Sleeping Bag Liners
Bikes: Surly LHT 26in 52cm 2008
Sleeping Bag Liners
Do you use Sleeping Bag Liners on your Bike Touring Trips???
What type of Sleeping bag liners do you use and Do you like using a Sleeping Bag liners in your Sleeping bags and Why do you use a Sleeping bag liners???
I am using Big Agnes Encampment 15 degs Sleeping Bag (Fall/Winter) and Big Agnes Gunn Creek 30 degs Sleeping Bag (Spring/Summer) and on 8/2012 I got the Kelty lightweight Fleece mummy Sleeping bag liner and I use it from 12-2012 to 3-2013 and I Slept in it for
1 night and I did not like it!!!... and then I was Sleep on Top of it at night and it is not easy to hook on the loops inside my Big Agnes Sleeping Bags!!!... and I was thinking of Getting the Big Agnes Sleeping bag liner but it is $89.99
P.S. I Sleep in Terramar EC2 Military Expedition weight Top & Pants
Vapor barrier liners Keep your sweat in when it's Below Zero F.
Patagonia silk weight tops and bottoms are good as PJ's.
I'm with Bob --> IF you really feel you need something between you and your bag, get some silk top&bottoms that can also be a clothing layer.
I use a Coolmax sleeping bag liner. I find that it's great for keeping my down bag clean, as well as those nights when it's too warm to be completely enclosed by the bag, but too cool to keep the zipper open much. Plus, they work great as a simple sheet to sleep under on the really warm nights.
Knows the weight of my bike to the nearest 10 pounds.
Real Men Ride Ordinaries
Quoted: 17 Post(s)
I've never really felt the need. They don't really add much warmth, they add considerable weight (depending on what model you use) and don't really provide any real advantage.
There are some reasons-if for some reason you don't like the feel of your sleeping bag, (or for the quilt users out there), it can give a bit of protection.
I guess it does keep the bag slightly cleaner, but having used a sleeping bag for four months continually, and accumulation of body oils (or whatever the given reason is) was never really a problem.
Quoted: 1324 Post(s)
Liked 927 Times
If I'm using a sleeping bag with a nylon inner surface then either very thin pajamas or a very thin fabric liner can reduce that clammy/sticky feeling. I've never bought a sleeping bag liner. I simply made one from a thin cotton sheet. I just slip it into the sleeping bag and don't try to fasten it to the interior of the bag.
A sleeping bag liner also helps a lot to keep the sleeping bag itself clean on the inside.
Having pajamas like others suggest can also give you that extra layer of clothing if you need it.
I like to have as much of my stuff do double duty as i can.
Cheers
Cheers
Quoted: 598 Post(s)
Liked 283 Times
Question for you that do use a liner, do you feel it lowers the rating of your bag by 10 degrees, i.e. takes a +40 deg F. to a +30 deg F ? I've heard mixed reviews as to whether there really is any insulative value with thin liners. Thanks.
I don't use sleeping bag liners anymore!
Sunshine
Quoted: 10965 Post(s)
Liked 7,492 Times
https://www.amazon.com/TETON-Sports-S.../dp/B00R5WR644
$19 and weigs 12oz. We have a couple of them. I like it since my bag is a very thin 42deg bag which is only possible if I am fully dressed in winter gear and sleeping in it at 42deg. Point being, it is another layer, albeit a thin one. Its great to use in hot weather too, just use that instead of the bag if I get too hot during the night.
We have a few Coleman fleece insert/bags too and those are bulkier and weigh probably 1.5pounds. They for sure make the bag warmer, but they trap moisture too. These can be used as a standalone sleeping bag when its warmer.
I bring the Teton liner with since I think it helps if the temp is going to be around 50deg or lower and above 70.
Bikes: Salsa Fargo commuter,Litespeed Ocoee titanium mountain bike cannondale caad9 105 road bike
I have a sea to summit silk liner(I think ) and it's supposed to add up to 10 degrees. Maybe it adds ten degrees when it's 80 out. It doesn't seem to help at all when its cold out. I also tend to get tangled up in it and don't use it.
Sleeping Bag Liners
but I am looking to buy a Big Agnes Sleeping Bag Liner but I don't have $89.99 for a liner and by 11-2016 yes I will get the Big Agnes liner
Quoted: 659 Post(s)
Liked 7 Times
Yes, a vapor barrier liner does add considerable warmth under cold conditions. I normally use a light down bag that's comfortable down to about freezing. By adding a very light vapor barrier liner to it I've been comfortable down to about 0F. It's not due to extra insulation but by reducing the heat lost through evaporation of perspiration during the night. It also has a side benefit of reducing water loss so I don't wake up thirsty in the morning.
I first discovered the benefit by accident on an unexpectedly cold night when I was still shivering in my usual bag. I remembered that I also had one of the emergency mylar blankets along so I wrapped myself in that inside the sleeping bag and it made a surprisingly large increase in my comfort that night. Later read about vapor barrier liners and eventually bought a nylon one (the mylar worked fine but is noisy whenever I moved around a bit).
I don't use any liner in above freezing conditions.
Quoted: 2604 Post(s)
Liked 1,933 Times
Though, I'm not sure one more answer is going to nail this question down. Unless you think this random stranger on the internet has the definitive answer (which, of course is actually the case , reviews will still be mixed with one more vote for "yes."
Miles to Go
With you using your sleeping bag every night, you may benefit from a liner to keep the bag cleaner, and be able to add or subtract for warmer or colder days. It may add some comfort also like sheets do on a bed. Sounds like from your past threads based on where you shop you can buy it and return it if you don't like it. Please let us know how it works for you.
Sunshine
Liked 7,492 Times
For what its worth- it costs $70 on their site. https://www.bigagnes.com/Products/De...Syntheticliner
aka Phil Jungels
I use an old cotton twin top sheet, folded at the bottom to fit the bag. Works great! Could use a micro fibre one for winter use.
Bikes: Surly Long Haul Disc Trucker
Quoted: 1015 Post(s)
I cant imagine spending $90 for a liner, but I also dont use equipment even 1/25th as often as you.
no, you don't. but you have mucho free time.
buy a thin, lightweight flat sheet from goodwill for $1.
i assume you have a sewing kit and scissors, if not.....dollar store.
measure, mark, measure again, correct marks, cut, sew.
doesn't have to exactly match the bag insides, doesn't have to be perfect.
take a couple hours in camp...........done.
