Early 90’s Allez Pro Restomod Project
I purchased an early 90s (1991? 1992? 1993? 1994?) Allez Pro with yellow lettering on “Silver” paint, advertised on OfferUp as having a 56cm frame, for $275. This model has the special “DiNucci” lugs and slightly oversized CroMo tubing.
My goal is to try to one-up the Specialized 40th Anniversary Edition aesthetically, with similar or better performance. The horizontal top tube is key to this.
The paint has been scratched/peeled off in several places, and I’ll need to address that soon to avoid rust.
Before that, I’ll take it to a frame builder to have the rear brake bridge modified so 28mm tires have enough clearance; I’m thinking to go with an inverted V brake bridge like the Specialized 40th Anniversary Edition Allez.
More critically, I’ll also ask them to straighten the rear triangle; the rear wheel is very, very slightly crooked. it still rolls great, in my uninformed judgement, but I want it to be as good as it can be.
The next step after that is paint. In anything less than bright light, the silver paint just looks dull grey with metallic flakes; IMO, it’s not great. In the sunlight, the paint actually looks awesome. I wavered a bit on whether to keep the current color, but I just hate the yellow lettering. I’m leaning toward repainting it the white-on-red color scheme that can be found on the original and many modern Allez. I’m planning on using the most modern version of the “Specialized” logo on the downtube and the 80’s white-and-silver Allez logo on the top tube. I am planning on replacing all the “Direct Drive,” “Direct Drive Aluminum,” “Designed in California,” etc. exactly as they were, but in white. I’m planning to have these all put under the clear coat. I’m planning to mask off the Cromo tubing decal and the area immediately around it, so that the original decal will remain and so people can see the original color.
For wheels, I’ve already replaced the original spec Mavic Open 4 CD as I hate the look of the partially-worn-through black brake track on the wheels. Plus they are probably the original 25+ year old wheels so they’re likely worn out. Currently I have Campagnolo Shamal Ultra C17s on it, because I like that spoke pattern and because I want wider, lighter wheels. However, I am not sure the wheels really suit the bike aesthetically; there’s too much black on the spokes, hubs, and quick releases. I’ll try to find a way to mod these parts to silver. Failing that, I’ll get some all-silver aluminum wheels that have a cool spoke pattern. If I keep the Shamals, I’ll replace the logo decals with black reflective tape.
The bike came with a 225mm tall 100mm Nitto Technomic quill stem. That’s too tall even at its shortest height. I have a normal-height 80mm Specialized quill stem that I’ll use in the interim; eventually I want to replace it with a polished silver quill stem and matching polished silver drop bars.
I have a NOS 8 speed Ultegra cassette on the new rear wheel, and a new chain. I have almost-new chainrings as well, but I’ve left them off. I am planning to switch to a compact crankset. I’m not sure how practical it would be, but I hope to polish the outer faces of the chainrings silver.
For now I’m planning to keep the existing components, which are Shimano 600 Ultegra tri-color. I hope to polish them to a silver color. A bike shop person told me that some parts of them might be magnesium and not aluminum, so that might not be practical. Maybe I’ll switch to the newest Campagnolo or Shimano silver group set instead, once used group set prices return to normal.
I will at least replace the STI shifters with something more modern, to get the modern, cleaner-looking, cable routing.
Hilariously, the front derailleur cage was broken and a metal piece was welded on to repair it. I find this quite endearing so I’ll keep it as long as I can. Front shifting works reliably, but sounds terrible because (I think) of this.
I have silver MKS Stream EZY Superior pedals on it now. If came with some cool Crank Brothers pedals. It I can adapt them to EZY Superior then I’ll try to swap them in for road rides. Otherwise I’ll try MKS’s SPD pedals.
I’m considering drilling the frame to do internal cable routing, for aesthetic and functional reasons. I will talk to the frame builder to see if the frame would need to be reinforced at the drilled holes. The functional benefit is that the cables would be protected when the bike is hauled around in my hatchback.
The brake shoes/pads were a mix of mountain bike (rear) and some kind of road shoes on the front that required a wrench. I replaced them with new Shimano 6403. Stopping isn’t great but I think that’s likely because I am bad at tuning them. If I can’t get them working great then I’ll probably replace the brakes with newer, silver ones.
Quoted: 574 Post(s)
Liked 616 Times
Wow this is clearly a labor of love, that said I have an early 90's Allez Pro and it is absolutely one of my favorite rides although I did replace the fork. Only thing that hit me strange in your plan is drill that very light frame for housing/cable protection, you are spending a lot already with a framebuilder and I haul mine, being retired we travel a lot, and have never had a problem.
