Melted ENVY Rims
#51
pan y agua
Quoted: 1447 Post(s)
Liked 727 Times
my only question is whether the small amount of hydraulic fluid is prone to boil under heavy load in prolonged use.
#52
Bikes: 1980's Spectrum 10 sp Campagnolo Centaur, 1990 Eddy Merckx 10 sp Campagnolo Centaur, Bushnell Tandem, Co-Motion Speedster Tandem
Quoted: 185 Post(s)
Liked 102 Times
It’s working well for us. It’s got good stopping power. We can lock the rear wheel with just the rear brake, and modulate short of that. So it’s got plenty of stopping power.
#53
Clipless in Coeur d'Alene
#54
Bikes: 2010 Bob Brown Cycles tandem, 2019 Co-Mo Carrera tandem, 1980 Richardson tandem, 2014 Cervelo R3, 2018 Specialized Roubaix, 1985 Bianchi Campione, 1983 Trek 720, 2020 Trek Fuel EX8, 2021 Salsa Mukluk
Quoted: 72 Post(s)
Liked 116 Times
I totally agree about the Spyre. I found it to be okay for the front brake but inadequate for the rear. Since I was unable to mount the HY/RD on the rear, I went with a Paul Klamper disc brake, and it was a huge improvement. They're just a bit on the heavy side, though.
#55
Quoted: 331 Post(s)
Liked 332 Times
Carbon Composite max working temperature
I work for the world's largest CF composite supplier. At 180 degrees C rim surface temperature, the resin holding the layers of carbon together on your rim is beginning to carbonize. Go above that temp and you are no longer insured.
#56
Bikes: 1979 Raleigh Team 753
Quoted: 3375 Post(s)
Liked 371 Times
I used to ride clinchers on the tandem. I blew sidewall off Mavic Ceramics - twice. Last 20 years I just use tubulars.
We have dual Enve rims 24/20 with Vittoria Corsa 28 rear and Veloflex Vlaanderen front.
