Italian City MTB Build - Which bars?
Bikes: 1986 Torpado Beta, 2006 Wilier Triestina Izoard
Quoted: 73 Post(s)
Liked 15 Times
So I'm building a city/urban/MTB bike out of my Torpado frame since I've now got the Wilier but I'm not sure which handlebars to go with. I'd like something a bit more comfortable but also something I can still ride 20-30 miles if I want to. I was going to just go with standard flat bars but now I'm thinking bullhorn. Any thoughts or info on these bars? I haven't really ridden them much, of course flat bars now and then in the past but never bullhorns.
What do you guys like for comfort and versatility? I've read a bunch about all kinds of bars but still unsure which way to go.
Many thanks for opinions, info, rants, hatred and love for any bars or even another bar type I haven't mentioned.
The frame is a road bike frame in the perfect road bike size for me so not sure if that matters. And I don't mind modern components as I'm not period correct when it comes to bikes; I prefer lighter parts that work.
The bike in question, early in the build. Probably will go Campy 10 speed but not sure on the shifters yet; either Campy flat bar shifters, Campy standard 10 speed shifters, or third party flat bar shifters that are compatible with Campy 10 speed derailleurs if there is such a thing?
Quoted: 821 Post(s)
Liked 255 Times
I'm going with MAP/Ahearne bars for my CSI single speed.
https://www.ahearnecycles.com/shop/ahearnemap-handlebar
Might be some ideas in this thread.
https://www.bikeforums.net/classic-v...-distance.html
Quoted: 1946 Post(s)
Liked 2,004 Times
Nitto North Roads. I had a pair on my PX-10 for a while before I put them on my daughter's fixie. Pretty awesome.
RUSA #3100
Bikes: Yes
Quoted: 237 Post(s)
Liked 505 Times
Condorina bars are the most quintessentially Italian city bike bar!
https://www.somafab.com/archives/product/condorina-bar
https://utahrandonneur.wordpress.com
I am finding the albatross bars very comfortable. I had been using north roads, but the albatross bars allow for at least one additional hand position.
Bianchi Goddess
Quoted: 2926 Post(s)
Liked 2,921 Times
These aren't really 'trekking' bars but what about something like the Scott AT-2 bars? The are ot too terribly wide, at least mine don't seem to be, and offer two hand positions
Sugar "Kane" Kowalczyk
Quoted: 821 Post(s)
Liked 255 Times
I wonder what brake levers would work with this one?
RUSA #3100
Bikes: Yes
Quoted: 237 Post(s)
Liked 505 Times
Quoted: 1372 Post(s)
Liked 1,749 Times
I built up my Motobecane Grand Jubilee in several versions...
This was the most comfortable for gentle around the cottage road rides...
Quoted: 73 Post(s)
Liked 15 Times
Thanks to all for the suggestions and new ideas. Who knew there were so many different handlebars???
I'm leaning towards bullhorns because of a couple reasons. First, I think I can use more easily obtained Campy 10 speed brifters on them. I know it's not ideal but they should work without too much difficulty in reaching. I would mount them under the bars and at the ends. The only trouble will be routing the cables...
And then the other factor for bullhorn choice is that they allow a bit more aerodynamic posture than other upright bars. I've also read that bullhorn bars feel most like being on the hoods on drop bars which is where I like to be most of the time.
Also, they are narrow which allows better movement through traffic.
Of course, that narrowness won't help in calming the twitchiness on my Torpado so that's a downside. I guess I can always switch to less drastic bars if I don't like the bullhorns.
Any thoughts on bullhorn bars?
And finally, I love the look of a honey Brooks saddle but not a fan of the price or weight. I'll just keep my old San Marco saddle for now but I'll probably want something different as this San Marco is very hard and uncomfortable for me. How is the comfort of a Brooks, both new and used? Do they change much as they're broken in? I also like a San Marco Regal which can be found for much less money.
And thanks so much for all the suggestions, some pretty cool stuff in this thread that I didn't know existed. The condorina bar is pretty cool and unique.
Oh, and I think I'm going with a Cinelli Ant stem which is a short 60mm. I had a 100mm stem on this bike with drop bars but it was a bit of a reach for me. This frame is a 54 with 54cm seat tube and top tube. My Wilier is just a touch smaller with around 53cm for the top tube but that less than 1cm made a huge difference in comfort and sliding forward on the saddle that I was experiencing on the Torpado.
Quoted: 478 Post(s)
Liked 634 Times
Quoted: 478 Post(s)
Liked 634 Times
randyjawa I did my Trek 600 -> IGH conversion first as a drop bar but then settled on those same bars....I like them in that they allow a certain amount of forward lean not present on the Nortthroad style bar....not a lot of miles yet on that bike.
Quoted: 1607 Post(s)
Liked 2,214 Times
WRT Brooks, it may be dependent on which one. The Pro is a thicker hide and takes longer, 600 mi, to break in. Others, like the Swallow are thin enough to be comfortable out of the box. Note that your position on the bike should dictate which saddle to use as your sit bones distance changes as you sit up.
You may also have a fit improvement opportunity wrt sliding forward, saddle position and stem length.
