Wd-40
Wd-40
Ok, I don't see this on a search. WD40 - good or bad as a chain lube? 20 yrs ago when I first got into biking, I'm sure I read not to use it and never have. I'm a Tri-flow gal. However, recently 1 person told me it's good for cleaning the chain and another said it's good for lubing! Feedback, please.
Bikes: Felt Z5, Look 675 Light, Specialized Diverge
Quoted: 48 Post(s)
WD-40 is a solvent not a lubricant. It does lubricate some especially when first applied but it's designed to evaporate and it doesn't leave much behind that is of lubrication value. While it's better than nothing, there are much better choices.
Quoted: 659 Post(s)
Liked 7 Times
I've found the original WD-40 product to work fine as a lubricant, but it doesn't last particularly long - especially if you ride in the rain. So you need to keep reapplying it more often than thicker lubricants. WD-40 also makes a product marketed as a bike lubricant that does last longer than their original product.
Señor Member
I use Tri-flow myself - WD40 is good for loosening rusty nuts and cleaning (but not cleaning chains). The old WD40 is something I would never use on a chain - the bike specific stuff I have never really considered, and I don't have much of an opinion about those products.
Bikes: Kona ESATTO DDL Cinelli Zydeco
Quoted: 11 Post(s)
Stick with your Tri-Flow its pretty darn good stuff, I have never had any issues with the product. i have used it for over 20 years one of the best lubes I have used, being a mechanic for close to 30 I have seen a lot.
Wd40 is all I use for cleaning and lubing chains. If you use one bike and bike 300 miles or less a week, you just clean and lube when you wash your bike at the end of the week. If you have 4 or 5 bikes that you rotate then maybe once every three or four weeks. If on the other hand you only ride 100 miles or less a week you can use wd40 as a cleaner/lubricant every 3 to 4 weeks.
If you have removed manufacturers lube with paint thinner , mineral spirits etc, wd40 will not be enough. You'll have to resort to one of the methods mentioned here. Other wise wd40 works to both clean and lube when manufacturers lube hasn't been removed. .
Tip, using a rag as a back stop, simply spray chain as you turn cranks slowly making sure to wipe at the same time.
Quoted: 206 Post(s)
Liked 102 Times
In the shop I used to work at, the mechanics only used WD-40 for loosening and cleaning parts. They used Tri-Flow for cables, pivot points, and derailleurs. Chain lube, which has a different viscosity than Tri-Flow, was used on the chains. Different products for different applications. That said, and lubricant is better than none.
Some days, it's not even worth gnawing through the restraints.
Quoted: 4792 Post(s)
Liked 3,918 Times
Stick with the TriFlo. Good stuff. I've used it for decades. I occasionally drift off to something else but always come back. I buy new chains,install and just wipe off the factory grease as best I can. When the chain starts squeaking, I love it with TriFlo, not removing the original grease. Then it is just wipe and lube until it is time for a new chain. Clean the cogs and chainrings and repeat. Easy.
I've done fancier routines but never saw that the extra work and expense did anything to make my chains last longer. Biggest drawbacks to TriFlo - it turns black as soon as you ride it and looks very dirty. It doesn't last forever and far less so in the rain or with washes. (No big deal; just lube it again.) On my winter bikes I use Finish Line wet lube for MTBs. Picks up dirt but lasts far longer. I have less fancy drivetrains on those bikes so it isn't a big deal that it is a lot dirtier.
Ben
Ben
Mad bike riding scientist
Quoted: 6200 Post(s)
Liked 4,204 Times
But Tri-flow isn't all that much different in terms of viscosity and, frankly, messiness. It's still an oil, it still gets on everything and the results are a black, oily messy chain that has to be cleaned constantly.
Stuart Black
Stuart Black
After all the people thinking its useful, WD 40 [(the 40th attempt at a Water Displacement product ) ,
( one that is used in large quantities on, like, hosing out the Jet engines,
when your aircraft overshoots the runway and lands in Jamaica Bay)]..
The Company now makes a bicycle chain lube in its multi product lineup, If you seek it out..
But as above Triflow , is popularly used on bike chains, a lot..
Bikes: '8? Ciocc Mockba 80, '82 Ron Cooper, '84 Allez, '86 Tommasini Racing, '86? Klein Quantum, '87 Ciocc Designer 84, '95 Trek 5500, '98 Litespeed Classic, '98 S-Works Mtb
Quoted: 226 Post(s)
Liked 309 Times
Dean
Roll Me Up and Smoke Me When I Die
Quoted: 4225 Post(s)
Liked 2,945 Times
I prefer Chain-L, but that's just me. I'm pretty lazy when it comes to maintenance, but it does the job.
Liked 2,945 Times
Hey, I don't think we've done one of these since we migrated to the new forum style. It was time.
PEOPLE! PEOPLE! SCIENCE HAS PROVEN THAT LOCALLY-SOURCED, ARTISINALLY RENDERED, UNICORN FAT IS THE BEST CHAIN LUBE.
end of discussion.
end of discussion.
Bikes: (2) 1994 Cannondale R900, red, Silver Trek hybrid
Quoted: 69 Post(s)
I have always thought of WD40 as just a cleaner and not a lube. I like to clean the chain with it, let it dry then apply tri-lube. My opinion, and I think I'm in the majority.
Liked 2,945 Times
the company sells a line of bike products however WD-40 Chain Lube cant tell if they are any good.
Liked 4,204 Times
You are spot on correct.....WD-40 was developed to be a water dispersant and this brew was the 40th blend. It does an amazing job of restoring conductivity to electrical connectors that have become soaked in water. Like others who have posted here, my experience is WD-40 does not make a good long term lubricant.
Dean
Dean
As for restoring conductivity, that's questionable as well. It might do so for a little while but the oil that is left (25% of the volume of WD40 used) is going to play havoc later on down the line.
Stuart Black
Stuart Black
Quoted: 5223 Post(s)
Liked 3,579 Times
they (the WD-40 brand) now makes bike products. I used their wet lube this winter. kinda thick & a little smelly for indoor application, especially if you get some on the floor, ugh. it seemed to work OK even through wicked sloppy conditions & modest bike washing
The Fat Guy In The Back
Bikes: '81 Panasonic Sport, '02 Giant Boulder SE, '08 Felt S32, '10 Diamondback Insight RS, '10 Windsor Clockwork, '15 Kestrel Evoke 3.0, '19 Salsa Mukluk
Quoted: 320 Post(s)
Liked 174 Times
I use WD-40 on my winter commuter bike as a cleaner and to free sticking links. The salt and chemicals they put on the road here eat chains at an alarming rate. I generally lube my chain on Sunday nights and by Friday it's completely dry and I have links rusting together and starting to skip. So I'll give the whole chain a good dousing of WD-40 to get the links free. I'll then wipe as much of it off as I can, along with all the accumulated muck on the chain. Then I follow it up with a thicker oil (chainsaw bar oil mixed with mineral spirits) for the actual lubrication.
WD-40 doesn't touch any of my other bike chains that I ride the rest of the year.
Visit me at the Tundra Man Workshop
Thanks for all the replies! The second guy who told me recently that that's what they use is a volunteer in a bike coop and that's where we were when he told me! I was quite surprised as he fixes up a lot of the donated bikes. I didn't know WD 40 now makes bike specific lube. I don't believe that's what he was referring to - I'm pretty sure I saw the familiar blue can in his hand when he said it. For cleaning chains, when I used to, I would buy whatever a country had when I was in it (touring). Mineral spirits here, white gas sometimes in other countries and other stuff. Didn't know I could use WD40. Good to know. Thanks again.
