Saddle Clamp Assembly - ups and downs...
Quoted: 1372 Post(s)
Liked 1,751 Times
This Sekine SHS270 is a recent acquisition, in "as found" condition and it got me to thinking. Which was does a non-integral saddle clamp fit. Which side goes up and which down, or does it matter...
Bikes: A Few
Quoted: 156 Post(s)
Liked 63 Times
I think they look a little better facing up, tucked under the seat more that way - But that's just me.
Probably not much difference in function, as long as they don't actually hit the seat underside.
Bad example
Quoted: 823 Post(s)
Liked 202 Times
I’ve never tried it that way, but I have wondered if it could work. I agree it would be less clunky looking.
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Practically speaking, flipping it from one way to the other can give you that critical inch (either up or down) when you need it. Generally, the bolt goes behind the post to get the seat position right relative to the centerline of the crank.
Liked 1,751 Times
Based on visual appraisal, alone (not to mention that it appears rails on top is most common), I think the assembly would be stronger with the clamps above the bolt, in the event of saddle clamp failure (not sure if that has ever happened). None the less, think I will go out and switch the clamp, to rails down) on the Sekine before I go back to work on the rock wall...
Liked 1,751 Times
Rail clamps up...
Rail clamps down and going for a test ride after the rock wall, then crafts with the youngest grand daughter and - nope, then time for a ride, even installed a set of SPD pedals...
Though I had forgotten that the lady had asked for that spoke protector to be removed, I did so and it has been hanging on a beam, under my summer cottage, ever since. Cleaned it up, this morning, and plan to put it back where it belongs, if the new owner wishes it so...
Quoted: 1607 Post(s)
Liked 2,216 Times
Anyone configure with rails down and then have interference with the saddle once it is broken in?
Is this the reason Brooks saddles have so much distance between rails and leather?
Quoted: 4722 Post(s)
Liked 3,036 Times
Typically, the bolt is located behind the post and below the rails. This maximizes the bolt exposure for ease of adjustment. If the bolt is above the rails, access is more restricted with some saddle types. Also, if the bolt is located above the rails and is insufficiently tightened, there is a possibility of the rails popping out of the cradle. I have placed the rails below the bolt, in cases where very short riders needed another 1" of saddle drop and smaller frames were not available.
Bikes: A Few
Quoted: 156 Post(s)
Liked 63 Times
They are technically stronger with the bolt under, but as with many things, it's a judgement call, I think.
I've definitely seen some of these that are worse quality than others, with thinner gauge stampings,
and poorly formed clamp shape, and some that are pretty robust and solid.
So it depends.
PS - I wish all dork discs looked as nice as that - I might tend to keep more of them on
So it depends.
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 981 Post(s)
Liked 631 Times
Imagine if there was one reading "Campagnolo". They would sell for serious money on eBay.
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Liked 1,751 Times
Speaking of the Sekine dork disc...
Years ago, while riding this lovely old Sekine, I had to stop for a traffic light. Coasting to the curb, I uncliped and waited. While waiting a lady, close to my age I guess, walked up to me and, looking at the back of my bike, said...
"Are you looking for sex?" Surprised at the abruptness of the question, I, none the less, kept my cool and said "yes". I then her why she would ask a stranger such a question. As she answered, she glanced at the rear wheel and commented on the dork disc...
She had, mistakenly I guess, thought it said "Seking Sex". True story and this is the bike that proved, almost, to be a chick magnet...
JoeBass
Classic & Vintage
23
10-02-23 03:25 PM
Jseis
Bicycle Mechanics
8
08-08-14 10:25 AM
