Will shedding 1lb of belly fat have the same results as taking 1lb off my bike?
I like new gear as much as the next guy but the heaviest thing on my bike is me. Taking a pound there is a lot cheaper than taking a pound off the bike. Will the impact on my climbing be the same?
Bikes: Giant Propel, Cannondale SuperX, Univega Alpina Ultima
Quoted: 678 Post(s)
Liked 431 Times
Apples and oranges.
if I offered you two identical bikes to ride right now, with the only difference being that one had an additional weight in the frame, the lighter bike would be faster.
If the question was "what can I do to be faster a month from now?", you could be even faster still by losing weight on your body.
Ideally, you will train hard, lose weight, AND have a bike that hits a sweet spot between light/aero/and suited to your needs. But there is seldom, if ever a situation where there is a genuine choice between losing weight or riding a lighter bike. Do both.
Formerly fastest rider in the grupetto, currently slowest guy in the peloton
Thread Killer
Quoted: 3200 Post(s)
Liked 1,734 Times
To directly answer the OP, for steady speed climbing, a pound is a pound. Doesn't matter where it comes from. At all.
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
If you can tell the difference between a full and empty water bottle or two ...
FWIW, I have found a 10 pound loss is equivalent to being able to ride up an 8% grade in the next highest gear. (This doesn't deconvolve weight loss from strength gain, but since I am 54, I think it is primarily weight loss.)
Bikes: 2015 Jamis Quest Comp
Quoted: 270 Post(s)
I think this is the best answer, because if you worked hard to lose the pound, that will make you faster than taking a pound off the bike.
pan y agua
Quoted: 1461 Post(s)
Liked 737 Times
The human body is only 18-23 percent efficient cycling. The other 75 plus percent goes to heat that has to be dissapated.
Take fat off your body and your heat dissapation improves.
So lose a pound off your body and climbing improves 3 ways; the power needed for a given speed is less; the heat produced is less, and you better dissapate the heat produced (which increases the power you can sustain). Loosing a pound off the bike only gets 2 of 3
And as stated above, lose the pound off your body by better training and diet, and your power will also increase ( excepting that .1 percent of the population already at or below their ideal cycling weight)
pan y agua
Liked 737 Times
Quoted: 18883 Post(s)
Liked 10,646 Times
Most people lose muscle when they lose weight. That’s why race cyclists don’t try to lose weight in season, and it’s why body builders eat until they’re tired of eating. Muscle tissue is metabolically expensive, to build and to maintain, so your body does not want to invest in it unnecessarily, especially in lean times. You can gain muscle on a calorie deficit, but it takes work and attention to your diet. Much easier to get stronger at the same weight.
Also, most people who lose weight gain it back. Most bikes that lose weight do not.
Liked 10,646 Times
This is actually a lot more important than people realize. Heat dissipation is why a man can run a marathon faster than a horse can. We don’t have (much) body hair. Only dogs can out (distance) run us, and only in the cold.
On that note, the fittest humans on Earth are Nordic skiers, with VO2max as high as 100 ml/kg/min. One of the dogs running the Iditarod Trail was tested at 240! Puts a thoroughbred horse to shame.
edit: Hrmm. It's certainly possible anyway: https://en.wikipedia.org/wiki/Man_versus_Horse_Marathon
I'd be curious about more info on it. The wikipedio entry notes times of nearly 2 hrs flat...that's basically world class marathon speed. Were these seriously trained racing horses...or just, a horse?
Quoted: 550 Post(s)
Liked 325 Times
The same climbing seated.
Quoted: 18493 Post(s)
Liked 15,790 Times
I don't think that really comes into play. More weight lifted just means more potential energy created. It will just be transferred back to the pedals. No power gained or lost.
Custom User Title
Bikes: Fuji Roubaix Pro & Quintana Roo Kilo
Quoted: 2863 Post(s)
Liked 31 Times
Is this actually true??
Only on the internet could this be a valid debate. Hilarious!
The bike has nothing to do with how fast you are.
You loose weight and slim down, and it's going to make you a faster cyclist. Real, measurable gains that are huge in comparison to any theoretical marketing hyperbole.
Loosing fat weight is not a end, it's a by-product of becoming fit.
Ignore the bike because, as any fred on a Venge will tell you, marketing hype doesn't make you any faster.
Spend money and energy on your body. You will get huge benefits from it.
This--> 100%
This--> 100%
Untrue, because it ignores the physiological l effect of fat on your body.
Bikes: 2015 CAAD 10; 2016 Felt Z85
Quoted: 156 Post(s)
Liked 5 Times
...but alas, I can see I would have been wrong.
Liked 10,646 Times
The race you linked to, sometimes humans run it faster than horses, and it’s not even a full marathon.
