bike laser light headlamp...
It do, but it don't.
interesting idea. if you ride a lot at night it might be worthwhile.
https://www.cnn.com/2013/09/13/tech/t...html?hpt=hp_c4
I don't get it.
What does this do that a very bright light won't do? And what about the bright light to see the terrain? I think I'm missing something.
J.
J.
Bikes: 2005 Raliegh Grand Prix w/significant upgrades. 2013 Specialized Rockhopper
That's what I was going to say. I just did a ride today today using my new 2200 lumen light and someone highbeamed me because it was so bright. I think it's safe to say that the driver saw me.
Mostly Harmless
Bikes: Have two wheels
Quoted: 13726 Post(s)
Liked 4,536 Times
But, it's got a frickin' laser beam.
SuperGimp
Bikes: *1998 GT Forte Ti 700c, Totem KDS-D 26" fatbike, BirdyGT 18", Brompton M2LX 16"
Quoted: 88 Post(s)
Liked 5 Times
I have a tail light that puts down 2 laser lines.
I suppose it helps since most people don't see red laser lines on the road.
Nothing wrong with this guy's product but I think it makes more sense on the back of the bike or on both ends.
I agree - back of the bike.
What I think might be interesting is a red laser line that shows the line that matches the minimum distance from the cyclists.
J.
J.
Quoted: 18883 Post(s)
Liked 10,646 Times
Quoted: 50 Post(s)
Actually, if it's not too much weight and size, it definitely COULD be useful.
A 2200 lumen LED suffers from the big spill of a lot of the light - hence drivers high beaming you to 'tone it down.' It's really annoying as a driver to get beamed by that kind of light.
With a properly directed laser (not sure the bike-shape is the best solution, but same idea), you could get similar visibility at night, with a lot less annoying light spill.
And I agree that this would be far, far more useful as a rear-pointed laser than front-pointed one.
Portland Fred
If a motorist can't figure out you're a cyclist based on your body, reflective gear, and lighting, I'm not sure how projecting an image of a bicycle on the ground 15 feet in front of you is going to help. Are we now counting on drivers to stare at the ground in time to pick up a cyclist who will encounter that spot in a fraction of a second?
The inventions in that article looked pretty dumb. The one exception was the cyclist detection system by Volvo https://www.techradar.com/news/car-te...-brake-1141471
Quoted: 50 Post(s)
Unfortunately, as is, there are very few bike lights that have a properly directed beam pattern.
I agree that the laser image in front of a bike doesn't seem like it'll help a lot, but it could help some. A rear image would definitely help, though, if used in conjunction with blinkies and clothing.
I'm in favor of anything that makes a driver think "wait - wtf is that?" for long enough to notice that there's a person/cyclist in the area. (Still won't help texting drivers.)
Quoted: 4273 Post(s)
Liked 1,369 Times
A flashing front or rear light would be visible from much, much farther away than this laser thing (which is pointed at the ground near the bike).
Portland Fred
Getting weird with the lighting is asking for slow response times. Most people continue to do exactly what they're doing when they don't know what's going on so it's best to keep things simple.
Quoted: 50 Post(s)
I never said I'd use this exclusively.
If possible, I'd like ALL options simultaneously. Clothing, lights, blinkies, and yes, a LED on the ground, as long as it's no hassle to carry and mount.
The LED also has the ?WTF factor, meaning it's more likely a motorist will take an active interest in both noticing and identifying the weird pattern on the ground.
And yes, I love my bright rear blinkies (PBSF and Mars 3.0) - keep those batteries bright and they're awesome. The LEDs would only be able to add a tiny amount of added visual features compared to a bright rear blinkie, but as long as it's no hassle, I'll take anything I can get.
Portland Fred
When you start putting lots of blinkies on, mount them at heights or in locations where motorists aren't used to them, etc, you break up your form which makes you less recognizable. Yes people see you, but they actually have to think for an instant before they know how to respond. So even if two lights might be brighter than one, it doesn't help from the perspective of making people less prone to hit you.
Quoted: 50 Post(s)
I see your point, but I still would rather have multiple options of visibility, and ideally, some 'weird' ones, to get attention.
Bright tail-lights are great, but they absolutely can blend into an urban environment - I've seen super-bright taillights in the middle of LA at night, that I didn't even realize were a cyclist since so many cars were buzzing about until much later.
I also recall some UCLA students who mounted some neon-like piping to their bike frames, in wacky colors, like neon blue and purple. Not super bright, but effective enough at night that as long as you weren't head-down texting, you would definitely pay attention to it just because it was so distinct from all the other white and red car-lights that were whizzing around.
Liked 1,369 Times
Sounds like a gimmick to me.
Portland Fred
I want a tail light that projects a hologram of a cyclist (or maybe even a car) behind me and to my left so that motorists can give me a wider berth when passing.
And while we're at it, how about an autofiring/aiming with face detection paintball gun that shoots red paintballs at motorists when a collision is detected with said hologram...
pan y agua
Quoted: 1456 Post(s)
Liked 733 Times
You could get lost and die.
You could hit a tree and die.
I ride with two 600 lumens cygolites on my handlebars and one 400 lumens cygolite affixed to my helmet with zip ties. I have two flashing taillights on each side of my frame and another flashing taillight clipped to the back of my helmet. Cars dim their lights when they approach me. No drivers honk their horns when they come from behind because I am easily visible from far away. I wear a bright, lime green jacket and my tights and over boots are loaded with reflective designs. I am visible, I am happy, I am alive.
The main thing is to put bright lights where people aren't used to seeing them. In that regard, I find a Cree on the helmet to be very effective. You can also nail drivers with it if they're about to pull out in front of you. This has saved my bacon many times. Also, I have a 1 watt blinky on the back of the helmet. People seem to notice lights more when they're up high.
Farmer tan
Actually, what I use that gets me serious concern from drivers. They give me more room and they typically slow down. I use a Dinotte 300R tail light that has something approaching a 300 lumen output. For some reason, it really works and I still chuckle after using it for three years, when drivers slow down and go way around. I'm not sure a laser would improve on this.
J.
J.
Metaluna
22
10-22-17 09:26 AM
PaulRivers
Commuting
22
06-14-11 12:30 PM
Richard Cranium
6
08-13-10 08:02 AM
