Go Back  Bike Forums > Bike Forums > Professional Cycling For the Fans
FL's Positive Result: "Splashed On?"
Professional Cycling For the Fans Follow the Tour de France,the Giro de Italia, the Spring Classics, or other professional cycling races? Here's your home...
Old 08-31-07, 01:55 PM
sector99
Guest
Posts: n/a
Quoted: Post(s)
There are numerous ways to deliver hormones to the bloodstream and hence, the urine ... to be later detected by laboratory tests.
One way is to maliciously mix the banned isotope or other substance with water and "Splash" it on the rider as he or she passes close to "Spectators" (Well meaning tour followers often attempt to aid riders in many ways). Skin absorbtion does the rest and the urine sample will test positive as the test sensitivity is extremely high.
I'm surprised this fact hasn't been raised. It's important becuase Landis can never prove a negative (That he didn't take drugs).
All he can do is (1) establish doubt that he intentionally administered the drugs that were found or (2) that the tests or testers were in error and there were no drugs present.
Old 08-31-07, 02:04 PM
G-Whacker
Affable Aberrant
G-Whacker's Avatar
^^True dat
was he "spashed on" during 17? I seem to recall that he was alone with a car for most of the ride.
G-Whacker is offline
Old 08-31-07, 03:56 PM
Keith99
Keith99's Avatar
Liked 3 Times in 2 Posts
Utter Cr@p. Both the original Testosterone to Epitestosterone and the Isotope test are ratio tests and NOT extremley sensitive. Simply put neither one is a is it here or not test. No way either comes back positive through the means you postulate.
Keith99 is offline
Old 09-01-07, 04:50 AM
rusto
Corrosive Attitude
rusto's Avatar
Bikes: 2007 LeMond Alpe D'Huez
Can you define, for the uninitiated, what a "ratio test" is?
rusto is offline
Old 09-01-07, 07:51 AM
SunSwingsLow
SunSwingsLow's Avatar
No way osmosis absorbtion could lead to a positive test.
SunSwingsLow is offline
Old 09-01-07, 11:04 AM
AlexTaylor
Snail-paced new boy
AlexTaylor's Avatar
Bikes: Colnago Extreme Power, Ribble Winter
This is clutching at straws now!
AlexTaylor is offline
Old 09-03-07, 03:46 PM
HigherGround
Descends Like Avalanche
HigherGround's Avatar
Location: Somewhere between Funkytown and Margaritaville, PA
Bikes: Lynskey R240, Sportive, and a Helix Sport disc model in the works; Eddy Merckx MX Leader; Specialized Rock Hopper Comp (1988!)
But what if an unborn twin brother splashed the drugs that were actually meant for his dog, originating from something a relative brought back from South America? (Thanks Hamilton, Vandenbroucke, and Simoni.)
The rider in my avatar is David Etxebarria, not me.
HigherGround is offline
Old 09-03-07, 04:08 PM
joeprim
joeprim's Avatar
The test determines the ratio of two things. In this cas eptestrone to Testrosterstone (forgive spelling please) It is an easire cheaper test that measuring the desired element directly. When FL's ratio was deemed off (the results varied with numbers in bounds and out) then another test was done. This test seemed to show that the testosterone was low. (what would the advantage of that be?).
If you go on line and look at the hearing you get the idea that not only was the ratio somewhat subjective, but so was the second test of the "A" sample and the same test done on the "B" sample.was questioonable. If they were sure that he was guilty the whole mess would have been over a year ago.
Joe
joeprim is offline
Old 09-03-07, 05:15 PM
asgelle
Quoted: 1031 Post(s)
Liked 451 Times in 265 Posts
Since you're following this so closely, you must know that Landis's T:E ratio was high because of a lack of epitestosterone, not an excess of testosterone, which was normal. So tell us, what is the magic compound that erases epitestosterone in the sysetem when applied to the skin?
asgelle is offline
Old 09-04-07, 09:21 PM
sector99
Guest
Posts: n/a
Quoted: Post(s)
The addition of testosterone will change the ratio...cutaneous administration is sufficient to do this.
Old 09-04-07, 11:53 PM
skanking biker
Word. I love the "the machine gave bad numbers so I used my own" testimony.
skanking biker is offline
Old 09-05-07, 01:06 PM
Keith99
Keith99's Avatar
It is a test where the ratio of 2 different things gives the final number. In this case it is testosterone to epitestosterone. Both are produced naturally in the body and they are produced by interrelated processes.This means that if their ratio is outside of a given range something is wrong. For athletes if the ratio is high the logical conclusion is that they took testosterone.
A related kind of test is a concentration/level test. Blood Alcohol level is a well known one. Too high and you are in trouble. Again alcohol is a naturally occuring substance and some should be expected in the blood.
Keith99 is offline
Old 09-05-07, 09:03 PM
roadgator
raodmaster shaman
So someone splashed water on him every day he was sampled during the tour? They all came back with synthetic testosterone.
I know there are a lot of Floyd apologists on this board, but this is a little out there as a conspiracy theory.
roadgator is offline
Old 09-05-07, 09:15 PM
roadgator
raodmaster shaman
Considering that it takes concentrated testosterone being applied in a patch right on the balls for hours to absorb any significant amount of test, it seems unlikely that enough could be splashed on a rider, and stay there long enough to trip the test.
You are also assuming someone had the motivation, means, and foresight to be waiting on the side of a hill for him. This is bike racing.
The only sabotage theory I find plausible is that a lab worker broke protocol, matched his vials, and put a drop of roids in before it was tested. But this is even too far out there for Landis' defense team. Considering the stuff they have come up with, thats saying something.
Old 09-07-07, 03:50 AM
meb
meb's Avatar
Liked 5 Times in 4 Posts
Was that application point specified because it is where it is most effective or simply where it is least conspicuous?
meb is offline
Old 09-07-07, 07:27 AM
roadgator
raodmaster shaman
I've heard its the most effective, but I'm no doctor.
Old 09-09-07, 12:28 AM
musician
cracked
musician's Avatar
Bikes: 07 Felt F5C, 93 Bridgeston MB-3
ROTFLMAO - thanks for this post.
musician is offline
Old 09-17-07, 05:57 PM
Helmet Head
Helmet Head's Avatar
What if an unborn twin brother splashed the drugs that were actually meant for his dog, originating from something a relative brought back from South America, while he missed a test because he was in Mexico (actually in Italy), had extra blood with a different blood type due to recovering from a leg injury, and transformed his body to be a climber due to cancer recovery?
Helmet Head is offline
