Question about fit
Quoted: 8 Post(s)
Question about fit
Hello,
I decided to remove some spacers on my bike to see if I gained any flexibility and to see how it would feel. I went for a 100km ride and everything was ok, no pain, the only problem was that my upper thighs hit my lower stomach (belly) when I am in the drops is that normal? It isn't something that really bothers me, but I just wanted to ask. Here are a few pictures of me in the drops and on the holds. Sorry I wasn't wearing cycling specific attire.
Does the bike look like a good size for me?
I did get a fit included at the LBS but need some other opinions.
Thanks for looking
Thanks for looking
If I have understood my own condition properly one has to be seriously skinny to not kick onesself in the stomach whilst ridin so low in the drops.
I'm starting to be really skinny and I still kick myself in the gut.
(193cm 93kg 84cm stomach girth)
Reason for this, i think, is because the bellyfat you have is more pronounced in a lower riding posture. Even a minor belly sags down when bending over. And so it's in the way of pedalling.
Could be that I'm completely wrong.
The question is not how does it look, the question is how does it feel? Age (flexibility really), girth, leg length, arm length etc. are pretty much unique to each of us. If you feel good on it and it is comfortable, to the point the bike becomes an extension of you, then it fits.
Voice of the Industry
Quoted: 1188 Post(s)
Liked 8 Times
Self flogging while riding in the drops which maybe deserved due to overeating is not a recommended practice. You are likely a combination of flexible guy with a spare tire and why you have this predicament. By contrast, my joints freeze up before I self flog myself in the drops. I am not uber flexible but am a flat belly. We each have to find our happy medium. So until you lose some weight either continue to beat yourself in the drops or raise your handlebar slightly until you drop some weight.
Artificial Member
Bikes: Retrospec Judd, Dahon Boardwalk, Specialized Langster
Quoted: 6766 Post(s)
Liked 5,477 Times
The fit looks maybe OK.
It's hard to tell from those photos but I wonder if a longer stem might be needed.
The deal is, though, if your center of mass on the bike is right you will be able to sit up no hands easy, go from the hoods to the drops, or vice versa, with both hands off and no particular hurry.
Can you ride it no hands and steer it? With confidence?
Bikes: Colnago C59 Italia Di2
Common problem with a bike set up with a low bar. Even more common with lots of set back. Ive never had this problem and ride with 100mm of drop to the tops. I can ride full power in the drops with bent arms and not hit my chest but then I am 6'2" and 160# very flexible and people are ALWAYS saying I look skinny. If you are heavier than that then you might have to put up with it.
you say you are comfortable so I wouldnt change anything. Just enjoy the aero benefit of a lower bar.
Bikes: Look 585
Quoted: 25 Post(s)
You might check you saddle height. It looks like it might be too high -- you're leg looks too straight with the pedal at the bottom.
Professional Fuss-Budget
A free fit over the Internets is worth what you paid for it... nothing.
Seriously, you can get general concepts explained to you, but nothing this specific. I'd talk to a real fitter, who can observe your entire fit from a variety of angles.
Quoted: 8 Post(s)
Bikes: Cannondale Supersix Hi-Mod / Scott Spark 930 / Scott Sportster 20 / Jamis Allegro 2.0
I think most of the comments are spot on...
1. Saddle looks too high
2. Stem too short
3. Seat too far forward
You seem to be in a pretty upright position...so I'm a little confused as to why your knees are hitting your stomach.
2. Stem too short
Quoted: 8 Post(s)
How does one know a longer stem is needed other than trying of course?
Splendid
so longer stem, lower seat and more setback - yes absolutely that will cure the knees hitting the belly, no doubt at all, honest gov. Who knows you may even turn that painless 100km into something much less enjoyable too Result!
Anyway enough sillyness...
Nassa are those the shoes you normally ride in? Only that could effect the seat height appearance, also were you riding with any effort in those photos as that will effect it too - along with the rest of your stance on the bike...
Quoted: 8 Post(s)
I love it, we are now doing internet bike fits with no information other than a poster who says he is comfortable and HALF a photo. We really are getting impressive now. Ask an innocent question about knees touching a clearly overweight belly (no offence) and leave needing a new stem for that perfect 'Lance' fit
Splendid
Splendid
To reply to the saddle height, according to my lbs I have the correct angle of knee bend with my cycling shoes.
Bikes: Look 585
Quoted: 25 Post(s)
No offense taken, but I don't see myself as overweight maybe a little spare tire and that is the reason why I ask. Height weight 5 feet 8 inches approx 172 pounds.
Liked 8 Times
I love it, we are now doing internet bike fits with no information other than a poster who says he is comfortable for 100km rides and HALF a photo. We really are getting impressive now. Ask an innocent question about knees touching a clearly overweight belly (only slightly no offence) and leave needing a new stem for that perfect 'Lance' fit
Splendid
Splendid
Bikes: 2010 Cannondale T1, 1998 Specialized FSR
Curious - how long are your crank arms? I'm 5'7" and ride 170's on all my bikes except one and it is 172.5. Remember, the longer the cranks the higher your legs have to go to complete a rotation. Just a thought. Al
pan y agua
Quoted: 1447 Post(s)
Liked 724 Times
I think the point for the OP is that there's some consensus here that he might do better with a longer stem. Thus it would be reasonable for the OP to try a longer stem. A good shop often has a few old stems around that you can borrow to try different lengths, before you decide to buy a particular size.
You could get lost and die.
You could hit a tree and die.
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,173 Times
Ha. "Big George" Hincapie is 6'3" for the same weight. That's why a favorite saying here is "You're too fat for this sport"
Liked 8 Times
Believe the point to the OP is...having blub around the mid section and riding a small bike for your size as maybe a top racer would with shortish headtube is not a recommended formula. To me the worse combination of fit is small bike + short cockpit...double kiss of death. Fat guys should ride a bit more upright to keep from self flagellation. But if developing a higher pain threshold to ride faster, this maybe the best formula.
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
There is a lot of knowledge and experience represented here, but I have to disagree. In my opinion, from what I can see there's nothing wrong with the bike's size or the rider's position.
Common sense is that soft tissue interference depends on how much you're bent forward, and the angle of your hips and pelvis. Suppose you tilt pelvis forward, to open up the angle?
Quoted: 8 Post(s)
Liked 8 Times
Thank you, I assume if the fit was off I would feel pain somewhere, but that is not the case. I spoke to my lbs fitter and he confirmed that their is nothing wrong with the fit but more my riding style, flat back, rather than arched back. He said we can try switching to a 110 mm stem but I have to try and arch my back. Does the stem brand make a difference? Fsa vs race face vs etc?
I would say 80% of the advice coming out of local bike shops when it comes to fit is bogus. Further at least 50% of bike shops can't tune a bike properly. So what are bike shops good for? Selling bikes and equipment. There is no shortcut to getting good at anything. It generally takes more effort than people are willing to put in and why average is just that.
