powdercoaters forgot to mask off the spindle interface on cranks
I recently had my cranks powdercoated and noticed that they either forgot to mask off where the spindle drives in (square taper) or they got confused because they did a great job masking off threads where the dust caps go. I would've have preferred the other way around. But anyway, how many of you would just run it this way and not bother trying to get the paint off in there?
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
You need the paint out of there, or you will never be able to remove the cranks again. Just get a good tap to clean up the threads.
OK, I just reread it. I would go the paint stripper route. Any mechanical means (such as a small flat file) will remove some of the material.
Guest
Posts: n/a
Quoted: Post(s)
Reread ... the threads are fine. It's the square taper hole that has pc in it.
24fit, you will have the best luck by using chemical paint remover. I use the water rinseable Jasco.
Just use a little brush and apply carefully. Wouldn't hurt to mask the rest of the cranks, just in case.
It's good that they did cover the dust cap threads, 'cause if they hadn't, even a good tap wouldn't have helped much, as it's tough to start a big tap like that into pc filled threads.
Thanks for the input. After reading the first reply, I went out an got a wire brush attachment for my dremel, only to find out later that the stupid wheel is too wide to fit in the square. Where do I start with "Jasco" for powdercoat? Where can I get it locally?
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 26 Times
ROFL.
Do you peole even bother reading what the OP wrote before attempting to answer? As for removing the powdercoat inside the taper area, soft wire brush on a drill from the frame side of the crank (pretending it's on the bike) will do.
There are wire brushes that fit through the taper hole.
Quoted: 2026 Post(s)
Liked 1,096 Times
I agree with the chemical stripper approach. Even a soft wire brush is harder than the aluminum crank arm and can remove metal from inside the square hole. If it does, the spindle will never fit properly.
Eastwood sells both powdercoating supplies as well as strippers. You can get your own little powdercoat rig setup. And of course you can get some stripper to remove what powdercoat you want to remove.
https://www.eastwoodco.com/jump.jsp?i...ORY&itemID=458
cdr
cdr
Quoted: 443 Post(s)
Liked 27 Times
cdr
cdr
Liked 1,096 Times
Bikes: Raleigh Classic 15, 84; Miyata 912, 85; Miyata Ridge Runner SE, 85; Miyata 610, 86; Miyata 100M, 86; Miyata Valley Runner, 88; Miyata Triple Cross, 89; GT Karakoram, 90; Miyata Elevation 300, 91; Marinoni Touring, 95; Long Haul Trucker, 2013
Quoted: 159 Post(s)
Liked 133 Times
The eastwood stripper doen't need an oven:
https://www.eastwoodco.com/shopping/p...roductID=16495
...but, really I think the people who did the coating should fix this.
Quoted: 1109 Post(s)
Liked 1,200 Times
Why not ask the guy that did the powder coating to clean it up for you since he made the mistake. He probably not only has the stuff (chemical, whatever) and also has the experience to do it w/o messing up anything. Just a thought.
Quoted: 118 Post(s)
Liked 50 Times
Make a sanding stick and sand it out. Get a square strip of wood that will fit into the bore with two wraps of sandpaper on it. When wrapping the sandpaper, each time you come to an edge, scribe along the edge with a pointed tool. It will fold easily and cleanly. After two wraps, staple it on the side with the end. I'd use 200 grit. bk
