Addiction 2021.1
#1476
Administrator
Quoted: 11955 Post(s)
Liked 6,611 Times
#1477
Administrator
Liked 6,611 Times
Me too.
#1478
Administrator
Liked 6,611 Times
Me too.
#1479
Super Modest
Quoted: 10963 Post(s)
Liked 4,618 Times
It is scary to watch, and in fact, his mother won’t.
Keep the chain tight!
#1480
Quoted: 3350 Post(s)
Liked 3,618 Times
Too easy to come across as pretentious.
The concert I was watching was 45min + 15min or so, with a minute long break where the band disappeared sidestage. They came back and played 3 or 4 of their songs that work the best live. Pretty optimal IMO.
I guess I don't mind as much if it's a headliner at a festival or something, but what I don't get is when bands do that on smaller venues. Just refine your setlist and get it done.
Odds are it's late and I've had fun but I want to go home
#1481
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12740 Post(s)
Liked 7,652 Times
A little breezy today.
#1482
Klaatu..Verata..Necktie?
Quoted: 10397 Post(s)
Liked 11,860 Times
Next stage is supposed to be Big Climbs, including Alpe du Zwift. I haven't decided whether I want to do that, but set trainer difficulty at maybe 50-75%. Or I might do the 'C' ride, which does the Watopia Mountain Route, which has the "Epic KOM", which is less arduous than the climb I just did, but also adds the Radio Tower climb, which is apparently .7 miles of 13.7 % Yikes. Hmmmmmm.....
#1483
he said member
Bikes: yes please
Quoted: 2789 Post(s)
Liked 1,950 Times
a little twitch is ok. If you have problems it will cause the cage to flip when the bad spot passes the jockeys.
Personally I think he may still be having B tension issues, So all this might be related back to his rear derailluer. But it could also be his cable not being seated properly.
Oh the drama.
Oh the drama.
#1484
he said member
Bikes: yes please
Liked 1,950 Times
#1485
he said member
Bikes: yes please
Liked 1,950 Times
#1486
he said member
Bikes: yes please
Liked 1,950 Times
I messed something up when I put new chain on. Shifted PEFFECTLY in the stand. But on the road was finicky, would not downshift properly, I had to click twice down then one up to shift, which is only a minor annoyance. But chain would also “stutter” under severe load like when standing in hills. So I sat for entire ride. There could be a slightly sticky or twisted link on new chain. So far all I checked was indexing back in stand and of course now works perfectly. I am open to suggestions.
edit: sounds like upshift are off too.
Likes For ls01:
#1487
he said member
Bikes: yes please
Liked 1,950 Times
I did Innsbruck tonight, with the Trainer Difficulty set to 100%, so the climb felt... well, pretty much like a 7.4 km climb with a 6% average grade would feel. I'm glad I used the Bianchi, with it's 34x27 low gear. I ended up standing on the pedals pretty much any time the grade went to 10% or higher.
Edit: Now that I think about it. I should look around and see if I have a climbing cassette somewhere. I just realized I'm doing all this with a 53/39 and 25 x12 no wonder I'm grinding all the way up.
Likes For ls01:
#1488
Fat n slow
Quoted: 3257 Post(s)
Liked 2,082 Times
If I hit 5 I’ll be happy unless I can find a way to do 40 before work 3x a week. My bigger problem has always been finding time for longer weekend rides on the weekends I have my daughters.
#1489
Fat n slow
Liked 2,082 Times
Likes For phrantic09:
#1490
VFL For Life
Bikes: Velo Volmobile
Quoted: 28577 Post(s)
Liked 1,849 Times
#1491
Should Be More Popular
Quoted: 22579 Post(s)
Liked 8,919 Times
Oh the drama.
Oh the drama.
#1492
Liked 8,919 Times
Likes For datlas:
#1493
Liked 8,919 Times
Longer weekend rides became more realistic for me as the daughters got older. Time is on your side. In the meantime be sure to spend time with them now. It passes too quickly.
Likes For datlas:
#1494
Bikes: Shmikes
Quoted: 10152 Post(s)
Liked 5,843 Times
Likes For MoAlpha:
#1495
Bikes: Shmikes
Liked 5,843 Times
#1496
Liked 8,919 Times
I had an insight into why my drivetrain is finicky as I woke up early this morning. I could not eyeball the cause until I left for work. But I am pretty sure I know what's wrong.
It's almost too embarrassing to admit, but if you can't admit your bone-headed idiot mechanic moves in here, where CAN you?
Yes, my mechanic is such a moron, he did the all time most AMATEUR move when putting on a new chain.
Chain is on backwards.
I will have to fix it and take it for a test ride to confirm that's the problem, but I am pretty sure that explains the problem.
#1497
Bikes: Shmikes
Liked 5,843 Times
More drama. Or possibly comedy.
Likes For MoAlpha:
#1498
Liked 8,919 Times
Has anyone ever ridden a Shimano drivetrain with the chain backwards? I am guessing the symptoms I described are typical for that mistake.
#1499
Super Modest
Liked 4,618 Times
I'm sure that it's pretty low since he's recovering from CV19 and doesn't even have the breath or strength to lift. He may have returned to the gym now, but a week ago, he still couldn't. I don't know when his next meet is but I bet that he's way behind on his training program now
#1500
Quoted: 20808 Post(s)
Liked 9,450 Times
Actually, now that I think about it, covid increased my mileage in another way - group rides on Wed are typically in the 40-50 range whereas striking out on my own for 62-100 was not unusual last year.
