WTB: 58cm frameset
Quoted: 63 Post(s)
Liked 10 Times
WTB: 58cm frameset
Just discovered my SBDU made Raleigh USA Reynolds 753 frameset is bent. Was kind of my grail bike. Sigh....
Looking for a good condition frame of comparable higher quality for build. Got a Campy 10s Chorus group waiting for a modernized build.
Need 58cm
Ideally British Bottom Bracket
Ideally with headset (I hate sourcing/sizing headsets)
80s-ish w/ 130 dropouts
Open to all ideas; just looking for a cool "keeper" and rider.
Need 58cm
Quoted: 3810 Post(s)
Liked 6,699 Times
58cm center to top? What’s your preferred top-tube length? And wth that component group, I gather you’re looking for something 80s or younger?
Bikes: Numerous
Quoted: 1678 Post(s)
Liked 3,098 Times
In case there is a little wiggle room on your fit.
https://www.bikeforums.net/classic-v...59-ish-cm.html
Quoted: 4511 Post(s)
Liked 6,382 Times
Need 58cm
Need 58cm
Sounds like job for @gugie.
Bikes: 2020 Trek Emonda, 1976 Colnago Super
Quoted: 39 Post(s)
Liked 75 Times
How about an Italian frame? I have a Viner that I specifically bought to do a retro build. It is a 58cm. I think its a good frame but its not like taking a Colnago or Masi and doing a retro build. I know you said English BB but I may be able to provide an Italian BB for you. It needs to be painted. May be more than you wanted to do, but I thought I would throw it out there.
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,800 Times
Operators are standing by...
Quoted: 63 Post(s)
Liked 10 Times
How bad? I am sure you know it can probably be straightened and you're in a good place for that. This frame is easily one that should be fixed. How about some pics and what led to just discovering it?
I've got a 23-1/2", '78 Raleigh Professional that I need to sell. It is currently built up but that can be fixed. It sounds like you are close to me if you want to take a look.
Quoted: 63 Post(s)
Liked 10 Times
Liked 6,382 Times
Okay, best I can do with pics here.... Hard to see. But hope the tilt in handlebars is apparent? I was told the headtub and seat tube we out of alignment to cause it, and in the shop, I think I could see it. At home, to be honest, hard to tell, though the lean in the bars is clear to me.
To my eye, the bars are cocked in the stem, look at the spacing of the bars where they enter the stem on each side. Might be a mismatch that finally manifested itself.
I would meetup with @Dfrost and @RiddleOfSteel at their bike co-op for proper C+V evaluation.
Even if this is a frame issue, it should not be life threatening, a good frame builder should be able to make short work of this.
I would encourage you not to consult anyone that does not have steel framebuilding experience.
Bikes: 1970s Coppi/Fiorelli beater, 1973 Raleigh Competition, 1972 Bob Jackson, 1970 Cilo Sprint-X, 1985 Fuji Touring Series IV, 1969 Legnano Roma
Quoted: 217 Post(s)
Liked 198 Times
cabling hassle aside, you could maybe remove bars & stem and drop them back in backwards (ie. stem reaching over top tube, facing rearwards) and look again -- if the tilt remains in the same direction as it is now, then that would indicate a tilted headtube. but if the tilt moves the other way, then it would indicate the bars/stem junction is the problem and maybe your frame is just fine?
Liked 6,382 Times
Thanks for the nudge of confidence in trying to fix it, which would be my preference. Several other folks have given me the same advice to at least try that (the shop where it was isn't super steel-experienced) so I'm gonna go get another opinion locally tomorrow. Crossing fingers.
Liked 6,382 Times
Master Parts Rearranger
Quoted: 1556 Post(s)
Liked 2,024 Times
A different stem and bar, for comparison, is a cheap and easy thing to do to check (which is something I think you'd want), and I wouldn't put either of those being bent beyond the realm of possibilities. Start with simple things and go from there is my advice.
Liked 6,382 Times
Quoted: 63 Post(s)
Liked 10 Times
Have you considered that the stem and/or bars may be tweaked? If you have some other stems and bars, I would try that to see if you could replicate it. I would think that a HT and a ST out of alignment would be indication of something pretty catastrophic, because you'd have to see the bend in both of them...or cracks at joints, etc. To say nothing of how the headset behaves--does it spin smoothly, bind, or is it loose depending on angle?
Liked 2,024 Times
So, I had a brief bit of time, took it by Aaron's for a second opinion. Pretty much did what you suggested pulling off stem and bars and then got to scrutinizing it and cleaned some, and alas.... yup, revealed a crack at headtube lug. Not sure if clear in pic, but yeah, bummer. Stem was also bent. I know these can be repaired, but don't have that ambition in me with this right now, so yeah, definitely gonna slowly seek out the right replacement frame now!
Ah man, so sorry to hear that! Man, that must have been some impact.
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,395 Times
FYI, 753's heat treating makes cold setting a very poor option.
I believe it could be repaired though, but the heating turns 753 into 531, IIRC. Even for an SBDU, it's easier to dig up another frame than start over.
Wouldn't be the first one damaged either; I have a photo of a 753 SBDU that was front-endered somewhere in the computer. Since it was already destroyed, I put it in the Park HTS-1 straightening tool it to see how long it would take before the heat-treated 753 cracked. Took just a few turns.
EDIT: Found it.
-Kurt
EDIT: Found it.
-Kurt
Quoted: 569 Post(s)
Liked 582 Times
Sorry to hear, I just lost a like new Tange 1 Ironman frame with a lug crack, factory marble paint so respray out of the question. No help to you now but Years ago I bought a custom 753 that was unrideable, Marchetti frame and fork alignment table and $100 to a frame builder it is one of my favorite rides with 1,000s of miles now.
Liked 6,382 Times
More/better pics?
You really need to get it to gugie.
Quoted: 254 Post(s)
Liked 182 Times
I've got this mid-90's Coppi that's about 58 cm c-c seat tube:
I think it meets all your criteria except that the BB threading is Italian, but I'd sell it with the square taper BB that's in it now (also with or without the wheels in the photo).
Quoted: 569 Post(s)
Liked 582 Times
Gut, I really have never liked fade paint and have had 2 resprayed for only that reason, but have to admit that is a sharp paint job I would keep, bet it is a sweet ride as well.
