Smartphone app
Bikes: Spcialized RockHopper (free) 1992 Trek T100 Tandem ($220) 2006 Quintana Roo Seduza ($350) 2016 Giant Fastroad ($1100)
Quoted: 46 Post(s)
I use Runtastic Road Bike Pro ($4,99) and pair with SungDing BlueTooth cadence/speed sensor ($14 on Amazon).
Quoted: 6193 Post(s)
Liked 4,810 Times
A while back I tried oruxmaps. But only half-heartedly as I have an edge 500 that I've used for many years. It does a lot. Not just cycling. However it was a little more work to use than my 500.
Quoted: 7 Post(s)
Hi,
To bobwysiwyg
With Strava, can you see data in real time while we are biking? (speed, distance, heart rate with Garmin chedt strap, etc)
Do you have capture of the screen while biking?
To hcgaloi
Same questions.
Thank you
To bobwysiwyg
To hcgaloi
Same questions.
Thank you
Quoted: 941 Post(s)
Liked 319 Times
Yes, Strava will display continuously provided you set your phone display to not shut off. However, keeping the screen on in conjunction with GPS location, you'll go through your battery pretty quickly.
Quoted: 7 Post(s)
Also, I have a Garmin 920xt.
Would it possible to send the data from my watch to my phone and monitor the data in real time?
Quoted: 941 Post(s)
Liked 319 Times
Just a matter of pairing them. I use a different HR monitor, and Wahoo cadence, speed, etc. For visual check along the way, I use Cateye computers. I prefer the Strada for the larger number display but it doesn't include cadence which is ok with me.
Quoted: 46 Post(s)
Runstastic Road Bike Pro displays metrics and map in real time, and you can also view historical data after rides. An added feature is you can set voice announcement per time , distance, cadence intervals while riding.
Quoted: 7348 Post(s)
Liked 2,470 Times
I use ridewithgps. I usually connect an external battery so my usage won't drain the battery, and the result is often that my phone is more charged at the end of a ride than when it started. On long rides, I set the phone to keep the display on. I use a Quad Lock mount to mount my phone to the handlebar.
Rollerdave
25
06-17-14 10:43 AM
anga
14
12-25-13 08:18 PM