If the integrity of the frame will be compromised then I won’t do the internal cable routing. However, I do think the internal routing looks better and protects the paint. Notice in my pictures where the paint has been worn down to the white primer on the bottom of the top tube. It seems likely that was caused by the cable running against the frame when the bike was handled and/or hung on a bike rack. I want to be able to throw this bike on a car bike carrier without worry.
Quoted: 574 Post(s)
Liked 616 Times
Why did you replace the fork? Which size tires were you running? I’m hoping to keep the fork as it is one of the distinguishing characteristics of this bike. I understand as soon as it gets bent, it will have to be replaced, though.
I hope I won’t be spending “a lot” as I understand the stuff I’m wanting done is straightforward for them. If the frame builder costs are too high I’d probably start over with another base bike for a different project.
Got it, I use those funky spacer things on my bikes with external cable and they work but I also use a cheap hanging by the TT hitch carrier but never with an exposed cable bike. Been thinking about a proper platform type hitch rack as light as I can find.
Hard to believe the someone at the factory thought the ideal color for decals on silver was yellow.
Here’s the state of it as I have been riding it today, with the new pedals, wheels, chain, cassette.
Let me know if you think the yellow hydrant successfully brings out the beauty of the lettering on the bike.
I think this picture, in the shade, illustrates how the bike tends to look grey and not silver when the sun isn’t hitting it directly. Also, notice how light grey metallic paint doesn’t go well with actual polished metal. (The original wheels had black rim brake tracks.)
While I wait for the shorter-height quill stem, I decided to try out the existing one in a configuration that’s more like what the handlebars appear to be designed for. Previously (above) the bars were rotated so that the part between the flats and the hoods was horizontal. That was pretty comfortable but pretty ugly. Now the bars are rotated forward so that the bottoms are about level with the ground. This definitely looks a lot better and provides more variety in how upright vs. forward I want to be. I rode this for a while with various tweaks but it doesn’t seem to be the right configuration for me. Either I have no weight on the hoods, or a lot; there’s no way to distribute my weight between the bars and the hoods. I hope this is a matter of developing more core strength and getting better at distributing my weight on the bike.
When I am riding around town on the tops, I now need a significant lunge downward to hit the brakes. If I can sort out the weight distribution thing then I would solve the latter problem with interrupter brakes. I am going to ride some more and then decide whether/how to replace the bars.
Likes For Allezedly:
It would be good to see a pic of how you have your bike set up. I’m trying to have this one bike be both a commuter bike and a road bike. I am unlikely to ever race, but I don’t want to take away from its racy design or hurt its performance either. I especially love how this bike accelerates, which I think is an underrated quality in a commuter bike.
Quoted: 4568 Post(s)
Liked 6,551 Times
And I'd bet it killed him that the lugs didn't get thinned.
Quoted: 574 Post(s)
Liked 616 Times
Likes For easyupbug:
The MKS reflectors arrived from Japan. I installed them on the pedals and had a go around the block. I felt like the bike was a bit sluggish. I don’t think the reflectors affected the aerodynamics so it must be the weight. Sure enough, I weighed the reflectors and they came in at 22g per pedal (including the nuts and washers)! The mounting hardware is steel, so no doubt it is contributing to make the ride more comfortable. However, the bolts are longer than needed since I don’t have toe clips installed, which means some of this is dead weight. I chopped them shorter (thread nut onto bolt, hold bolt with needle-nose pliers, hold pliers in vice, cut bolt with Dremmel metal cutting wheel, file flat and smooth, unthread nut off of bolt). This saved 2.2g of weight total (1.1g per pedal). More aggressive chopping would probably save an additional gram of total weight. A must-have mod.
Pedal installed on bike.
Original weight of MKS reflectors.
Comparison of a chopped vs unchopped bolt.
Reduced weight.
Reduced weight.
I got some new handlebars and a new Nitto Young 3 stem. Unfortunately, the bars are 26.0m and the stem is 25.4mm, so I need to change one or the other. Nitro’s catalog says their 26.0mm stems are either difficult or impossible to install ergo bars on, depending on the stem, but it doesn’t say anything like that about the Young 3 stem, so I decided to order a b105aa bar. I actually think that might be a better compromise of looks and ergonomics anyway.
Also, I picked up some Campagnolo Centaur 10 speed shifters to operate my 8-speed Shimano 600 Ultegra drivetrain. I love the skeletonized shift levers. Both the shift levers and both the brake levers are aluminum, which I think looks great even as-is. These new brifters are much more comfortable than the 600 Ultegra ones in my initial testing.
