Any idea how this comes apart?
SE Wis
Quoted: 2740 Post(s)
Liked 3,388 Times
What does it say on there? Something stem
I'll assume you looked through this stuff.
https://www.lookcycle.com/en/mounting-instructions/
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 674 Post(s)
Liked 738 Times
First I'd treat it like a quill stem. Loosen the top bolt a few turns but don't remove it. Tap it down (maybe leave the Allen key in and tap that). If it moves, the stem is now loose.
Quoted: 1814 Post(s)
Liked 923 Times
Is there a bolt under the cap?
That would be the quill stem bolt- do what andrewclaus says above.
& probably remove the exposed allen bolt as well to disconnect the stem from the fork.
Man- they come up with some complicated ****!
Bikes: A Few
Quoted: 156 Post(s)
Liked 63 Times
Here's a link to a page with a patent drawing of this set up - It's called a "Monoblade" fork -
I can't get just the image out - It won't let me do it, so that's all I got.
Anyway, it looks like there's a hollow axle of some kind that passes through a couple bearings -
Probably held in by that allen bolt you removed.
If you can't find a way to get that tube out of the bearings, then I don't know .........
https://issuu.com/lookcycle/docs/white_paper_796_bd
PS - Why is it that the French have to make things so mechanically difficult ?
Quoted: 674 Post(s)
Liked 738 Times
Quoted: 4559 Post(s)
Liked 2,802 Times
I can't get just the image out - It won't let me do it, so that's all I got...
- Click on the browser's "view source" option.
- Search (usually Ctrl-F) for image files, usually jp* for jpgs or jpegs. Sometimes PNG.
- Right click to view in a separate window or tab.
- Link to or download the image for future reference.
