Origami Wasp!
#101
Bikes: Origami Gazelle, Origami Crane 8, Origami Cricket 7
Quoted: 452 Post(s)
Liked 405 Times
It's a freewheel. I'm swapping out the cassette,... A 7 speed compatible with my 7 speed freewheel. The part that's changed is called a "cassette". Thanks for the concern, I did my research. I almost purchased a 7 speed megarange by accident. I want top end, not bottom. My wheel is compatible with what I plan to do.
Paul Pinigis
Owner of Origami Bicycle Company
Paul Pinigis
#102
55+ Club,...
Bikes: 9+,...
Quoted: 1112 Post(s)
Liked 848 Times
OH NO!!! The chainring is big enough,...I'm just getting some practice playing around with this. I'll enjoy the personal challenge.
#103
Bikes: Muddyfox Evolve 200, Bicycles4u Paris Explorer, Raleigh Twenty Stowaway, Bickerton California, Saracen Xile, Kona Hoss Deluxe, Vertigo Carnaby, Exodus Havoc, Kona Lanai, Revolution Cuillin Sport, Dawes Kingpin, Bickerton, NSU & Elswick Cosmopolitan
Quoted: 297 Post(s)
Liked 33 Times
https://en.wikipedia.org/wiki/Cogset
Shimano don't make a 11-28 freewheel and if they did it likely wouldn't last long due to the smaller ratchet mechanism and pawls if you were making heavy use of the 11T cog. 13T is normally the smallest cog on a decent quality modern freewheel (Shimano/Sunrace) and I think 14T is recommended for European and American adults.
#104
55+ Club,...
Bikes: 9+,...
Liked 848 Times
A freewheel and cassette are two different things. Many manufacturer's like to blur it and try to mislead the consumer by making you think a bike has a cassette rather than freewheel but they aren't the same.
I have no intention of buying parts without doing research and asking questions. Relax,...
Update: the "cassette sprocket" is also available at JensonUSA. And it's compatible,...
#105
When I get the tool to remove the rear cogs I'll check it out and see exactly what's there. @Pinigis can verify also if it's threaded or not. Also, the seller is in Japan and answers questions, so I'll also be able to get info that way as well.
M.
#106
55+ Club,...
Bikes: 9+,...
Liked 848 Times
Tds, as an aside how were the hub bearings on your Wasp? My Crane came in last evening and I thought the hubs were a bit "gritty". I did most of the assembly but there's a few things I can't do, so I'm taking it by a bike shop for a once-over (a couple spokes seem like they need to be tighter and while trying to adjust the brakes I found the rear wheel is a bit out of true).
M.
M.
Concerning the rear "cassette sprocket", here's the nonexistent shimano component I plan on using: CS-HG41-7
#107
Quoted: 452 Post(s)
Liked 405 Times
Paul Pinigis
Paul Pinigis
#108
Quoted: 452 Post(s)
Liked 405 Times
I have yet to disassemble the wheel, so I'm not sure.
Paul Pinigis
Paul Pinigis
#109
55+ Club,...
Bikes: 9+,...
Liked 848 Times
#110
55+ Club,...
Bikes: 9+,...
Liked 848 Times
Here's the cassette sprocket on the Wasp:
#111
Quoted: 452 Post(s)
Liked 405 Times
That's a damn good question. I have to go back to the original components list and see when the substitution took place. On the bright side, we provided something better than we promised.
Paul Pinigis
Paul Pinigis
#112
55+ Club,...
Bikes: 9+,...
Liked 848 Times
Now, can you find out if it is the splined freewheel please,... This way the parts party can commence!!!
#113
Quoted: 297 Post(s)
Liked 33 Times
#114
55+ Club,...
Bikes: 9+,...
Liked 848 Times
#115
Yeah, the MF-TZ21 is definitely a threaded freewheel. Going IGH would be pretty slick, though it looks like vertical dropouts so chain tensioner it is.
M.
M.
#116
55+ Club,...
Bikes: 9+,...
Liked 848 Times
Yup! I have a chain tensioner on my 8 speed igh non-folding bike. My only issue is a flat or 2.
#117
55+ Club,...
Bikes: 9+,...
Liked 848 Times
I just need new tires,...they're kinda old. Some Schwalbe Big Apple or Big Bens will do. And I don't use slime,...I've personally never had a good experience with it.
#120
Quoted: 452 Post(s)
Liked 405 Times
The TZ21 is definitely a threaded freewheel. The splines that you see from the front in the photo are just for attachment of the tool to remove the gear set.
Paul Pinigis
Paul Pinigis
#121
55+ Club,...
Bikes: 9+,...
Liked 848 Times
Thanks pinigis!!!
#122
55+ Club,...
Bikes: 9+,...
Liked 848 Times
My threaded freewheel upgrade is about to be shipped!!! Woohoo!!!
#123
Stardust
#124
55+ Club,...
Bikes: 9+,...
Liked 848 Times
I noticed. I made sure to order from Amazon, so if anything happens within the return period, I'll be able to send it back. I've never had a problem with Prime,... Hopefully this freewheel will be up to snuff!
#125
Interested to hear how it works out; thinking about gearing mine down for pulling trailers, but I might go for a smaller chain ring instead.
M.
M.
