Thoughts on Power meters...???...
Ghost Ryding 24/7
Bikes: Giant Defy with Dura Ace group, & Ksyrium SL's,Specialized Allez Shimano mixed/mashed,2011 Opus Sentiero,2008 Kona Jake the Snake,Custom built track/fixed,Stumpy Hartail,Kuwahara/ET bike.
I'm considering getting a comp/GPS/PM for my bike, & am considering the iBike iPro Gen III Power Meter.
What are your guys/gals thoughts on this device?
Anyone have any experience with this device?
https://ibikesports.com/ipro.html#page=page-1
Bikes: S-Works Roubaix SL2^H4, Secteur Sport, TriCross, Kaffenback, Lurcher 29er
Having to recalibrate it every single ride for the changed environmental conditions makes it a non-starter for me.
These have been discussed quite a bit here.
Cost is $5-600 depending on model.
They work by calculating power off of measurements of forward air resistance and incline along with user inputs of weight, etc.
Throw the stick!!!!
Because you can trust the numbers in all environments and on group rides.
Good used power taps regularly sell in the $500 - $700 range.
I may be fat but I'm slow enough to make up for it.
Señor Member
Bikes: 2018 Lynskey R380 Ti | 2011 Hampsten Travelissimo Gran Paradiso Ti | 2001 De Rosa Neo Primato - Batik Del Monte, Genius | 1991 Eddy Merckx - Motorola, TSX
Quoted: 36 Post(s)
Liked 14 Times
Using a PM effectively, that's a whole other can of worms to open.
Tour De French Fries
Bikes: 2010 Cervelo R3 SL & 2013 Airborne Goblin
I had an Ibike Pro Gen III. It wasn't very good. Resold it after having it for only 2 months. Data was sporadic at best.
Also setting it up is a pain in the ***
Señor Member
Quoted: 36 Post(s)
Liked 14 Times
Ghost Ryding 24/7
I'm also considering a Garmin Edge 500.
No not a PM, but has most of the functions I want in a bike comp.
I like the idea of a PM, & agree with is being calculated on Torque. I'm asking about this particular PM since I can get it for $200.
If the consensus thinks it's not a great device I may pass on it.
I'm open to other PM suggestions too, can I get links to what some of you guys use?
Thanks everyone!
Thanks everyone!
Thanks everyone!
Thanks everyone!
If you want to do some serious PM based training then you need a Powertap (wheel based, $500 used, $1000 and up new) or a Quarq (crank based, $1500 and up). The garmin 500 is a great head unit with or without a PM.
soon to be gsteinc...
Well I have to chime in.
History: I am a Cat 1 beast who thought I knew everything I needed to about training.
Then I got a powermeter only to learn that there was a lot I was doing wrong or misguided. I will never ride without one again, ever!!!
Quoted: 550 Post(s)
Liked 325 Times
That's as much as a used wireless powertap and twice a used wired second generation one which provides the same numbers as the wireless powertap but requires you to use a yellow computer that isn't nearly as sexy as a Garmin.
Throw the stick!!!!
I'm the same way, not a beast but I don't like riding without a power meter. In my mind being fat and out of shape makes it even more important to have a powermeter. With it I know that on a 6 minute climb I can hold around 340ish watts. Therefore if I look down at the beginning of the climb and see that I am putting out 400ish watts trying to keep up with you skinny guys I know that I am going to blow up. I am then able to lower my wattage to a sustainable number and get to the top without falling over dead or completely blowing up and having to do the last half at 150 watts.
https://www.ibikesports.com/Download/...une_09_red.pdf
Direct measurement of torque off of a strain guage, while more expensive, is really the way to go if you are serious about training with power.
Here's another huge problem with it in my book -- iBike recommends battery changes every 2 hours for operation in 40 degrees and below.
Thanks everyone!
Thanks everyone!
Faster but still slow
Bikes: Trek 830 circa 1993 and a Fuji WSD Finest 1.0 2006
The power is estimated off of effective wind speed, grade, and other parameters like rider's aero drag. My understanding of the iBike is that you have to calibrate it at the beginning of each ride so it knows what the conditions are. But conditions change, and the data is therefore based on shifting sands. There is a ton of information in this document:
It would seem that the only thing that would change is the weight of the bike and rider throughout a ride as water is consumed and perspired. I lost 0.5 lbs on my long ride yesterday. I lost the equivalent of half a water bottle in sweat.
I did a road race years ago (~130 miles) and believe I was down 6 pounds...
Plenty of things moving around besides rider weight.
Quoted: 1186 Post(s)
Liked 289 Times
My impression is that the iBike is a toy and if you're serious about training with power you'll be disappointed.
