Cinelli Bar Stem
Cinelli Bar Stem
Old 07-16-15, 08:47 PM
OldsCOOL
OldsCOOL's Avatar
Quoted: 659 Post(s)
Liked 595 Times in 313 Posts
Cinelli Bar Stem
My '77 Colnago has Cinelli bars and stem. I'm wondering the story behind this stem, it's the kind with no visible clamp, just a bolt underneath. The owner/builder said he went with that being '77 was the first year and he thought it looked cool. Given I have not been around the Italian scene, this is new to me.
OldsCOOL is offline
Old 07-16-15, 09:21 PM
PBC peugeot
PBC peugeot's Avatar
Bikes: 1972 Raleigh international, 1975 Raleigh professional, 1978 ALAN criterium, 1981 Pinnarello Traviso
Quoted: 34 Post(s)
Liked 31 Times in 22 Posts
is it the one with the round black Cinelli emblem on the front?
because those were cool! always wanted one,
PBC peugeot is offline
Old 07-16-15, 09:24 PM
Soody
Soody's Avatar
Bikes: Gunnar, Shogun, Concorde, F Moser, Pete Tansley, Rocky Mtn, Diamant, Krapf, Marin, Avanti, Winora, Emmelle, Ken Evans
Quoted: 275 Post(s)
Liked 417 Times in 218 Posts
Don't kill it like I killed my old Cinelli stem overtightening 26mm bars. It should be a proprietary 26.4 mm size, so if you want to run other bars (26mm), make sure you shim them.
Soody is offline
Old 07-16-15, 09:30 PM
OldsCOOL
OldsCOOL's Avatar
Quoted: 659 Post(s)
Here is a before pic as when the bike came home:
OldsCOOL is offline
OldsCOOL
OldsCOOL's Avatar
Quoted: 659 Post(s)
Yes it's with the Cinelli bars.
OldsCOOL is offline
Old 07-16-15, 09:32 PM
OldsCOOL
OldsCOOL's Avatar
Quoted: 659 Post(s)
Was there a model name for this type?
OldsCOOL is offline
Old 07-16-15, 09:33 PM
FBinNY
Quoted: 5792 Post(s)
Liked 2,583 Times in 1,432 Posts
Welcome to the lost world of one-piece forged stems. Quality stems of the ea were forged from a single piece of aluminum, bored for the handle bar, then the clamp ears were drilled and tapped. Most Italian makers were happy to have the ears underneath with the bolt horizontal including Cinelli for many years. But Cinelli was probably the most fashion forward bike maker in Italy, so after a while they went that design one better with this one, which made for a cleaner look.
The thing about these or any forged stem is that removing bars is a matter of finesse, and not using strength or pry bars to spread the stem open. If you look you'll see that the sides are narrowed on the bottom. This allows just enough room to clear the inside of every curve on the bars. You have to rotate the bar as you thread it through to keep the inside where the clearance.
BITD I'd see so many nice alloy bars all scratched and gouged where some oaf who didn't get it tried to force them through rather than use the finesse called for.
There are decent photos of this stem and other nice stems of the era, easily found if you search "forged quill stem images". Obviously, they're random photos, but if you think about it a bit, you can trace the evolution of this design through the decades.
FB
Chain-L site
FBinNY is offline
Old 07-16-15, 09:35 PM
Soody
Soody's Avatar
Quoted: 275 Post(s)
VeloBase.com - Component: Cinelli 1R (1/Record, early version)
Is it that?
VeloBase.com - Component Listing
Soody is offline
Old 07-16-15, 09:43 PM
TheManShow
Bikes: Old rusty bucket of bolts
Thayt my friends is a Cinelli XA Stem, and I have to 90mm. One is in use, one is waithing on my New Frame.
TheManShow is offline
PBC peugeot
Quoted: 34 Post(s)
YEA MAN! thats the one!
the standard stem was the 1A, I think that one was the 1R ?
Old 07-16-15, 09:49 PM
OldsCOOL
OldsCOOL's Avatar
Quoted: 659 Post(s)
Velobase says the XA began in the mid-80's whereas this one was installed during the frameset build in '77. Who knows?
OldsCOOL is offline
Old 07-16-15, 09:51 PM
OldsCOOL
OldsCOOL's Avatar
Quoted: 659 Post(s)
Access the velobase link that Soody posted. It says the early 1A started late 70's. Could be that one?
