Mounting A Rear Rack via QR Skewer - Advice
Quoted: 80 Post(s)
Liked 9 Times
I built up a really nice steel road frame with no brazons for rack mounting. I have rear racks on all my other bikes and thought I could live without one on this really nice steel road frame. I tried frame mounted bag, top tube bag, etc. Conclusion: I need a rear rack to but a small trunk bag... wallet, keys, tool bag, snacks, tubes, inflator, and a small pair of binoculars.
The bike really built up nice and I used all silver components so it would look vintage. Running 9 speed friction with a lovely set of miche/H plus wheels in high polish.
I was looking for kind of a classic sliver rack and found this: Soma Champs Elysees Rear Rack (See picture attached). They indicate it can be mounted off the QR skewer and the rear brake mount bolt. So I will not need any p-mounts. It is not cheap at $100 but is stainless so it should last. But more importantly I think it will look correct on the retro steel frame and be plenty sturdy to hold a small truck bag with only a few pounds in it.
I was wondering how mounting a rack on the rear quick release skewer actually works out in practice. Is it pretty secure and trouble free or is doing a rack off the quick release problematic?
Can I use my current quick release or will I need to go to a long quick release? I believe it is a standard 130mm road QR so I could get a 135mm if needed.
Any advice, ideas would be welcome.
Bikes: 2017 Salsa Carbon Mukluk frame built with XT, 2018 Kona Rove NRB build with Sram Apex 1,2008 Salsa El Mariachi, 1986 Centurion Ironman
Quoted: 286 Post(s)
Liked 100 Times
I was looking for kind of a classic sliver rack and found this: Soma Champs Elysees Rear Rack (See picture attached). They indicate it can be mounted off the QR skewer and the rear brake mount bolt. So I will not need any p-mounts. It is not cheap at $100 but is stainless so I should last. But more importantly I think it will look correct on the retro steel frame and be plenty sturdy to hold a small truck bag with only a few pounds in it.
I was wondering how mounting a rack on the rear quick release skewer actually works out in practice. Is it pretty secure and trouble free or is doing a rack off the quick release problematic? Can I use my current quick release or will I need to go to a long quick release?
Don't complain about the weather and cower in fear. It's all good weather. Just different.
Quoted: 1819 Post(s)
Liked 1,693 Times
Mounting a rack on the quick release skewer is going to be a huge nuisance every time you have to remove the rear wheel for any reason. P clamps are preferable to this type of mount since they are set and forget, you never have to worry about them once installed
Quoted: 80 Post(s)
Liked 9 Times
Other Option = Tailfin
My other option would be a Tailfin Rack. Which is certainly not retro and it is not cheap but it mounts of special quick release skewers that have pegs on the ends for the rack to mount to and a quick release clamp to the seat post. You can take it on and off in 10 seconds they claim. It was designed for road bikes with no mounting points on the frame. See link:
TailFin S
TailFin S
Liked 1,693 Times
The level of the nuisance factor is going to depend on how often you feel the need to remove the rear wheel. For me, this would get old very quickly since I often remove the rear wheel to clean my bike or to stow it in my car trunk when I travel with it, not to mention changing tires or repairing flats.
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
I’m not a fan of P-clips, however. They are just barely adequate. Tubus rack adapters are much more stable and much easier to use, They can be used as the upper and/or lower.
I have them on a couple of bikes as the upper mount and at least one bike as the lower mount.
They are relatively strong...I use them for a commuting load (about 15 lb). I’ve also used them for off-road touring. I’m not carrying much of a load in the little bags but the rack is extremely stable. I’ve been using them for about 10 years without problems.
You have to measure the diameter of the seat stay to get the right size (use an adjustable wrench if you don’t have calipers)
Stuart Black
Stuart Black
Liked 1,693 Times
I don’t agree. I had an Old Man Mountain long ago. The skewer bent and was almost impossible to remove from the hub. I went a different route.
Quoted: 1438 Post(s)
Liked 1,092 Times
Likes For dsbrantjr:
Liked 4,218 Times
I agree. P-clamps are a pain because of the single bolt. As an added bonus, you can leave the Tubus adapters in place if you take the rack off for some reason.
Stuart Black
Stuart Black
Quoted: 836 Post(s)
Liked 1,061 Times
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
Another route, if your seat-post adjustment and seat are strong and rigid:
Arkel Randonneur Rack:
Quoted: 80 Post(s)
Liked 9 Times
Thank you
I ordered a Soma Champ Elysees Rear Rack (tubular stainless steel) and my local bike shop is trying to get me some 14mm Tubus Rack Clamps that Cyccommuter recommended. I think that rack will be plenty for a light day ride trunk bag and keep the retro look since it is silver. I appreciate all the input.
Liked 4,218 Times
Not really. They come with friction tape. Once tightened they don’t slip.
Stuart Black
Stuart Black
