Blue loctite on clipless pedal cleats screws
Bikes: Canyon Ultimate CF SL Disc, Canyon Spectral
Quoted: 73 Post(s)
Liked 24 Times
I bought a new pair of five ten kestrel clipless shoes recently. I've noticed the cleat is coming a tiny bit loose on every ride. Is it safe to blue loctite the screws?
Quoted: 682 Post(s)
Liked 453 Times
How tight are you doing them up? And I’d have thought threadlock will be fine as long as the screw heads are robust enough to get decent purchase on when it comes to removing them.
Quoted: 73 Post(s)
Liked 24 Times
I'm cranking the screws down tight. didn't use a torque wrench to measure, but they are good and tight. I'll give the loctite a shot.
Likes For wheelreason:
Bikes: 1972 Motobecane Grand Record, 2022 Kona Dew+
Quoted: 165 Post(s)
Liked 148 Times
Blue's fine for this if you feel it's necessary, just don't use a lot of it. Purple's a little weaker, great for temporary use, but can be hard to find, or green which is similar to blue but for use on fasteners that have already been tightened to spec rather than waiting to be assembled.
I tend to prefer the gel versions as they seem easier to deal with not being so liquid as the original varieties. Blue's my most used choice.
Just Don't Use Red unless you really, really, really don't want the secured fasteners to come undone.
Likes For spclark:
Quoted: 4469 Post(s)
Liked 1,606 Times
Greased threads are what is normal, and they don't come loose.
Quoted: 668 Post(s)
Liked 529 Times
Can't say I've even had a problem with shoe cleats coming loose. Maybe a bit tighter. But second the idea of purple locktite. Sort of hard to find, most stores don't stock it, so order on line.
I find that cleats often come loose on new shoes as the plastic creeps and the cleats settle into place. If you go to the full 5-6Nm I think this might not happen; it is tighter than I would do by feel. I also use Loctite 242 or 243 on the screws.
Likes For cuevélo:
Bikes: Handsome xoxo, Serotta atx, Canyon Endurace CF8
Quoted: 904 Post(s)
Liked 1,909 Times
just got new shoes and cleats and I tightened by feel on what I thought was tight. I then used my handy dandy ritchey torque wrench which is factory set to 5 nm and wow I was not even close by feel, tightened up a lot more with the ritchey tool.
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
If these are 2-bolt SPD style cleats, the bolts will be M5 flathead countersunk bolts which use an 3mm hex wrench. A 3mm hex wrench will actually flex noticeably at 4-5Nm of torque which can fool you if you're used to torquing to feel with a 4mm or 5mm hex wrench.
Last edited by Unca_Sam; 09-07-23 at 07:55 AM. Reason: spelling, grammer -4 points
Quoted: 6245 Post(s)
Liked 4,846 Times
Did they give you screws with a hex socket in them or are they Philips or something else? Some Allen wrenches can be pretty short. Which is normally good because it keeps you from overtightening things. Though if you can't get the torque you need with those short Allens, then look for some longer ones.
And make sure it's the proper size. Don't use ANSI fractional sizes in metric sockets or the other way around.
Cantilever believer
Quoted: 550 Post(s)
Liked 1,901 Times
Likes For RCMoeur:
Habitual User
Quoted: 5010 Post(s)
Liked 8,189 Times
If I recall, Speedplay pedals used to to come with the cleat screws already blue-dipped. Based on that, it seems like blue would be a reasonable choice.
Likes For streetsurfer:
Quoted: 581 Post(s)
Liked 921 Times
I use blue loctite. It serves two functions - keeping the bolt from loosening, and keeps water out and prevents the threads from rusting and seizing.
Also you need to make sure the bolts are tight enough in the first place. The 'teeth' on the bottom of the cleat will progressively work their way into the underside of the sole of the shoe and effectively loosen the bolt. If the screws are tight enough when assembled then the teeth will already be seated into the sole.
Quoted: 112 Post(s)
Liked 25 Times
I've used Loctite 222 on cleat bolts for years without ever having a loosening issue.
I use to use wax in the allen socket to prevent dirt accumulating, but just use a pick now to clean out the dirt before unscrewing the allen bolt.