OldsCOOL is offline
Old 07-16-15, 09:55 PM
OldsCOOL
OldsCOOL's Avatar
Quoted: 659 Post(s)
I'll post an underneath and side pic in the morning. Thanx!
OldsCOOL is offline
Old 07-16-15, 09:58 PM
delicious
delicious's Avatar
Quoted: 88 Post(s)
Liked 60 Times in 34 Posts
It's definitely a 1R.
delicious is offline
Old 07-16-15, 10:03 PM
OldsCOOL
OldsCOOL's Avatar
Quoted: 659 Post(s)
I concur.
OldsCOOL is offline
Old 07-16-15, 10:09 PM
repechage
Quoted: 3464 Post(s)
Liked 2,831 Times in 1,997 Posts
It is a Cinelli 1R stem, first version. Noted by the CINELLI typography on the front plastic cover disc.
It came out earlier than 1977 though. Presented in late 1975, some availability in 1976. 26.4 bars exclusively in my book.
The wedge bolt should be well lubricated on the threads and at the wedge face.
These stems really liked the then current production bars (last of the shield logo) as the knurling at the center was deeper than the earlier bars. We lubricated the bars too, but there was some argument about that.
This stem came supplied with an aluminum quill bolt too, be sure to lube the brass washer(s) at the base of the bolt head.
That all written, I did not like them. Too fussy. I have two now, one on a bike as that was original equipment, the other for reasons I cannot recall.
repechage is offline
Old 07-17-15, 04:38 AM
miamijim
miamijim's Avatar
Quoted: 413 Post(s)
Liked 109 Times in 78 Posts
+1 to them being fussy. If you over tighten the wedge digs into the bar which in turn prevents you from micro fine tuning the bar position. You'll only get big adjustments out of it. The wedges are prone to cracking as well as the from of the stem at the edges of the black Cinelli badge.
to remove bars you loosen the bolt them rock the bars back n forth and in n out to break the wedge free.
1R parts are expensive.
miamijim is offline
Old 07-17-15, 06:07 AM
OldsCOOL
OldsCOOL's Avatar
Quoted: 659 Post(s)
I appreciate the excellent info, guys. What an interesting steerer set for an interesting bike. I doubt there will be much difficulty for me since the bike will be my "Friday Night" bike and special occasions, nevertheless it's good to know the shortcomings.
OldsCOOL is offline
Old 07-17-15, 06:54 AM
Henry III
is just a real cool dude
Henry III's Avatar
Quoted: 32 Post(s)
Liked 34 Times in 14 Posts
I've got later one that black but just on the move cross from Oregon to Michigan it faded pretty bad just from being outside in my trailer. I think their cool looking stems compared to the standard 1A.
Henry III is offline
Old 07-17-15, 07:06 AM
SJX426
SJX426's Avatar
Quoted: 1608 Post(s)
Liked 2,216 Times in 1,103 Posts
The 1A is Classic and Vintage, with the right logo. But I really am getting attached to the looks of the XA.
[IMG]P1020201 by Patrick Boulden, on Flickr[/IMG]
SJX426 is online now
Old 07-17-15, 07:25 AM
Henry III
Henry III's Avatar
Quoted: 32 Post(s)
You've got that bar clamped down pretty good with the rubber insert oozing out the sides.
Old 07-17-15, 07:39 AM
SJX426
SJX426's Avatar
Well that is the way it was when I purchased it. I dont' typically clamp that hard and didn't upon re-installation, it took a permanent set with prior clamping force.
Old 07-17-15, 09:06 AM
Soody
Soody's Avatar
Quoted: 275 Post(s)
Soody is offline
Old 07-17-15, 10:21 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
I've been using a 1R & Nitto dirt drops [Taken off a V1 of the BS MB1 by BS Dealer..] they flare at the drops for bar end shifter to knee clearance.
The black patch on the front fills in the hole bored into the stem to fit the wedge mechanism that pushes the shoe forward to grip the Bar.
fietsbob is offline
Old 07-17-15, 10:57 AM
lotek
lotek's Avatar
Bikes: 1 trek, serotta, rih, de Reus, Pogliaghi and finally a Zieleman! and got a DeRosa
Quoted: 15 Post(s)
Liked 9 Times in 9 Posts
Off topic but nice shot of Fignon, who I've come to respect even more after reading his autobiography.
I've got a few 1Rs finicky to be sure but oozes Italian style.
Sono pił lento di quel che sembra.
Odio la gente, tutti.
Want to upgrade your membership? Click Here.
lotek is offline
