certainly nothing mystical or classical about these old English three-speeds. All I do is breathe some fresh air into them and get them back on their feet in a way that will appeal to someone in this century.
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,801 Times
Right!
Well done!
I never finish anyth
Bikes: 2008 Merckx LXM, 2003 Giant XTC mtb, 2001 Lemond Alpe d'Huez, 1997 Lemond Zurich, 1989 Cannondale ST, 1988 Masi Nuovo Strada, 1983 Pinarello Turismo
Quoted: 294 Post(s)
Liked 137 Times
If you don't yet have the VO PBP 700C rims, I have a set of unlaced rims that I won't use. I wound up switching to 650B rims for my build. I'll be more than fair on the price since they will just sit in my shop otherwise. In fact, I'm pretty sure they're still wrapped just as I received them.
2-Wheeled Fool
Liked 677 Times
Get off my lawn!
Bikes: 1917 Loomis, 1923 Rudge, 1930 Hercules Renown, 1947 Mclean, 1948 JA Holland, 1955 Hetchins, 1957 Carlton Flyer, 1962 Raleigh Sport, 1978&81 Raleigh Gomp GS', 2010 Raliegh Clubman
Quoted: 93 Post(s)
Liked 98 Times
Nice to see some attention and what appears to be a lot of effort going into an old 3spd. I did this Dunelt up for my Goddaughter to use in college. She still has it and gets regular summer use. It came to me via a trash pick. An OA bath, fresh grease, oil and new brake pads tires and tubes and it is good for another 30 or so year. Cheers to you NoControl for giving another one a second chance at life.
2-Wheeled Fool
Liked 677 Times
Whats your mix ratio on the OA?
Quoted: 7348 Post(s)
Liked 2,474 Times
Get off my lawn!
Quoted: 93 Post(s)
Liked 98 Times
NoControl - On painted surfaces, I start with a heaping table spoon per gallon of water. After 24 hours, if you do not see any bubbles forming I add to the mix. A milder solution won't leave a haze on the painted areas. On Chrome, I'll go 3x the amount of AO.. Skip buying it as wood bleach. You can buy 10 lb bags for the same price of Ebay or Amazon
Noglider - Yes, we should get together...still in the West Village during the week?
Liked 2,474 Times
Yes!
Bikes: '00 Koga Miyata Full Pro Oval Road bike.
Quoted: 475 Post(s)
Liked 8 Times
Those are cool old bikes, very retro and different than anything made these days. I guess that's what makes them cool.
2-Wheeled Fool
Liked 677 Times
I just finished up another bike, so time to get on top of this one.
Check out the BB. Poor manufacturing techniques and very little quality control back in the day was responsible for this. The English bike factories churned out thousands of bikes, and as long as people were buying them, they had no reason to make the process better. Look how caved-in it looks I haven't measured it, but I'll bet that is at least a .254mm-deep cavity. I'm no dentist, but what I'll do is shave off enough to make it perpendicular and give it a good seat for the sealed BB that I'll be using.
Chasing and recutting threads. They were pretty buggered anyway. They were threaded deep enough for the threaded cups, but not a thread more. I threaded into it maybe 7-8mm more to accommodate the sealed BB.
Threads cut in all the way. For this particular Park tool (BTS-1), you need to use the taps as guides to allow you a perfectly perpendicular facing.
Starting the cut with the BTS-1. You can see how far off the face was. Imagine how many miles this bike has been ridden in such a poor state of health!
I switched over to another Park tool (BFS-1), which is better imho for facing because of its adjustable pressure. Its harder to get a decent cut out of the previous model I was using simply because you have to apply your own pressure. The BFS-1 evens all that out, so that you can slowly and steadily cut the face and square it up.
Here it is, all pretty and shiny and square as a cucumber (). I'll do the same thing on the left side and sand out any chatter marks with some 400x wet-or-dry and a flat piece of precision-ground 0-1 that I keep for stuff like this. I'll rinse it out with some mineral spirits and blow it out, then wash the oil off the outside and touch it up with a little clear to keep it from corroding.
Quoted: 294 Post(s)
Liked 137 Times
How wide is that shell after the amount of material you had to remove? Maybe it looked like you had to remove more than you actually did, but still.
Dale, NL4T
Dale, NL4T
Quoted: 3813 Post(s)
Liked 3,345 Times
Be those 26TPI taps you ran through there or did you simply rethread to 24TPI?
Great thread and documentation of project BTW!
2-Wheeled Fool
Liked 677 Times
Thanks! The threads were re-cut using the standard 24 TPI.
Bikes: Raleigh Sports 1963, Phillips 1959, Cannondale F700 1999, Cannondale Crit 500 1980s, Bianchi Limited 80s, Bianchi Brava 80s
Quoted: 28 Post(s)
looking forward to this build. I just picked up a 1970s dunelt good frame but very rusty.
Liked 3,345 Times
What marques in the Raleigh pantheon received these triangular tubular crowns vs the round ones?
2-Wheeled Fool
Liked 677 Times
I'm curious why you chose the word pantheon to describe the various re-badged Raleighs over the years... well at least I think that's what you mean, hehe.
Honestly, I have no idea. I have a British friend, Nick, who may know. He's the owner and curator of Three Speed Hub - so maybe if you shot him a line on his forum?
Phyllo-buster
Liked 2,055 Times
Calamari Marionette Ph.D
