tire size question for my Le Tour
Old 11-04-12, 09:15 PM
wardie
Bikes: Giant OCR 3, Kubachi, Trek 820, Iron Horse Trail, 74 Schwinn LeTour, 95 Schwinn LeTour, Ross Euro Tour, Miayata
Quoted: 10 Post(s)
I have a Schwinn Le Tour s/n M5H105832 that I've been changing over for the past two seasons to touring. It has Araya 36 hole rims and the LBS installed racks and fenders. When I got the bike back they installed these thin tires 700x 23's they said they couldn't go bigger because the fenders would contact. I am looking for a solution I really do need fatter tires at least 700 x 28's any suggestions? Wardie
wardie is offline
Old 11-05-12, 02:49 AM
seeker333
seeker333's Avatar
Bikes: yes!
Quoted: 282 Post(s)
Liked 38 Times in 36 Posts
remove fenders, mount larger tires
seeker333 is offline
Old 11-05-12, 06:32 AM
bradtx
Bikes: Cannondale, Trek, Raleigh, Santana
Quoted: 308 Post(s)
Liked 3 Times in 3 Posts
Wardie, The shop may exchange the fenders and tires so contact them first. If the Le Tour was originally equipped with 27" wheels there should be ample clearance for 28 mm (possibly 32 mm tires) tires and fenders.
Brad
bradtx is offline
Old 11-05-12, 08:32 AM
LeeG
Quoted: 137 Post(s)
Liked 81 Times in 64 Posts
Is it possible the fender mounts at the bridges stick too far down and different attachment would fix that? I thought LeTours could easily take 32mm tires. Get the tires you want then modify the fenders to fit. What year is the bike?
LeeG is offline
Old 11-05-12, 09:39 AM
saddlesores
saddlesores's Avatar
Bikes: inferior steel....and....noodly aluminium
Quoted: 1053 Post(s)
Liked 341 Times in 229 Posts
700c is bigger than 27", so you've reduced the space available
between the tire and the fenders. a wider tire is going to be
taller than a narrow tire.
mount your rear fender to the underside of the rack.
a wider mtb fender will catch more of the spray than
your thinner 27" dealies.
*edit* damn, i was sure i remembered the measurement was
of the tire's outside diameter. but then, i haven't run 27"
since about 1988.
saddlesores is offline
Old 11-05-12, 09:48 AM
staehpj1
staehpj1's Avatar
Quoted: 1251 Post(s)
Liked 754 Times in 560 Posts
Not true. A 27" wheel has a 630mm bead seat diameter, while a 700c wheel has a 622mm bead seat diameter.
Bottom line the 700C is smaller diameter than the 27" despite the confusing nomenclature.
staehpj1 is offline
Old 11-05-12, 10:48 AM
LeeG
Quoted: 137 Post(s)
Oops, newer LeTours look to be more road bike in clearance.
LeeG is offline
Old 11-05-12, 12:26 PM
ksisler
Quoted: 25 Post(s)
Agree with others... most fenders can be improved by improving the mounting points. If you are still at the stage of needing to pay a LBS to put on tires and fenders, you are not likely to have the skills at hand (yet) to massage or redo the fender mounts. The LBS for hire will take the item out of the box and install it following the generic instructions from the OEM.
If you can post some good pix of the mount points with the current fenders, then we can probably suggest if and how you might improve that so you can get back some space for more tire clearance. Note; No comment here from me regarding how big around wheels or tires are; assuming other posters dealt with that.
ksisler is offline
Old 11-05-12, 12:29 PM
ksisler
Quoted: 25 Post(s)
Agreed. Pretty sure that LeTour in French doesn't always translate in English directly to "Touring Bike". More marketing crap than anything else...
ksisler is offline
Old 11-05-12, 03:33 PM
wardie
Quoted: 10 Post(s)
thanks for responses
I should of been clearer. The fender mounts to the brake caliper. These aren't Vee Brakes they are standard road brakes. Fender bracket rides in caliper pinning bolt. No movement necessary I don't know what to do. most touring bikes have Vee Brakes that use studs on the forks to mount them. Maybe a fork change is in order. I don't even like the look of skinny tires with fenders. Just looks wrong. Wardie
wardie is offline
Old 11-06-12, 12:55 PM
ksisler
Quoted: 25 Post(s)
Offer to provide more aide after you provide some pix stands.
ksisler is offline
czr
Singlespeed & Fixed Gear
2
10-07-17 01:35 PM
jonny4947
9
06-21-14 10:51 AM
gorshkov
Touring
3
01-18-12 07:56 PM
abdon
13
05-28-11 03:56 PM
