Trek SLR7 Disc
Trek SLR7 Disc
I'm giving myself a retirement present in June, a new bike! For once, I want to buy myself something a bit more extravagant and not just do the 'reasonable thing'.
I'm currently on a 2014 Domane 4.3. This was their entry level carbon, 105 DT, basically first gen of the rear IsoSpeed. It's been a great machine with no complaints of interest.
I'm looking at the SLR7 Disc. Lots of hills where we live so will be happy for the improved braking. Electronics are a nice change and the lighter frame hopefully adding to some enjoyment.
As the geometry is identical to my current bike, I expect the fit to be okay. Will also check out the BMC RM, perhaps a couple of other brands. Planning on test rides in the next months.
Anyone riding this model and can provide some feedback?
Thanks!
Thanks!
[insert clever quote here]
Quoted: 276 Post(s)
Liked 6 Times
Might as well wait until Trek makes it's announcement that changes the entire cycling world forever:
https://www.bikeforums.net/road-cycl...g-forever.html
Can't help you on the SLR7 but I bought a 2017 Domane SLR6 Disc and now have about 7000 miles on it. I'm now a big fan of disc brakes, the front/rear Isospeed components definitely do smooth out the ride on the typical surfaces I ride. This was the first carbon frame I've had - I'm really enjoying it. I went with the SLR 6 that year, mainly because it came with Metron Vision 40 wheels, I'm not sure how much of the improved feeling is from those vs. the frame.
The only downside has been less durability than my previous Trek bikes, all steel frames. I've already had to have 1 shift cable and the bottom bracket replaced, which the bike shop says is about average but I think I got way more than 7K miles on those components before, though with the new bike I am doing a lot more miles per year than I had been doing. There is a plastic cable guide under the bottom bracket that kept braking and kept being replaced under warranty - Trek improved the part and no more problems there.
You replaced a BB at 7k miles and the shop said that was average? On my 2014, I've only just now swapped out a broken cable. I rode my Giant OCR for ten years without ever having to replace the bottom bracket.
Bikes: Trek Emonda SL7
Quoted: 5 Post(s)
I choose the EMONDA SL7 disc about a year ago and sing it's praises on every ride.
Made the leap from a 20 y.o. Cannondale CAAD3; 53/39; 12-27 machine, so as you can imagine, i was blown away.
It's ULTEGRA Di2 spec'd ; 11-28 compact cranks; Bontrager carbon wheels and ~17.5#. A superb club riding machine for
the "climbs" and twisties here in SoCal. Think about opting for "VELO-CARE" during the purchase ... I got the 3 yr option for $175.. covers many moving
parts that your mileage will require replacing. Also, Trek has a credit card plan that you can opt to take up to 1 year interest free to settle up. There is a minimum
monthly and a very ugly steep interest rate if you miss a payment or don't square things up at the end of the year.
Test ride them all... Enjoy the new bike!
I had Trek's Red maintenance plan after I bought my Domane. It was pretty much a waste of money. I only replaced a chain under it. Sounds like the Velo-Care is less expensive than I paid. Will check that out, thanks.
Senior Citizen
Bikes: Trek Emonda SLR7 Disc, Lemond Poprad, 1980 Colnago Super, '88 Specialized Rockhopper
Quoted: 69 Post(s)
Liked 576 Times
DO IT!
Last year I decided to go the extravagant route (in retirement) as well. But I chose the Emonda SLR-7 Disc. Honestly, I think it's impossible to be happier on a bike! I went the Project One route, upgraded to Ultegra Di2, Aeolus Pro 3 TLR Carbon wheels and 26mm R3 TLR tires. I'm fully tubeless and run at about 80 psi front and 85 psi rear. The ride is smooth and supple. I love it.
Quoted: 5 Post(s)
DO IT!
Senior Citizen
Quoted: 69 Post(s)
Liked 576 Times
I've got approximately 1800 miles on the Emonda without a flat (knocks on wood), but I always carry a tube with me just in case.
DO IT!
Senior Citizen
Quoted: 69 Post(s)
Liked 576 Times
I notice the Emonda can use 25/26 tires (I've been using Conti 4000's 25 on my Domane) while the SLR goes up to 32. Emonda much lighter than the Domane. I'll test ride both. What I do like about sticking with the Domane is that the frame specs are identical to mine so that I can more easily adjust the fit to current numbers.
Thanks! I retire in June and will be testing bikes in late May.
Bikes: Fat City Monster Fat, BMC Roadmachine, Trek Emonda, Trek 2100, Specialized Rockhopper
Quoted: 21 Post(s)
Thinking about doing the same thing except I already have an Emonda(not a SL7). I am looking hard at the BMC though. Does anyone know if the Di2 junction box is still under the stem on the SL7 as in the photo on Trek's website or has it been moved internally somewhere?
Quoted: 1067 Post(s)
Liked 259 Times
My Domane SL6 disc will take a 35mm tyre.
I also have an Emonda ALR5 rim brake which will take a 30mm tyre.
So you may be underestimating the size tyre a SLR7 will fit.
Bikes: '86 Centurion Elite RS '17 Trek Domane SLR6 Disc '16 Trek Boone 5 '15 Trek Fuel EX 9 '20 Trek Checkpoint SL6
Quoted: 25 Post(s)
I got an Ultegra Di2 Domane SLR 6 disc and opted for the 32s. They were a bit too fat for my liking as a road bike, but I'm consistently riding on 28s on the road. If I were doing gravel on it I'd go wider.
I had the previous Ultegra Domane (the same as you have now) and it was definitely worth the upgrade, both in terms of the frame and the groupset. Get Di2!
Quoted: 3242 Post(s)
Liked 2,089 Times
Good that you are retiring. That's exactly the bike I desire, Domane SL7 with Di2 and discs. It comes with 32mm tires and I'd bet could push to 35 or so, which makes it a potential gravel grinder. I would suggest getting (as upgrade if required) the GS rear derailer as it offers greater cassette range, up to a 32 or so. I would contemplate a 2nd set of wheels for gravel, with an 11-32.
