Headbadge re-mounting
Hi I’ve had some vintage frames refinished and obviously had to remove the original rivets on the head badges.
To remount them it’s been recommended to me that I get some self-starting screws from McMaster in a very small size.
There are a lot of options there though, and I could use some help figuring out which ones to order.
Any advice on this would be much appreciated.
Thanks!
Thanks!
Randomhead
Liked 3,698 Times
This seems like a very C&V sort of question. Maybe someone from there will follow you in here or I can move this thread
Randomhead
Liked 3,698 Times
I'm sure the real expertise is here in C&V. Moved here from framebuilding
Quoted: 809 Post(s)
Liked 1,023 Times
Drive pins are the usual way to fasten the headbadge if it was done that way originally. Some headbadges used pop rivets these are also available in small sizes.
This is the link to drive pins on McMaster-Carr:
https://www.mcmaster.com/drive-pins
Likes For Velo Mule:
Quoted: 1303 Post(s)
Liked 1,911 Times
Screws in thread sizes of 3 X.5 mm are available and should be easy enough to tap out on the frames. Next size up is 4 X.7 mm and the heads may be too bulky but if using stainless screws they can be ground down to an acceptable size head. HTH, MH
Likes For Mad Honk:
feros ferio
Quoted: 1393 Post(s)
Liked 1,325 Times
I use small screws, as mentioned above, although I should try small pop rivets.
Likes For John E:
Quoted: 350 Post(s)
Liked 276 Times
CoRide59 has surplus drive screws in a few different sizes and was very generous to share. You should reach out to him.
Likes For tyler_fred:
SE Wis
Quoted: 2747 Post(s)
Liked 3,395 Times
I have some small taps in sizes like 4-48 and 3-56 and like to tap and use short screws with loctite. Brass or stainless, flat or pan head depending on how it sits.
Likes For dedhed:
Friendship is Magic
Bikes: old ones
Quoted: 26419 Post(s)
Liked 10,380 Times
I never finish anyth
Bikes: 2008 Merckx LXM, 2003 Giant XTC mtb, 2001 Lemond Alpe d'Huez, 1997 Lemond Zurich, 1989 Cannondale ST, 1988 Masi Nuovo Strada, 1983 Pinarello Turismo
Quoted: 294 Post(s)
Liked 137 Times
I have 198 extra drive screws in sizes 00 and 0 that I bought from McMaster-Carr. I'm happy to put a few of each size in an envelope to you, just let me know. PM is fine.
Dale, NL4T
Dale, NL4T
Likes For speedevil:
Friendship is Magic
Bikes: old ones
Liked 10,380 Times
It would probably work if you could find some way to flatten the interior projecting stub. The space between these two tubes is pretty tight.
I have quite a few extra 2-56 1/8” brass screws. Also willing to share.
Quoted: 3464 Post(s)
Liked 2,829 Times
Drive screws, then set them (also deforms to clear the steerer with a solid rod inside the tube, or really really thick wall pipe.
A nail set with a concave head helps too, there are different sizes around.
Cinelli used screws, hard to find, as they are "countersunk with a slot and slight domed head- Think Sewing machine bobbin case leaf spring fasteners.
Those vary in size- Industrial machine, "Big Bobbin" machines.
Bikes: 1970s Alex Singer, 1960s Peugeot PX 10, 1960s Bertin C37, 1973 Carre Bertin C 37, 1972 Carlton Kermesse, 1981 Peugeot PX 14 Super Competition
Quoted: 346 Post(s)
Liked 266 Times
krems81-
Head badge rivets from Velo Heaven? Come in 3 different sizes: https://www.velo-heaven.co.uk/collec...d-badge-rivets
Likes For bertinjim:
Use a little bit of copper wire off an electrical house mains cable to form a rivet, using a chisel inside the tube as an anvil.Toffee hammer and careful blows.
Likes For aland2:
Quoted: 457 Post(s)
Liked 462 Times
...using a standard pop rivet is problematic because the interior of the rivet projects far enough into the head tube to interfere with the steerer tube.
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
Likes For KenNC:
Quoted: 1299 Post(s)
Liked 103 Times
It can be tricky setting drive screws by hand. The body of the screw is supposed to be .001 to .002 over the size of the hole, so it has to be a perfect match. I think .002" might be a bit too tight for the harder steel used in bike frames. You would need a concave ended punch or the head of the drive screw will flatten. Then it's a 4 handed operation trying to line everything up and drive in the screw. I think you would be better off using a screw and tapped hole with lock tight or a rivet that clinches on the inside of the head tube.
Inflate Hard
Inflate Hard
Bikes: 1973 Colnago Super, Litespeed Classic , Automoto , Pinarello Gavia TSX,Eddy Merckx Corsa Extra,Eddy Merckx EMX-5 , 1982 Moser SL, Concorde TSX, Vitus 979 KAS. Diamant SLX,60's Meteor
Quoted: 235 Post(s)
Liked 947 Times
Ive used aluminum rivits a few times. I used to be an aircraft mechenic many years ago so riviting is something im very familiar with..
I ordered some small rivits from McMaster Carr, I cut the length down because too long of a rivit will interfere with the steerer fok tube. Theres not alot of clearance in the head tube so a small rivits work best. I made my own rivit set using a piece of small round stock. All I did was use a 1/4 drill bit to fit the size of the rivit head. I then used a piece of solid round stock that I had in my metal junk pile. I put it in a vise, I slid the steering tube over it, and I used the round stock as a bucking bar , A few small light taps on the head of the rivit and bingo!
I was concerned with slipping off the rivit head and damaging my headbadge , So far Ive been more lucky than good.
Maybe if I get some time I can go take pictures of how Ive done it.
Quoted: 175 Post(s)
Liked 244 Times
Ditto to this one.
The Simplicity of Vintage Cycles
Quoted: 3810 Post(s)
Liked 6,699 Times
My standard practice is to glue the head badge back on and then glue faux rivets in the holes. I’ve made those from spoke heads and alu rod.
Quoted: 294 Post(s)
Liked 137 Times
To prevent the head tube from denting, find a socket that will fit into the head tube to use while tapping in the screws. You might want two, one above the hole and one below.
Dale, NL4T
Dale, NL4T
