[Brompton] Trunk bag to fit Brombacher rear rack?
Quoted: 576 Post(s)
Liked 119 Times
Hello
I found this rear rack on eBay, which might actually be a copy of the Brombacher rack but it does the job just as well.
So I now need to find a rack top bag…
Any idea where I could find a bag that would fit?
Thank you.
- about 50cm/20" horizontally and 40cm/15" vertically to carry my camping gear (tent, matress, sleeping bag)
- preferably waterproof, but I can always stick a drybag inside if it's not
- Fast and easy to install/remove
Thank you.
Where is the company situated?
Quoted: 576 Post(s)
Liked 119 Times
The one selling the rack on Ebay? It says this when clicking on the account:
"Based in United Kingdom, chiman2288 has been an eBay member since Jun 26, 2005"
I assume it is just a copy from China, but shipping cost was more reasonable than the one charged by Brombacher.
Anyway, it looks like the 24 liter Ortlieb Rack-Pack could do the trick, although it'd have to be moved a bit to the back to provide enough heel clearance.
Any where , any one will do, I have 2 that use velcro to attach top of any Rack.
Obviously you have to remove It, before you can use the rear rack as a your Brompton's Kickstand..
Velcro is easy to Use, for you , right?
You can always hold that Dry Bag down with a stretch Net, un hook it in a moments time.
Topeak and Altura make a rack bag that is simply held on with a large sheet of velcro that is strapped to the rack..You can remove the bag in a second which would make it suitable to use when folding your Brompton..Both bags have expandable side panniers..
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 337 Times
Quoted: 840 Post(s)
Liked 337 Times
After you fold the bike its weight rests on the rack and it needs to withstand being carted around. But sure, practice trumps theorizing. Looking forward to the report.
Schwinnasaur
I think the strength of the carrier depends on the grade of the aluminium...The whole weight of the bike may be put on the two rear supporting struts of the carrier when it is folded and put down on the ground quickly..On a Brompton carrier there are four supporting struts at the back..
An alternative to the Brombacher rack is the Nitto rack..https://www.perennialcycle.com/produc...idproduct=6413
Sadly it costs a fortune I think..$180 plus postage..
Quoted: 576 Post(s)
Liked 119 Times
Thanks for the infos.
There's a third alternative: H&H's Titanium Rear Rack going for $125
https://dinokiddo.me/?portfolio=hh-t...a-for-brompton
The Brombacher must be very good value at $45 and very light also..What looks good about the rack is it is likely to add a bit of strength to the front support struts of the forward rolling wheels..
Quoted: 840 Post(s)
Liked 337 Times
This now removes floppiness of the shape. To deform the shape you need to compress or expand some struts. This design is superior to that of the cheap rack.
What I am saying is that the design puts stress on those ends in lateral direction virtually ensuring failure in the course of time. If you look at the rack from the rear, you see a rectangle. A rectangle is floppy - think of a cardboard box with bottom and top removed. To prevent such box from flattening, you would need to stiffen the corners and stress would still concentrate by those stiffened corners so the stiffness would need to rely on stiffness of paper. Once you put just the bottom or top back, the shape is suddenly far more stable. Now the original Brompton rack does not put the bottom back, but uses triangulation with extra struts running at an angle to the outer ones:
Also, doesn't the fact that OP's rack attaches to the orange rear triangle of the bike act as some sort of "box top" to the rectangular rack?
Quoted: 840 Post(s)
Liked 337 Times
The two rather than one support points on top in the OP rack + bridge bars should certainly help, but they are very far from the outer end of the rack. I expect the outer end to be wobbly on a short time scale and getting shoved with the rack going out of shape on a long scale. However these are expectations - in due time we should find out from Winfried how things play out in practice.
55+ Club,...
Bikes: 9+,...
Quoted: 1135 Post(s)
Liked 868 Times
Quoted: 576 Post(s)
Liked 119 Times
I've been using that $50 aluminum rack bought on eBay for almost two years, and it's fine. I've done several trips with it, and carried a bit of groceries:
(yes, I might get a Burley Travoy or a Carry Freedom Y Large trailer).
Lighter than the original from Brompton, and 3-4x cheaper than alternatives in titanium.
