Touring Tires Dirt/Paved Roads
I'm looking for a 26 inch tire to tour on dirt roads and paved roads on the same trip. I've seen the Continental Travel Contact Tire (26x1.75). Any experience with these tires? Or any other suggestions. In the distant past I've use Continental Goliaths. Thanks JVW.
Bikes: Surly Cross Check, Thorn Sherpa
Have you looked at Schwalbe's line of Marathon tires?
The Nimbus 1.5 tires are good for dirt roads IMO. They have a kevlar belt in them and can go up to 80PSI. Previously I had been using the Armadillo Hemisphere 1.95. Awesome tire. I had nails go in them and the nail heads just bent, no flat. They also have the kevlar and their sidewall protection seems better than that of the Nimbus. I prefer the Nimbus cause you can get going faster in them. Unless the dirt road has lots of gravel on it I would use the Nimbus, for a gravel road with lots of pointy rocks I would switch to the Armadillo at around 65PSI.
happy touring!
happy touring!
Bikes: Trek 5200, Giant Rainier, Devinci Destination,Motobecane CF, Bike Friday family tandem, Bike Friday NWT
Quoted: 15 Post(s)
Continental Town and Country, 1.9. Pretty good all rounder.
Hockey
Hockey
totally louche
Bikes: the ever shifting stable loaded with comfortable road bikes and city and winter bikes
Liked 10 Times
Conti Travel contacts are THE BOMB for mixed road touring, IMO. I've used them extensively on tours that combine paved with significant gravel & dirt roads and find them mos' excellent.
Pedalpower
My two cents on the Specialized tires. The Nimbus is an excellent road tire that will do fine off-road as long as it's used over hardpack, but hit a steep climb over loose ground and your back wheel will spin like on a turbo trainer with zero forward motion. The Hemi is not as smooth on the road and traction is only marginally better (IMO, the only improvement over the Nimbus is the wider size).
I have a TravelContact on the front wheel of my commuter. Used it all winter on snow, ice and pavement and it handled pretty well. I did get a couple flats this winter though, caused by slivers of glass being pushed through the tire. That was disappointing. I plan on buying some Schwalbe Marathon Pluses for my touring bike to hopefully avoid all flats for my 3.5 month tour this summer.
Edit: after reading post below, let me say I've been very happy with Conti tires on my road bike. The sidewalls do seem to dry out a bit, especially if subjected to temperature extremes. But for flat-proof touring tires, I'll try the Schwalbes based on glowing reviews on this forum. On my road bike, I'll stick with Contis.
Hooked on Touring
I had sidewall splitting problems with a pair of Contis I bought. Granted I bought them in Fairbanks and they might have been damaged by storage at minus 60.
Or maybe it was just one bad batch.
But I'll avoid Contis from now on.
I've had great luck with Armadillos.
Found some Vredesteins on sale last year and love them. (Holland)
Never heard of them before and probably won't be able to afford them in the future.
One Hep Cat
Bikes: Surly Cross-Check (commuter), Lemond Sarthe (sports car), Schwinn fixed gear conversion (for fun)
I have had really good luck with Ritchey Tom Slicks (26 x 1). I used that a lot for commuter and Anchorage Trail Watch duties for two years, and they did just fine on dirt and pavement. I never took it on more extreme or techincal trails with them, but for bombing along on dirt and gravel they did great. Also, I never had a flat despite running over several beer bottles in the dark.
Bikes: Surly Long Haul Trucker
I used the Conti Travel Contacts 26x1.75" for my longest tour (3 months) and loved them in the dirt. I found the tread to be grippy on pretty much any surface. With some pressure adjustments, I was pretty much at home in everything from RV/Jeep trails, rail-to-trail and of course, pavement. However, I found them to be slightly fast-wearing and had to change them around the 4000km mark. I didn't get a single flat in over 8000km so they were perfect for what I wanted from them: multi-surface touring with minimal flats. I will use them again.
Conti Travel Contacts have weak sidewalls for a touring tyre.
The gold standard offroad touring tyre is the Schwalbe Marathon XR, available in 1.6", 2.0" and 2.25". They cope well enough on road if you pump them up to the max. pressure.
I've got a set of 2.25" that have already covered 9000km and I think I'll easily get the same distance again. The front still looks almost new.
Bikes: 2015 Scissortail hardtail MTB, 2013 XL Longbike USS recumbent, 2010 Hans Schneider steel randonneur road bike, 2005 Surly LHT;
centexwoody
They're beautiful handsome machines that translate energy into joy.
centexwoody
Lots of good tires out there.... but I see nothing wrong with Conti travel contact tires. Lots of people tour with these all over the world (very popular tire in Germany)
I like to buy tires locally. If the sidewall blows out in 500 miles, take them back and politely ask the bike shop for a good deal on a repalcement tire.
centexwoody
centexwoody
I've got Travel Contacts on two different bikes and I've found them fantastic. One bike has had them on for 4 years (about 5000km), with minimal wear, great durability and few flats. I love the tire.
depending upon which way i go it is 6-8 km to a paved road, in between are various forms
of dirt, gravel and sandy roads. right now most of them are covered with a messy mix of
ice, mud and ooze, this eve many spots were so soft my bike sank in deeper than the
tire/rim. each year i travel over 2000 km on this mix of road riding on regular Schwalbe marathon tires.
they are suprisingly effective on sandy/dirt roads with good resistance to stone bruises. these
tires just plain get the job done, please be forewarned- i'm biased about these tires as i've had
great luck with them for more than a decade. use the 47 or 50 mm width, wish they made a 54.
Quoted: 7 Post(s)
Originally Posted by rmac
Did you notice they are a lot narrower than advertised? I bought a set of 37s and they measured 33 mm.
One Hep Cat
Originally Posted by Joe Dog
That's funny. I thought that usually tires ran wider than advertised because narrower is cooler. I'll measure my Conti's and see...
Quoted: 7 Post(s)
Originally Posted by acidinmylegs
That's been my experience.
