9 speed cassettes
Quoted: 132 Post(s)
Liked 62 Times
9 speed cassettes
Is anybody having any luck finding these? I am kicking myself for not buying an extra last summer. I guess the ultegra 6500's are gone-gone.
Anything else?
Anything else?
working on my sandal tan
Quoted: 3873 Post(s)
Liked 2,574 Times
Likes For ThermionicScott:
Quoted: 18451 Post(s)
Liked 4,562 Times
Ribble had a good deal on the HG400 cassettes a while ago. And, I accidentally got a double order. So, I think I'm set for life.
Check E-Bay for cassettes. New ones.
If you purchase slightly used ones, look at them very carefully.
Likes For Lazyass:
Quoted: 1630 Post(s)
Liked 2,253 Times
Two critical items that are increasingly difficult to find at a reasonable price are the 26mm lock nut for a Campagnolo free hub and the Ergo 9 speed, either the complete Ergo or the part to convert a 9 or 10 speed to 9.
Quoted: 3261 Post(s)
Liked 2,581 Times
SRAMs are out there.
Bikes: Soma Double Cross Disc (2017), red Hardrock FS (circa 1996)
Quoted: 217 Post(s)
Liked 155 Times
HG50, HG400 and HG200/201 are there. 9 speed cassettes are not going away, you can still get a 5-speed frewheel. (Another question is what Shimano is actually producing given the current problems with supply.)
For me the range and the ratio are the most important, and some of the options will disappear as 9 speed is moved down the hierarchy. For example, Ultegra 6500 had a 12-27, it is gone now. I like the progressions without the big jumps in the middle, for 7 speed it was Shimano "M" (13-15-17-19-21-24-28), John Allen explicitly recommends it on https://www.sheldonbrown.com/k7-7.shtml:
Of all the cassettes listed below, the one I [John Allen] like best is the Shimano M cassette. It has an even progression of ratios, without a big jump in the middle like many other Shimano cassettes (including 8- and 9-speeds!). With triple chainrings, the M cassette provides a very nice selection of drive ratios.
YMMV, maybe you want something more "road" with less range, like 12-26 or 14-25.
Likes For csport:
Quoted: 132 Post(s)
Liked 62 Times
Ultegra 6500 are gone from Shimano range, https://productinfo.shimano.com/#/sp...tte%20Sprocket
I think all of them will shift well -- Shimano, SRAM, Microshift, Sunrace. It depends on what matters for you: cassette range and progression, weight, price?
For 9 speed add 11 and 32: 11-13-15-17-19-21-24-28-32, this combination is made by Microshift (H092) (bikewagon has them on new ebay) and Shimano (HG200/201). Also very nice is Microshift H092 11-34: 11-13-15-17-19-21-24-28-34 -- it has 8 cogs in the 11-28 range plus 34t for tougher hills. Now I have HG50 11-30 (11-12-14-16-18-20-23-26-30) on the bike (spotted by ThermionicScott on Universal Cycles).
Liked 2,574 Times
Unfortunately, no. The spacing is different between 8-speed and 9-speed, so it would throw off your shifting, assuming you're using indexed shifters. Plus, there isn't any room to add another cog because 8-speed and 9-speed cassettes both occupy about the same width.
Quoted: 217 Post(s)
Liked 155 Times
For example, take 11-13-15-17-19-21-24-28-32, remove 11 and 13, add a top position 13 (or 14) and 36. This will make a great touring cassette, 13(14)-15-17-19-21-24-28-32-36.
Quoted: 1956 Post(s)
Liked 2,201 Times
For a standard cassette spacing that is available, it isn’t worth it. There are some times when you might go that route. If you have 9 speed shifters and an 8 speed cassette you don’t want to go to waste, you can space it to 9 and just run 8 cogs; you’ll need to fill up the freehub body with spacers to be able to get the lockring tightened against the first cog.
it is also useful if you want to build a cassette that isn’t made; which I have done more than once. When I don’t need an 11t or 12t, I’ll dump a cog and add a cog. I’ve even mixed-n-match cassettes and loose cogs to build a cassette using parts of 8, 9, 10, and 11 speeds. Forty years ago you could buy individual cogs for a freewheel and do the same.
John
Edit Added: While I was typing, csport beat me to it.
Likes For Ihmemies:
Quoted: 217 Post(s)
Liked 155 Times
Thanks, though they cannot ship Shimano to the US. Anyway, we have to accept that the assortment of 8 and 9 speed cassettes is becoming smaller. Not as small as the 7 speed where they killed all but a few models
Quoted: 1088 Post(s)
Liked 1,207 Times
Since so many of these cassettes are pinned together these days, does anyone remove the pins to allow for more customization?
Liked 2,201 Times
Some people will say that by doing so, there is a risk of indenting the freehub body with the cogs and pinning prevents this. Probably more prevalent with a titanium freehub body. I have not had any problems, but I understand the potential.
My initial reason to unpin was to be able to use 8 speed mtb trigger shifters with a 7 speed freehub by re-spacing the cassette.
These days it is more about mixing and matching cogs to get certain ratios like the old freewheel cog board from years ago.
John
Keefusb
Bikes: 60cm 1992 Paramount, 60cm 1995 Cannondale R900 (son's bike), 1994 Cannondale H300 (mine), 1994 Cannondale H300 Killer V (wife's bike), 60 cm 1989 Eddy Merckx Corsa Extra SLX
Quoted: 83 Post(s)
Liked 58 Times
I have found HG50 9-speed 11-30 cassettes in the past couple of years, and they are great for my aging legs in the hilly area I live in. For the short cage Dura Ace 9-speed RD, you have to pretty much screw the B-screw all the way in to clear the 30T cog, and there is not a lot of clearance there even with the B-screw in all the way.
I might want to pick up a spare HG50 11-30 just to have it.
On the Ultegra 9-speed cassettes, the top 3 or so cogs are attached as a unit on an Alu spider. I don't wear out these, but the mid-range cogs in the 15-19 range. So I buy Ebay cassettes (Sunshine, ZTTO, ZRACE etc.) and just replace the worn 6 cogs like for like. The largest Ultegra (or Dura-Ace or XTR) cogs, which constitute the weight savings, are kept.
Quoted: 1455 Post(s)
Liked 2,065 Times
in addition - Shimano (XT) CS-M770 9 speed cassette is available in 11-32 and 11-34
Keefusb
Quoted: 83 Post(s)
Liked 58 Times
I just picked up a couple of Shimano Sora-branded HG50 11-30T cassettes from Nashbar for $35 each.
Bikes: Dahon Jetstream p8 (sold), customized Dahon Helios x10, customzed Dahon Smooth Hound x11,customized Dahon Hammerhead 8.0 d7, Planet X Free Ranger (mullet setup 1x11), Planet X Giovanissimi 20 (1x9), Frog 52 (1x9) and Frog 48 1s
Quoted: 276 Post(s)
Liked 247 Times
I have HG400 11-25 (cheap because it seems unpopular these days) ready to go for a super light setup with a 36 mtb chainring. the sora range is quite common.
