Quill stem for threadless fork
South Carolina Ed
Bikes: Holdsworth custom, Macario Pro, Ciocc San Cristobal, Viner Nemo, Cyfac Le Mythique, Giant TCR, Tommasso Mondial, Cyfac Etoile
Quoted: 344 Post(s)
Liked 291 Times
I just bought a Viner Nemo frame with a steel 1" threadless fork off of Ebay. I have some old Campy parts to hang onto it and more to buy. I saw this quill stem that it say is for threadless forks. Is this a typo or will it work? Thanks.
https://cgi.ebay.com/120mm-KALLOY-QUI...QQcmdZViewItem
juneeaa memba!
Bikes: Crap. The box is not big enough...
Quoted: 13 Post(s)
the threads on a conventional fork are what holds the fork in place (well, the nut that threads onto the threads...). With a threadless fork, the clamp-on stem is what actually holds the fork in place. If you mix technologies in either direction, you will be unable to secure the fork to the frame.
South Carolina Ed
Quoted: 344 Post(s)
Liked 291 Times
That's what I thought, but I prefer the look of the quill stems. The bike's gonna a be an eccentric piece an I want all of the parts to be shiny and skinny;-)
Well, you could jig something up. You could use a clamp to hold the steerer in place, then use the theaded stem. You'd probably need to cut some threads into the steerer so that you could put a locknut on it so it looks good.
Kind of like how Sheldon Brown (pbuh) did but he used a threadless stem.
South Carolina Ed
Quoted: 344 Post(s)
Liked 291 Times
This probably isn't going to work. There is a reason that things are designed the way they are. Like it or not threadless is a superior set up, quills work just fine but they are in no way better so why revert back to dated technology. There is no reason to have a janky set up like that chances are it won't fit anyway. You would be much better served looking for a lugged threadless stem.
The Improbable Bulk
Bikes: Many
Quoted: 5 Post(s)
Liked 7 Times
Sheldon used a quill stem in a similar configuration on his multi-handlebar...
https://sheldonbrown.org/thorn/index.html
A threadless system with a clamp (Sheldon used a seat post clamp on the bike listed above) can accomodate a threaded stem.
I would only try it with an alloy, or preferably steel, steering tube...
From what I understand a threadless steerer is the same as a threaded steerer except that...
(drum roll please)
... it doesn't have threads.
(drum roll please)
Slow Ride Cyclists of NEPA
People do not seem to realize that their opinion of the world is also a confession of character.
- Ralph Waldo Emerson
Except for the fact that the whole point of threadless was to reduce weight, and alot of the time the wall on threadless tend to be thinner because they dont need any extra mass to make up for the cutting. Also just because it can be done doesn't mean it should be.
Look for something along the lines of this
https://cgi.ebay.com/Lugged-steel-ste...QQcmdZViewItem
Or.
https://cgi.ebay.com/LITESPEED-TITANI...QQcmdZViewItem
Or keep an eye out for a threadless Cinelli Grammo. That is a good looking stem but I cant find a good picture
Or.
I'd be careful threading the steerer tube if you want to put a locknut on it for aesthetics. Just thread it enough for the locknut to go on, but not all the way to the clamping area. It might be hard to find the right tool to thread the steerer. I have not checked all LBSs but I have heard that most only have the die to chase the threads or the one to extend the threads, not the one to start the threads. A frame builder might have the correct tool.
I agree with you, a good looking quill stem is much better looking than any threadless stem. I want to find a quill stem that has a pop top so that I can buy the bars I want. Right now I have one of those adapters to be able to use the threadless stem on one of my bikes. Just not the same. But, so far, the only ones I can find are welded and I hate those more than threadless.
South Carolina Ed
Quoted: 344 Post(s)
Liked 291 Times
https://cgi.ebay.com/ws/eBayISAPI.dll...m=180198240304
I think the fork really goes with the frame and reduces the option of going with a threaded fork.
