Side lighting for front headlight new law in some states.
Bikes: Schwinns and Miyatas
I'm a newbie here at Bike Forums so forgive me if I screw up a bit. Just reading all the great posts about bicycle lighting and some of the great ideas for using flashlights as head lights. Just wanted to throw in my 2 cents about some of the states changing their laws about bicycle lighting apparently because more people are riding at night. In Ohio we now must have a head light that also distributes light to the sides at 180 degrees, visible for 300 feet. That would eliminate using a flashlight set up here ( unless you figure the police won't bother you for such a trivial jab at the law ). I know there are reflectors on the bicycle wheels that reflect light at night, but the new light laws are supposedly because of a motorist being parked at night, ready to exit their car, being able to see a bicyclist to their immediate left before opening the door into the bicyclist's path. I guess that sounds like a good reason, but I've not heard of any instances of that occuring in our area. So just a heads up so you can check to see if your lighting idea conforms to possible new lighting laws in your state. My old light didn't...my new light does.
Quoted: 659 Post(s)
Liked 7 Times
Is there any other definition given for the side lighting beyond the 'visible from 300ft.'? Note that the effectiveness varies widely depending on other ambient lighting or distracting lights in the same general direction. If the light is isolated and on a dark night, human vision can see a single candle at a distance of up to 30 miles (How Far Can the Human Eye See? | Human Visual Acuity | LiveScience). So very little light would really be needed to see something 300' away under optimum conditions. If the edge of a cyclist's flashlight beam hits any part of his cables, brake levers, front tire, etc. then it would probably be visible from that distance as seen from the side - again, under optimum conditions.
California has had a similar provision for some time (I don't remember any changes in the last 20 years) that requires:
"A lamp emitting a white light that, while the bicycle is in motion, illuminates the highway, sidewalk, or bikeway in front of the bicyclist and is visible from a distance of 300 feet in front and from the sides of the bicycle." Most bicycle-specific lights I've seen do emit a tiny bit of light to the sides (enough to say they comply under good conditions, but probably not very useful in practice). And any decently bright flashlight should be casting enough light on the road and other objects ahead of the cyclist so as to be seen by someone observing the cyclist from the side.
Looking at it another way, you could have your entire bike outfitted with side reflectors and side lights but if you don't have a "Front light with 180° visibility" the perpetrator could claim he couldn't see you and as stupid as that might sound, it can happen. ( so much for my faith in our justice system )
Prathmann's analysis nails it IMO.
I don't see the logic in the claimed reason. First of all, it's not advisable for traffic (either cyclist or motorist) to be in the door zone. Secondly, if the person in the car looks back before opening his door the cyclist who ends up next to the door when it actually opens would be quite a few feet back when the motorist first looks. So he should have a clear view of the front light shining forward with his initial glance. OTOH, if he just opens the door without looking then any light shining sideways from the cyclist won't be seen anyway. The cases I've seen of doorings have happened because the driver was looking forward when he opened his car door - not at all in the direction of the cyclist. By far the most effective light to avoid these would be a bright light shining forward so that portions of the car on the left side and in front of the driver (mirror, left edge of dash, etc.) are illuminated by the beam.
Obviously the laws' writers were football fans.
proileri
18
08-02-12 07:32 PM
Richard Cranium
31
04-07-10 01:34 PM