I’m having trouble locating goldenrod bar tape to match the goldenrod lettering. I ordered some yellow tape that looked like it would be close, but it is way too bright. I’ll try to darken it in some way. I’m just doing this temporarily while I have the original color scheme on the bike. Any tips for locating already-goldenrod bar tape or darkening bright yellow tape are appreciated.
The Michelins run large. I had some 25's and they were more like 27-28. I have heard others say the same, so I don't think it was my particular rims. Nice tires though.
Likes For due ruote:
The stickers on the rims are gone. The wheels look better, with fewer “please steal these $1,000 wheels” vibes.
The stickers weigh over 7g!
This is how I rode it today, with the Nitto Young 3 100mm quill stem, Nitto 105aa drop bars, and a Fabric flat seat.
State as of Thanksgiving weekend, 2021.
I have been trying to dial in the fit, including the brifter position, so I hacked together a minimal solution for padding on the bars that doesn’t require me to wrap, unwrap, and re-wrap the bars each time.
I am going to have a bike shop do the swap of the 600 Ultegra brifters to the Campagnolo Centaur brifters, replace all the cables and housings, and tune up the brakes and shifting. I did do a test fit of the Centaur brifters on the handlebars and they feel much more comfortable than the original brifters.
I feel like the bend is too tight at the drops on these 105aa bars. I also wish that my bars were perfectly parallel on the top and bottom. However, I’ll reevaluate the fit when the Centaur shifters are installed; maybe they will be comfortable with the bar rotated forward so that the bottoms are parallel with the ground, without too much of a drop from the tops to the brifters.
As I’m now deferring having this related red, I now possess some good bar tape with the right shade of golden yellow that is close to the color of the yellow lettering on the frame. I am considering going with some cable housing that is also golden yellow, but I am not sure if that will work with the Campagnolo cables I need, and I am not quite even sure which diameter Campagnolo cables I need. It will be a minor miracle if I can get the bar tape and housing to match color-wise.
I talked to a couple bike shop techs and they acted like they never heard of mixing Campy 10 speed brifters with Shimano 8 speed, though I have seen many on the internet claim this is the best configuration for 8 speed Shimano. I am reluctant to take the bike somewhere that’s never done this before. I am sure there are a bunch of bike shops in SoCal who know how to do this, but it is difficult to find one.
Quoted: 3467 Post(s)
Liked 2,843 Times
I just purchased a near identical frame set. The paint has issues. It will need to be repainted. the primary graphics for this year/model appear to not be supported yet.
I need to weigh it, appears pretty light.
I like the oversized top tube.
As for the graphics, unless you are going for a full restoration, I’d suggest doing custom graphics or using the older graphics that look much nicer. The only original graphic I’m keen to reproduce is the Direct Drive Aluminum Fork decal on the fork (I’m planning to mask the tubing decal during sandblasting to preserve the original one along with a bit of silver paint around it).
Liked 2,843 Times
Are you finding the paint to be very delicate? It seems like it doesn’t stick well to the primer.
The chainstay and Direct drive fork art I will ask my graphic designer spouse for Christmas
I need to carefully consider the top and downtube.
in a quick review, the art I saw was just a bit off, on some the italic angle appears to change over the span.
but yeah, the paint did not appear to attach to the primer really well.
the drive side upper lug trouble you have is minor compared to mine.
The frame has good details, the oval chainstays, the slightly ovalized seat stays.
If I really like the bike perhaps ask DiNucci to build a steel fork with one of his crowns. $$$$
I will be going RED, as everyone knows red bikes are faster.
Bikes: Too many to list
Quoted: 1765 Post(s)
Liked 1,125 Times
Liked 2,843 Times
In SoCal, might try the Bicycle Stand in Long Beach on Broadway
Liked 2,843 Times
I glanced at mine today and noticed that the downtube is slightly bigger- a measure confirms- 28.6mm top tube and 30.4mm thereabouts down tube.
I knew DiNucci was a specifier but every little bit.
Bikes: Trek 460, Trek 1420, Schwin High Sierra
Quoted: 16 Post(s)
Liked 15 Times
Bike as of 2022-1-1 - Shimergo setup with Centaur 10 speed shifters, new B105 handlebars, new Nitto stem. Yellow water bottle cages and yellow bar tape to match yellow lettering on frame. TiGr bike lock mounted to seat post, with tail light mounted to lock. Headlight mounted to handlebars.
